List of DVD/BluRay that haven't worked
Marc_G
Re: List of DVD/BluRay that haven't worked
Post by Marc_G » Sun Aug 09, 2009 7:46 pm
Hi folks,
I had a problem with Battlestar Galactica Season 4.5 Disk 3 BluRay region 1. I was able to extract the first episode on the disk, and the final one (which was an extra-length version of the content), but the middle episode, which is a double-length 2 hour special consistently fails. Here's the log trace:
005014:000000:0000 Saving 1 titles into directory F:/Video/Battlestar_Galactica_Season_4_5_(Disc_3)
001012:000000:0020 FAILURE: Code 4 at *"MQ'hY%B{%6F^dgmsO:29396644
001012:000000:0020 FAILURE: Code 3 at *"MQ'hY%B{%6F^dgmsO:29396644
001011:000000:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: frame->timecode>=cluster_timecode
005003:000000:0000 Failed to save title 3 to file F:/Video/Battlestar_Galactica_Season_4_5_(Disc_3)/title03.mkv
Interestingly, in the titles list, it seems to show up twice. Once with just a size (15.9 GB) and once with the size and note that it has 7 chapters (7Chapters, 15.9 GB).
I'm running AnyDVDHD 6.5.7.4 (and had the same problem on the prior released version). Running Make MKV 1.4.6 on W7 RC 7100 32 bit. The disk is mounted in Virtual Clone Drive; was ripped with AnyDVDHD leaving protection intact.
Haven't had any other problems in 1.4.6 of MakeMKV. Great program!
Any thoughts about the above problem?
Marc
dennis
Post by dennis » Tue Aug 11, 2009 7:14 am
I just tried master and commander
The mkv file had no chapters
farmwald
Post by farmwald » Wed Aug 12, 2009 1:25 pm
Serenity still fails with 1.4.6
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file R:/Video/Serenity/title00.mkv
kevinbal
Post by kevinbal » Mon Aug 17, 2009 4:29 pm
I've been fighting all day with the US Blu-ray release of Ratatouille. It scans the disc fine, picks up the titles, but when I select the main title track for MKV creation, the process is very long and it seems to be bouncing from stream to stream with no rhyme or reason. Halfway through, it fails. I tried Title #11, 12 and 13 which are all the main feature from, presumably, 3 different angles.
This is the first BD that I've come across (that wasn't BD+) that I couldn't deal with.
[EDIT by Mike]: this is very likely physical disc error. To confirm please provide the full log ( /Users/kevinbal/MakeMKV_log.txt ) as it has additional information.
Bling2Ming
Post by Bling2Ming » Wed Aug 19, 2009 6:24 pm
Disney BOLT Region 2 UK DVD. Failed to create file.
Debug log started at Wed Aug 19 18:00:58 2009 , written by MakeMKV v1.4.6 beta linux(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta linux(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /home/bling2ming/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at vw$%uML@XF}?OmV:#0u_:213130720
001012:000000:0020 FAILURE: Code 0 at tn`I97}Nqrt:Xy]:121261911
003010:000000:0000 Using direct disc access mode
003002:003011:0010 Calculated BUP offset does not match one in IFO header.
003028:000000:0000 Cell 1 was discarded (structure protection?)
001012:000000:0020 FAILURE: Code 0 at }+]8?[`.GEx;g$X:213130835
003032:000000:0000 CellWallk algorithm failed (structure protection is too though?), trying CellTrim algorithm
003047:000000:0000 Fake cells occupy 70% of the title - assuming fake title
003037:000000:0000 Title #0 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 69% of the title - assuming fake title
003037:000000:0000 Title #1 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 68% of the title - assuming fake title
003037:000000:0000 Title #2 (0:00:00) was skipped
003037:000000:0000 Title #3 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 67% of the title - assuming fake title
003037:000000:0000 Title #4 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 66% of the title - assuming fake title
003037:000000:0000 Title #5 (0:00:00) was skipped
003037:000000:0000 Title #6 (0:00:00) was skipped
003037:000000:0000 Title #7 (0:00:00) was skipped
003037:000000:0000 Title #8 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 61% of the title - assuming fake title
003037:000000:0000 Title #9 (0:00:00) was skipped
003037:000000:0000 Title #10 (0:00:00) was skipped
003037:000000:0000 Title #11 (0:00:00) was skipped
003037:000000:0000 Title #12 (0:00:00) was skipped
003037:000000:0000 Title #13 (0:00:00) was skipped
003037:000000:0000 Title #14 (0:00:00) was skipped
