I was running version 1.7.2 of makemkv, I started getting errors on some titles in my collection of some older titles.
The Last Witch Hunter, gives the following error, the last error line is almost instant after the previous IFO file error (no more than 1 second later).
Using LibreDrive mode (v01.0 id=388F93C712C1)
Calculated BUP offset for VTS #0 does not match one in IFO header.
IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Chain reaction ( the movie )
This movie will scan the disc, it will pause 0n css block 11 for what seams like a whole minute, it then says completed. If you then save the movie file it gets errors at approximately 2.8 gig. it gives a long list of audio sync errors, it also informs no more errors will be shown , but listed to the log file.
Both of these titles will play without issues, in the same drive in VLC player, on the same computer, I have tried to use my second drive (does not support the libre drive mode, and runs in the old way) with the same results. I upgraded to makemkv 1.7.3 today, This issue still persists.
Both disks i have tried cell walk, cell trim, cell full and auto modes in the settings, with no difference in outcome.
Due to the nature of makemkv beta, I am unable to test in any older versions to see if this is a recent thing or always been there.
best regards
Simon
Makemkv 1.7.2 & 1.7.3 possible bug, Help required
Re: Makemkv 1.7.2 & 1.7.3 possible bug, Help required - updated Information
Just additional information, should the developers/ other users require it. The disk plays fine in VLC player on both drives.The logs for both drives are listed below.
DVD Drive
Debug log started at Tue Feb 14 15:56:34 2023 , written by MakeMKV v1.17.3 win(x64-release)
001005:0000 MakeMKV v1.17.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\User/MakeMKV_log.txt
DEBUG: Code 3 at 'W5#or0UspRy]J7I('S_3yx3:29395310
SDF v097: PIONEER_BD-RW___BDR-209M_1.51_RHDL004044WL
No SDF v097: ASUS_DRW-24D5MT_2.00_201906171049_KM3K4TN2738
No auto SDF v097: ASUS_DRW-24D5MT_2.00_201906171049_KM3K4TN2738
DEBUG: Code 0 at 1fI2{<myXyWw7=irX:29396253
DEBUG: Code 0 at [zsJFhLiL.aL`&tD:213136746
SDF id v097: ASUS_DRW-24D5MT_2.00_201906171049_KM3K4TN2738
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
001003:0020 DEBUG: Code 0 at !S4-YvF<W=Zk-9:29400071
003042:0000 IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
001003:0020 DEBUG: Code 0 at K,F0DC8hc8=#1mSmB:121262854
Blu-ray drive
Debug log started at Tue Feb 14 15:48:46 2023 , written by MakeMKV v1.17.3 win(x64-release)
001011:0000 Using LibreDrive mode (v01.0 id=388F93C712C1)
Best regards
Simon
DVD Drive
Blu-ray drive
Best regards
Simon
Re: Makemkv 1.7.2 & 1.7.3 possible bug, Help required... SOLVED !!!
This issue is now solved...
The Last Witch hunter
This title Has Disney X Project Protection on it, Basically has 99 titles and obscures the correct title for the main movie file Etc. This was an issue with MakeMKV not fully supporting the Disney X Project protection Method.
Chain Reaction
This title needed to be treated as a file and NOT a DVD disk, This is something that MakeMKV doesn't support, It reads Discs NOT Files.
Both of These Issues were fixed by alternate software that was purchased on the internet.
(The name of the software has been withheld as it's rival software and i don't want to promote other pieces of software on the MakeMKV forum.
Best regards
Simon
Chain Reaction
Best regards
Simon
Hi
I had similar problem with Chain Reaction, i bought a second copy with the same results
I posted on redit
https://www.reddit.com/r/makemkv/commen ... n_makemkv/
I'm unable to private message atm @BritishBoy1967 as im a new member, but i'd really like to jump to the end and find out how to get this movie in the DONE pile
If anyone could point me in the right direction i would be very happy thnx
All the best
Andy
I posted on redit
All the best
Andy
