Rororororo
When injecting P7 MEL CMv4.0 to BL would it be possible to add a workflow to output it straight as P8 mkv? I mean without using 4-1 after 1-1
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
I dont see a use case for that ? Why did you extract the P7 rpu in the first place if you wanted a p8 rpu? just process the original P7 rip into 4-1?
I never had to inject a P7 rpu to a different BL.
Rororororo
I meant P7 with WEB CMv4.0 bloc from 2-6RESET_9999 wrote: ↑Sun Jul 07, 2024 12:05 pmI dont see a use case for that ? Why did you extract the P7 rpu in the first place if you wanted a p8 rpu? just process the original P7 rip into 4-1?
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
In that case, just inject the synced cmv4.0 P5 rpu with (1-1) as you would do for any P8 hybrid release. The script will convert P5 to P8.
That's what I do for the MEL P7 movie I want to add the cmv4.0 bloc, no need to transfer the cmv4.0 to P7 for those movies if what you want is P8.
Rororororo
The more you know, thanks!RESET_9999 wrote: ↑Sun Jul 07, 2024 2:48 pmIn that case, just inject the synced cmv4.0 P5 rpu with (1-1) as you would do for any P8 hybrid release. The script will convert P5 to P8.
One thing I noticed, after converting P5 to P8 (Dune: Part Two), the Metafier reports a lot of positive Level 8 lift values. Can these warnings be safely ignored?
WARNING: Positive Level8 lift value at shot: UniqueID = cde4f9ee-e827-4cc9-80d6-e0a583667ac6 @[6926-7019]
WARNING: Positive Level8 lift value at shot: UniqueID = ee1d2741-c522-43bf-a66e-21e96d1fe3d9 @[7055-7101]
WARNING: Positive Level8 lift value at shot: UniqueID = 2e295c16-58cb-4243-9c30-c4725f4c89b6 @[7381-7434]
WARNING: Positive Level8 lift value at shot: UniqueID = df9739dc-3b5b-4fd8-b46f-bcfa6183d72e @[7634-7857]
WARNING: Positive Level8 lift value at shot: UniqueID = b688ce45-b34a-45e6-8624-26864f72ea11 @[8460-8546]
WARNING: Positive Level8 lift value at shot: UniqueID = fb10dc96-8668-44b5-8b4c-81ea88848eed @[8639-8719]
(...)ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Ugoos AM6B Plus
those warnings are normal and they are for the colorist who did the metadata.
metafier has two modes:
mode 0 in the script = find offset values over 2048
mode 1 in the script = find offset values over 2100 which causes raised black bars.
but the thing is any offset positive value(over 2048) is ignored by the HDMI players so DV cannot have raised letterbox anyway.
I did some positive lift test files here: https://drive.google.com/drive/u/1/fold ... fx6vRYDEfs
Metafier warnings are fine, errors are not.
FonduemangVI
I just had a chance to check Mando and I can't see any sync issue. Can you provide a particular timestamp?staknhalo wrote: ↑Tue Jun 25, 2024 7:37 pmwhatever problems watching at the computer/windows platform aside - is that the best windows store dv player then outside of any official dv pcs player etc?
Framestor Mando S02E08 Hybrid UHD out of sync too - prob all the (d+ or iT/D?) stuffRESET_9999 wrote: ↑Tue Jun 18, 2024 5:04 pmand it's only because I know him personally and I know that he always does all the necessary checks.
Some older framestor releases are wrong and I just checked the Captain America hybrid is still available on BHD even though it's a VERY different grade and the RPU is not even in sync with the BL.
Same for their Black Widow release and others.
You can pm the list of hybrids you're not sure and I can have a look if i can find them.
Life is busy, havent been able to monitor the development of DV. Can someone explain why is it a big deal CMv2.9 vs. CMv4.0? I see the latter mentioned a lot here. I read the official document, but dont understand why its a big deal. Thanks!
CM v4.0 provides creators more control over tone mapping, thus it's more accurate when applied properly.
https://professionalsupport.dolby.com/s ... v-4-0-FAQs
https://professionalsupport.dolby.com/s ... tween-them
Hi everyone, I'm using cm analyze to calculate MaxCLL and MaxFALL values of a video file.
Unfortunately the cm analyze process gets killed randomly during the measurement thus, making it freeze forever. It must be a bug related to cm analyze itself. Has anyone else experienced this problem when using cm analyze?
Here it is a brief log:
Drag and drop your file: C:\Muxing\500.Days.of.Summer.2009.WEB-DL.2160p.HDR.mov
Set the Image Aspect Ratio: 2.4
Starting workflow...
