BETA key not working
ggking7
Post by ggking7 »
My evaluation period expired so I tried to use the BETA key as described here:
http://www.makemkv.com/forum2/viewtopic ... 1218#p4421
but makemkv says the key is expired and removes it. Can we still use makemkv without purchasing since it's in BETA?
Re: BETA key not working
Post by mike admin »
Yes, the key is updated.
ggking7
Post by ggking7 »
I don't get the message about the key being removed from ~/.MakeMKV/settings.conf any more, but it still tells me my evaluation period is over and it doesn't let me rip a disc. I'm on 1.5.5. This is all I have in settings.conf:
appKey = "T-o4vIHFtFMG0O4H5u0NT40YJcRLnfXk2j1O0Yiy3O6YrwbHga7kWEYays4AS6MTK9h9"
I've double-checked permissions on the folder and file.
ggking7
Post by ggking7 »
I forgot the underscore in app_Key.
Archo
Post by Archo »
Makemkv beta expired and there isnt a new one. Batch encode errors out cause of trial expiration but i believe you are still allowed to use Makemkv regardless of beta expiration (at least until our of beta).
Romansh
Post by Romansh »
Archo wrote:Makemkv beta expired and there isnt a new one.
Yes, there is: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
hjr333
Post by hjr333 »
Hi there,
the beta key is not working again. Although it should until the end of September
regards
The link currently has a key that expired a couple of days ago. The message you're replying to is 6 years old!
When Mike replaces it, the note at the bottom will say something like....
and is valid until end of (probably) November 2017.
Right now, it's 1 October in many parts of the world, so the September key doesn't work anymore.
dorgan
Post by dorgan »
Would be really great if this didn't happen a couple times a month... Not sure I want to consider supporting something that stops working until its updated by the owner...
It hasn't happened to me since 2011. Of course, that was when I bought a permanent key.
The keys are typically good for two months. If you're having it happen 'a couple of times a month', there is something else going on.
