yeah but pioneers can be flashed on windows only email me if you can send that info from windowsmas1701 wrote: ↑Sun Jun 30, 2024 11:51 pmHi,
is there any chance for UHD with this OEM USB3 BD-XL drive? When inserting an UHD disc, it only makes funny sounds, then stops.
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: ALDL2403xxxx
Firmware-Datum: 2018-08-22
Highest AACS version: 71
Drive platform: RS8511
Firmware version: E101/ID26
After successfully flashing a first drive on Linux today and reading some of the previous posts, I'm at least a bit hopeful that there is an expert here who can help.
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM for clwelch63 deleted. was not read within a week.
Hi coopervid,
Sorry I wasn't able to get to the PM you sent. I've been traveling. I'm back home and would appreciate a second PM.
Thanks,
Chris
Thanks,
Chris
Coopervid wrote: ↑Tue Jun 25, 2024 9:21 amPM sent.clwelch63 wrote: ↑Sat Jun 22, 2024 3:40 pmHi coopervid,
I'd like to flash my PIONEER BD-RW BDR-UD03 with the firmware that lets it read UHD discs. I see a lot of discussion about it, but don't see where to download the firmware. Is there a download site? Thanks in advance.
Here's my drive information:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Firmware version: 1.10
PM sent.clwelch63 wrote: ↑Sat Jul 06, 2024 8:21 pmHi coopervid,
Thanks,
Chris
OS device name: E:
Revision: 1.10
Respectfully, I'd like to point out that this seems to be incorrect.Billycar11 wrote: ↑Mon Jul 01, 2024 12:33 am
The drive I successfully flashed on Linux was an ASUS drive manufactured by Pioneer. I even reported on the successful flash attempt in full detail right here on the forum. The drive was on up-to-date encrypted firmware and is now on an older, non-encrypted MK firmware.
If you just want to sell a piece of windooze software to me (as suggested by your signature), you are out of luck.
if you want to be proven wrong post your makemkv drive info sectionmas1701 wrote: ↑Mon Jul 08, 2024 12:20 amRespectfully, I'd like to point out that this seems to be incorrect.Billycar11 wrote: ↑Mon Jul 01, 2024 12:33 am
if your drive platform is mt1959 or mt1939 its not a pioneer its an LG
oh look mt1959 you say your drive was
so you are incorrect giving people false hope and misleading them and trying to prove a person wrong who is always helping people here.
i give away all the info for free the charge for those who dont want to do it them selves with the guide.
That was NOT my intention. But thanks for the clarification.Billycar11 wrote: ↑Mon Jul 08, 2024 1:12 amif you want to be proven wrong post your makemkv drive info section
In fact, I'm shocked that ASUS has to resort to more than one OEM supplier for their drives. So if this is a Pioneer drive and the other is in fact an LG, then of course you may be completely right, I just can't tell. I have to depend on what I read here and obviously I didn't notice the difference between MT19x9 types. It is not really to be expected that this little change in the number has to do with a different manufacturer, it looks more like another model from the same manufacturer.
Sorry for the mix-up.
So if this is a Pioneer drive and if there is an alternative firmware with less artificial restrictions, is there a reason why this FW is not just available for download and has to be requested? I doubt the legal situation differs from the situation of other FW packages.
Btw., I just flashed the FW of another ASUS/LG drive remotely for a friend using MeshCentral remote control. He picked up the drive by recommendation after I've successfully flashed my own.
As for flashing with Windows, yes, of course I can do that. It's an external USB3 drive after all, so it's not "stuck" to the Linux system.
If look on the sticker of your Asus you will see it says LG bh16ns40mas1701 wrote: ↑Mon Jul 08, 2024 11:11 pm
The pioneers are way better I stopped selling LG/Asus desktop drives back in 2019
Hello! I have the same drive - hopefully coopervid can assist me as well.
Thank you!
OS device name: F:
Current profile: DVD-ROM
Revision: 1.11
Firmware date: 2018-11-28
Firmware version: 1.11
Check your PM.gschmidl wrote: ↑Wed Jul 10, 2024 9:28 pmHello! I have the same drive - hopefully coopervid can assist me as well.
Thank you!Code: Select all
Drive Information OS device name: F: Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: [redacted] Firmware date: 2018-11-28 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Hello Coopervid. May I ask for the UHD patch too, please? My Verbatim 43887 (non UHD) shows this:
Revision: 1.14
Serial number: BADL47xxxxx
Firmware date: 2020-06-15
Firmware version: 1.14
Unrestricted read speed: YesRe: Pioneer BDR-UD03 UHD possibility
Hi, I think I have the same Drive. SDFtool Flasher says "The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed."
Is there a way to flash it so I can play ultra hd blu rays?
OS device name: E:
Revision: 1.14
OS device name: E:
Revision: 1.14
Yeah email me your makemkv drive info section like that see belowDany-el wrote: ↑Sun Jul 14, 2024 9:29 pmHi, I think I have the same Drive. SDFtool Flasher says "The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed."
OS device name: E:
Revision: 1.14
Check your PM.maxxie wrote: ↑Sat Jul 13, 2024 4:29 amHello Coopervid. May I ask for the UHD patch too, please? My Verbatim 43887 (non UHD) shows this:Thank you very much!Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: BADL47xxxxx Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