Workflow started
Command being used: "C:\Dolby\DoVi_Scripts\tools\cm_analyze.exe" --bda --source-format "bt2020 pq" --aspect-ratios 1.77777777777777777778 2.4 C:\Muxing\500.Days.of.Summer.2009.WEB-DL.2160p.HDR.mov "C:\Muxing\500.Days.of.Summer.2009.WEB-DL.2160p.HDR.xml"
Copyright (c) 2013-2024 Dolby Laboratories, Inc. All Rights Reserved
07/18/2024/19:37:30.562000000 CPU: AMD Ryzen 7 7700X 8-Core Processor (AuthenticAMD) [ mmx mmxext sse sse2 sse3 ssse3 sse41 sse42 sse4a avx avx2 avx512f avx512dq avx512cd avx512bw avx512vl avx512bmi fma ]
07/18/2024/19:37:30.564000000 atom: WARNING Unknown Video Sample Description Extension: pasp
07/18/2024/19:37:30.588000000 quicktime: WARNING ignoring media track of type text
07/18/2024/19:37:30.621000000 atom: WARNING Unknown Video Sample Description Extension: pasp
07/18/2024/19:37:30.647000000 quicktime: WARNING ignoring media track of type text
07/18/2024/19:37:30.661000000 cm_analyze: Source: 'C:\Muxing\500.Days.of.Summer.2009.WEB-DL.2160p.HDR.mov'
07/18/2024/19:37:30.661000000 cm_analyze: Master Display: 1000-nit, BT.2020, D65, ST.2084, Full
07/18/2024/19:37:30.661000000 cm_analyze: Src Info: '3840x2160x3 u16 interleaved 422 le tight 0-136841 23.976fps top_left pq ycbcr_bt2020 video bt2020'
07/18/2024/19:37:30.661000000 cm_analyze: Frames: 0 - 136841
07/18/2024/19:37:30.661000000 cm_analyze: Frame rate: 24000/1001
07/18/2024/19:37:30.661000000 cm_analyze: Algorithm Version: 4
07/18/2024/19:37:30.661000000 cm_analyze: XML Version: 4.0.2
07/18/2024/19:37:30.669000000 cm_analyze: Metadata aspect ratios: canvas 1.777778e+00, image 2.400000e+00
07/18/2024/19:37:30.670000000 cm_analyze: setting letterbox to (0,280,0,280) based on aspect ratios
07/18/2024/19:37:30.671000000 cuda: initializing CUDA
07/18/2024/19:37:30.747000000 cuda: using CUDA version 9.2.0
07/18/2024/19:37:30.747000000 cuda: NVIDIA GeForce RTX 3060: compute 8.6, cores 3584*1837MHz, memory 12287MB
Frame 18070 complete. Last frame: 0.040 seconds. ETA: 6:18:13.280-
yeah, I have the same issue on my Windows 11 PC. I can no longer use cm_analyze, it crashes after about 10 minutes.
Are you on Windows 11? I spent a couple of hours trying to debug it and nothing worked so I suspect a recent Win11 update caused this bug because I'm using the same Nvidia drivers on my Windows 10 PC and there's no issue.
PS: You should use madVR instead anyway, it will be 10 times faster, and no need to convert to prores.
Yup, I'm using Windows 11 latest release:RESET_9999 wrote: ↑Thu Jul 18, 2024 7:01 pmyeah, I have the same issue on my Windows 11 PC. I can no longer use cm_analyze, it crashes after about 10 minutes.
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.22631 N/A Build 22631
How can I use MadVR to do that?
you measure HDR with madMeasureHDR.exe and it will tell you maxcll/fall. You can also use workflow 6-2 in dovi_scripts which use madvr.
madMeasureHDR.exe input.mkv
Thanks for the info. I'll use your script so that I can exclude black bars from the measurements.RESET_9999 wrote: ↑Thu Jul 18, 2024 7:53 pmyou measure HDR with madMeasureHDR.exe and it will tell you maxcll/fall. You can also use workflow 6-2 in dovi_scripts which use madvr.
madMeasureHDR.exe input.mkv![]()
After trying I get this error:RESET_9999 wrote: ↑Thu Jul 18, 2024 7:53 pmyou measure HDR with madMeasureHDR.exe and it will tell you maxcll/fall. You can also use workflow 6-2 in dovi_scripts which use madvr.
Drag and drop folder with HEVC video files or a single file and press enter...C:\Muxing\500.Days.of.Summer.2009.WEB-DL.2160p.HDR.mkv
Do you want to exclude the letterbox? y or n and press enter... Cropping helps with MaxFALL accuracy but makes the process slower (3x) (default=n) MUST BE MOD2
y
Right border pixels offset...
0
Left border pixels offset...
0
Top border pixels offset...
280
Bottom border pixels offset...
280
Connecting LAV Video Decoder to madVR failed.
Reading generate config file...
Parsing madVR measurement file...
Error: The system cannot find the file specified. (os error 2)