003037:000000:0000 Title #15 (0:00:00) was skipped
003037:000000:0000 Title #16 (0:00:00) was skipped
003037:000000:0000 Title #17 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 72% of the title - assuming fake title
003037:000000:0000 Title #18 (0:00:00) was skipped
003037:000000:0000 Title #19 (0:00:00) was skipped
003037:000000:0000 Title #20 (0:00:00) was skipped
003037:000000:0000 Title #21 (0:00:00) was skipped
003037:000000:0000 Title #22 (0:00:00) was skipped
003037:000000:0000 Title #23 (0:00:00) was skipped
003037:000000:0000 Title #24 (0:00:00) was skipped
003037:000000:0000 Title #25 (0:00:00) was skipped
003037:000000:0000 Title #26 (0:00:00) was skipped
003037:000000:0000 Title #27 (0:00:00) was skipped
003037:000000:0000 Title #28 (0:00:00) was skipped
003034:000000:0000 Cells 1-10 were removed form title start
003035:000000:0000 Cells 82-82 were removed form title end
001003:000000:0020 DBG ASSERT: -&nLl7s s2V6V"zMnFGAcbhBJKFUcp|( @e5W]Ij%h5bn/| at `Tib{DH]&7:RR}f':121261405
003019:003000:0010 Wrong Angles count in angle block around cell 11 , 2 (title) != 1 (pgc)
003046:000000:1000 Complex multiplex encountered - 18 cells and 913 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003036:000000:0000 Title #29 was added (54 cell(s), 1:29:44)
003046:000000:1000 Complex multiplex encountered - 18 cells and 910 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003048:000000:0000 Angle #2 was added for title #29
003037:000000:0000 Title #30 (0:00:00) was skipped
003037:000000:0000 Title #31 (0:00:00) was skipped
003037:000000:0000 Title #32 (0:00:00) was skipped
003037:000000:0000 Title #33 (0:00:00) was skipped
003037:000000:0000 Title #34 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 65% of the title - assuming fake title
003037:000000:0000 Title #35 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 55% of the title - assuming fake title
003037:000000:0000 Title #36 (0:00:00) was skipped
003037:000000:0000 Title #37 (0:00:00) was skipped
003037:000000:0000 Title #38 (0:00:00) was skipped
003037:000000:0000 Title #39 (0:00:00) was skipped
003037:000000:0000 Title #40 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 62% of the title - assuming fake title
003037:000000:0000 Title #41 (0:00:00) was skipped
003037:000000:0000 Title #42 (0:00:00) was skipped
003037:000000:0000 Title #43 (0:00:00) was skipped
003037:000000:0000 Title #44 (0:00:00) was skipped
003037:000000:0000 Title #45 (0:00:00) was skipped
003037:000000:0000 Title #46 (0:00:00) was skipped
003037:000000:0000 Title #47 (0:00:00) was skipped
003037:000000:0000 Title #48 (0:00:00) was skipped
003037:000000:0000 Title #49 (0:00:00) was skipped
003037:000000:0000 Title #50 (0:00:00) was skipped
003037:000000:0000 Title #51 (0:00:00) was skipped
003037:000000:0000 Title #52 (0:00:00) was skipped
003037:000000:0000 Title #53 (0:00:00) was skipped
003037:000000:0000 Title #54 (0:00:00) was skipped
003037:000000:0000 Title #55 (0:00:00) was skipped
003037:000000:0000 Title #56 (0:00:00) was skipped
003037:000000:0000 Title #57 (0:00:00) was skipped
003037:000000:0000 Title #58 (0:00:00) was skipped
003037:000000:0000 Title #59 (0:00:00) was skipped
003037:000000:0000 Title #60 (0:00:00) was skipped
003037:000000:0000 Title #61 (0:00:00) was skipped
003020:000000:0000 Title #62 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003014:000000:0000 Title #63 with special attributes was skipped
003014:000000:0000 Title #64 with special attributes was skipped
003020:000000:0000 Title #65 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #66 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003014:000000:0000 Title #67 with special attributes was skipped
003014:000000:0000 Title #68 with special attributes was skipped
003014:000000:0000 Title #69 with special attributes was skipped
003014:000000:0000 Title #70 with special attributes was skipped
003014:000000:0000 Title #71 with special attributes was skipped
003014:000000:0000 Title #72 with special attributes was skipped
003014:000000:0000 Title #73 with special attributes was skipped
003014:000000:0000 Title #74 with special attributes was skipped
003014:000000:0000 Title #75 with special attributes was skipped
003014:000000:0000 Title #76 with special attributes was skipped
003014:000000:0000 Title #77 with special attributes was skipped
003014:000000:0000 Title #78 with special attributes was skipped
