Aspect ratio error with WD TV Live (only DVD)
Tomka
#1 Post by Tomka » Thu Sep 01, 2011 9:02 am
Sorry, but i didn't read all the post and at first sight I doesn't see the answer at my problem.
So.
I use this tool to make backups from my DVD-s ans BR-s. Its working perfect with BluRay discs.
In a case of a DVD it makes correctly the mkv file, but with 4:3 aspect ratio. :roll:
If I look the original VOB files with my WD TV Live, I use the widescreen mode to my 16:9 TV. :!:
But if I convert these files to mkv, I must to switch the WD TV to normal mode to stretch the movie to its original size.
It is an error of the converting process or the WD TV's mistake with mkv? But why working pretty good with BR rips?
Tom
Budapest, Hungary
reebok
Re: Aspect ratio error with WD TV Live (only DVD)
#2 Post by reebok » Thu Sep 01, 2011 12:03 pm
makemkv doesn't alter the info from the disc. are you sure your dvd's are in 16:9 format? many dvd's are in full screen (4:3) aspect ratio. usually it says if it's widescreen or full screen on the disc and on the case.
Tomka
#3 Post by Tomka » Thu Sep 01, 2011 6:08 pm
It's look like a wide screen movie... Horizontally fills the entire screen.
After converting it's look like a 4:3 movie, but in the picture there is the full information.
This is the opposite case of viewing old 4:3 movie on new 16:9 screen...
Tom
crowfax
#4 Post by crowfax » Thu Sep 01, 2011 8:00 pm
I've not had this issue before. Where are you from? Can you give me an example of a disc that this happens with?
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
Tomka
#5 Post by Tomka » Thu Sep 01, 2011 9:27 pm
I'm from Hungary.
The last one DVD was the "Limitless".
Tom
Tomka
#6 Post by Tomka » Thu Sep 01, 2011 10:11 pm
I tried it with some old discs and there is no such problem... :shock: :shock:
Then it must be a disc specific error?
T.
Romansh
#7 Post by Romansh » Thu Sep 01, 2011 11:27 pm
Tomka wrote:I tried it with some old discs and there is no such problem... :shock: :shock:
T.
Possibly. Which discs are you having the issue with and how did you arrive to the conclusion that they were 16:9 and not 4:3?
Tomka
#8 Post by Tomka » Fri Sep 02, 2011 5:57 pm
You have right!
In the downloaded mediainfo app show this information: 720:576 in 4:3 format.
Can I somehow change this setting in the mkv?
T.
reebok
#9 Post by reebok » Fri Sep 02, 2011 10:02 pm
the beauty of makemkv is that it does not alter the content it rips. this is why it was fairly obvious they were not 16:9 discs.
Romansh
#10 Post by Romansh » Fri Sep 02, 2011 11:00 pm
Tomka wrote:I'm from Hungary.
Tom
You mean this movie?
http://en.wikipedia.org/wiki/Limitless
Tomka
#11 Post by Tomka » Sat Sep 03, 2011 3:02 pm
Yes thats the movie.
I read after, this is the anamorphic widescreen...
But the WD TV can' t recognize this , so it plays it as a standard 4:3 ....
T.
Romansh
#12 Post by Romansh » Sat Sep 03, 2011 6:05 pm
Tomka wrote:In the downloaded mediainfo app show this information: 720:576 in 4:3 format.
For what: the DVD's VOB files, MakeMKV's output, or both?
Tomka
#13 Post by Tomka » Sun Sep 04, 2011 4:03 pm
For the mkv it is sure:
Track information
Type: Video
Codec: Mpeg2
Resolution: 720x576
Aspect ratio: 4:3
Frame rate: 25
At the weekend i don't have the DVD with me, but if i got back i will looking it one more...
But don't think it will be different to the mkv file... :roll:
Tom
Romansh
#14 Post by Romansh » Sun Sep 04, 2011 7:22 pm
Tomka wrote:But don't think it will be different to the mkv file... :roll:
Then you'd better not buy your discs in Hungary and order from abroad.
Limitless is 2.40:1, so if the disc you have is indeed encoded in 4:3, then out of the 576 pixels of vertical resolution, a whopping 256 pixels (44.4%) is used for letterboxing (black bars at the top and bottom), leaving you with only 320 pixels of actual vertical resolution (instead of 150 pixels of letterboxing and 426 pixels of content if it were encoded in 16:9).
Unless of course they used Pan & Scan, in which case you're just not seeing the whole movie.
setarip_old
#15 Post by setarip_old » Mon Sep 05, 2011 6:43 pm
@Tomka
Hi!
Although it's about standalone players, I believe the following thread from the Doom9 Forum may provide you with the insight you're seeking:
http://forum.doom9.org/showthread.php?p ... ost1522333
