WH16NS40 cannot rip UHD after few succeed rip
kelvinhin
Post by kelvinhin »
I have a WH16NS40 flashed to MakeMKV's custom firmware to rip UHD Blu-ray. The drive is in Ratoc RP-EC5-U3AI USB enclosure and connected to MacBook Pro which running macOS 14.5 by USB 3.0 B to C cable directly, no USB hub or converter is used. I had use this setup to rip 16 UHD Blu-ray successfully. However, when I tried to rip another UHD Blu-ray after few days, I got "LibreDrive compatible drive is required to open this disc - video can't be decrypted." error. I ensured the LibreDrive status is "Enabled". I tried to remove "_private_data.tar" then restart the computer and the app but still got the same error. I also checked the computer can connect to "hkdata.fairuse.org". I tested can rip Blu-ray and DVD successfully.
I had also tried to rip in Windows 10 environment, unfortunately still got the same error.
Re: WH16NS40 cannot rip UHD after few succeed rip
Have you tried power cycling the optical drive? Power off the enclosure holding the drive for 15 seconds or so, then power it back on.