003014:000000:0000 Title #79 with special attributes was skipped
003014:000000:0000 Title #80 with special attributes was skipped
003014:000000:0000 Title #81 with special attributes was skipped
003014:000000:0000 Title #82 with special attributes was skipped
003014:000000:0000 Title #83 with special attributes was skipped
003020:000000:0000 Title #84 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #85 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #86 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003014:000000:0000 Title #87 with special attributes was skipped
003020:000000:0000 Title #88 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #89 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #90 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003014:000000:0000 Title #91 with special attributes was skipped
003014:000000:0000 Title #92 with special attributes was skipped
003014:000000:0000 Title #93 with special attributes was skipped
003014:000000:0000 Title #94 with special attributes was skipped
003014:000000:0000 Title #95 with special attributes was skipped
003020:000000:0000 Title #96 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #97 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #98 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /home/graham/Videos/BOLT_GBR
001012:000000:0020 FAILURE: Code 2 at }CXkL0'L.x?A07hj:213135251
SD=ZeNr7wMDMwJkpwMUABEwgguHJdkYGCPgS/3S79oIn27+02nD8BwKQGEgOxAex3wBpAPc9EZ8=
001012:000000:0020 FAILURE: Code 4294967276 at 4r87>S?R 59FwA*^:121267270
SD=ZeNr7wMDMwJnpwMUABEwgguHJdkYGCPgS/3S79oIn2ye02nD8BwKQGEgOxAexO4A0APDtEKM=
SD=ZeNr7wMDMwJnpwMUABEwgguHJdkYGCPgS/3S79oIn27+02nD8BwKQGEgOxAex3wBpAAIsEc8=
SD=ZeNr7wMDMwJmZwMUABEwgguHJdkYGCPgS/3S79oIn2ye02nD8BwKQGEgOxAexO4A0APgtEMM=
001012:000000:0020 FAILURE: Code 0 at 4r87>S?R 59FwA*^:213134837
SD=ZeNr7wMDMwJm5gYsBCJhABMOT7YwMEPAl/ul27QVPtk9oteH4DwQgMZAciA9idwBpAApcERM=
SD=ZeNr7wMDMwJm5gYsBCJhABMOT7YwMEPAl/ul27QVPtn9pteH4DwQgMZAciA9ivwHSABuMEj8=
001012:000000:0020 FAILURE: Code 4294967276 at I9*Yr:JZOH3Em~kgcG:29394068
001012:000000:0020 FAILURE: Code 4294967276 at I9*Yr:JZOH3Em~kgcG:121262601
001012:000000:0020 FAILURE: Code 4294967276 at I9*Yr:JZOH3Em~kgcG:29394597
002010:000000:0000 Read error. Sector=608978
001012:000000:0020 FAILURE: Code 0 at &]5~,@Xj%*Fx\nzbFjgB:121262509
001012:000000:0020 FAILURE: Code 0 at #5T-Rzng[rz)Yomw(@*:29393470
001012:000000:0020 FAILURE: Code 0 at &]5~,@Xj%*Fx\nzbFjgB:121262164
001012:000000:0020 FAILURE: Code 7902 at &]5~,@Xj%*Fx\nzbFjgB:213129639
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file /home/bling2ming/Videos/BOLT_GBR/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Edit: Played back DVD in a hardware dvd player and checked the title number of main feature whilst it was playing. This was title 30 of 99 not title 29 as selected by Mkvmerge. A now common Disney protection ploy is to flood the dvd with lots of titles of approximately the same length. An option to open a specific title number would be nice.
gelyon
Post by gelyon » Thu Aug 20, 2009 12:30 am
David Gilmour - Remember That Night (2007) Blu Ray
Audio and video out of sync.
I have tried using eac3to and mkvmerge also, I just can't get them to sync. Any ideas?
Video: VC-1
Audio #1: PCM
Audio #2: AC-3 TrueHD
[EDIT] I came back to this and found that it's only on Windows Media Player that the audio and video are out of sync. It works fine on my WD TV HD. I always test my new videos on Windows Media Player (Windows 7) and this is the first one that doesn't work correctly on WMP and does work correctly on WD TV HD. So, Windows Media Player is not a reliable test.
NomadCF
Post by NomadCF » Thu Aug 20, 2009 2:36 am
Try tsmuxer and convert the MKV to a TS or m2ts and see how that plays. The conversion is on the container and not the "streams" so there is no quality loss and it only takes ~45 seconds.
gelyon
Post by gelyon » Mon Aug 24, 2009 3:11 am
Thanks, with tsMuxeR, creating a TS file, the audio and video are in sync.
[edit] But, no chapters with the TS file. :( With a concert video like this it's really nice to have chapters.
If I demux with tsMuxeR and mux with mkvmerge the audio and video are out of sync.
[EDIT] See the edit in my post above.
arelless
Post by arelless » Mon Aug 24, 2009 2:57 pm
Dumbo, 60th Anniversary Edition DVD - Program crashes with "Fatal error occured, programm will now exit."
Debug log started at Mon Aug 24 14:53:45 2009 , written by MakeMKV v1.4.6 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as *********
003028:000000:0000 Cell 28 was discarded (structure protection?)
003046:000000:1000 Complex multiplex encountered - 3 cells and 778 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003036:000000:0000 Title #0 was added (21 cell(s), 1:03:31)
003046:000000:1000 Complex multiplex encountered - 3 cells and 779 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003048:000000:0000 Angle #2 was added for title #0
003046:000000:1000 Complex multiplex encountered - 3 cells and 780 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003048:000000:0000 Angle #3 was added for title #0
003014:000000:0000 Title #1 with special attributes was skipped
003020:000000:0000 Title #2 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #3 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:000000:0000 Cell 2 was discarded (structure protection?)
003036:000000:0000 Title #4 was added (1 cell(s), 0:02:53)
003036:000000:0000 Title #5 was added (1 cell(s), 0:14:50)
003020:000000:0000 Title #6 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #7 was added (1 cell(s), 0:05:57)
003020:000000:0000 Title #8 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #9 was added (1 cell(s), 0:02:52)
003036:000000:0000 Title #10 was added (1 cell(s), 0:09:21)
003036:000000:0000 Title #11 was added (1 cell(s), 0:08:31)
003036:000000:0000 Title #12 was added (1 cell(s), 0:02:35)
003036:000000:0000 Title #13 was added (1 cell(s), 0:02:33)
003020:000000:0000 Title #14 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #15 was added (1 cell(s), 0:02:12)
003020:000000:0000 Title #16 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #17 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #18 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #19 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #20 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #21 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003026:000000:0000 Jumped to cell 2 from cell 2 due to cell commands (structure protection?)
003027:000000:0000 Loop detected. Possibly due to unknown structure protection.
kevinbal
Post by kevinbal » Mon Aug 24, 2009 3:42 pm
kevinbal wrote:I'
It's actually not, I did some research and Ratatouille BD uses a very complex stream order (presumably to prevent this type of action). I was able to eventually rip it out with a different program and arrange the streams in the correct order, but the audio sync was a huge issue. This disc is an exception to the norm, but one to be weary of for future discs.
kevinbal
Post by kevinbal » Sun Sep 06, 2009 9:15 pm
Encountered my second failure so far, US Blu-ray release of Star Trek VI: The Undiscovered Country. Progresses about 4/5ths of the way through and has a critical failure that shuts down the application.
Debug log started at Sun Sep  6 20:23:37 2009 , written by MakeMKV v1.4.6 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/kevinbal/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at 5!|TVt[rO5U5)pPf^;C,+'S{&os:121264878
DISCID=0C4CE675250413A76713DE79A7D62DD4D121FCBE
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00034
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00035
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00036
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00037
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00042
003316:000000:0000 Only extracting AC3 core audio from stream #1 of type 'DD True HD audio' in file 00040.m2ts
003313:000000:0000 File 00043.mpls was added as title #0
003313:000000:0000 File 01000.mpls was added as title #1
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00200
003313:000000:0000 File 01001.mpls was added as title #2
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00039
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00040
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00041
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00038
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00047
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00201
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00048
003020:000000:0000 Title #00001.mpls has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00003
003314:000000:0000 Title 00100.mpls is equal to title 00043.mpls and was skipped
003314:000000:0000 Title 00101.mpls is equal to title 00043.mpls and was skipped
003020:000000:0000 Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00003.m2ts was added as title #3
003313:000000:0000 File 00004.m2ts was added as title #4
003313:000000:0000 File 00005.m2ts was added as title #5
003313:000000:0000 File 00006.m2ts was added as title #6
003313:000000:0000 File 00007.m2ts was added as title #7
003313:000000:0000 File 00008.m2ts was added as title #8
003313:000000:0000 File 00009.m2ts was added as title #9
003313:000000:0000 File 00010.m2ts was added as title #10
003313:000000:0000 File 00011.m2ts was added as title #11
003313:000000:0000 File 00012.m2ts was added as title #12
003313:000000:0000 File 00013.m2ts was added as title #13
003313:000000:0000 File 00014.m2ts was added as title #14
003313:000000:0000 File 00015.m2ts was added as title #15
003313:000000:0000 File 00016.m2ts was added as title #16
003313:000000:0000 File 00017.m2ts was added as title #17
003313:000000:0000 File 00018.m2ts was added as title #18
003313:000000:0000 File 00019.m2ts was added as title #19
003313:000000:0000 File 00020.m2ts was added as title #20
003313:000000:0000 File 00021.m2ts was added as title #21
003313:000000:0000 File 00022.m2ts was added as title #22
003313:000000:0000 File 00023.m2ts was added as title #23
003313:000000:0000 File 00024.m2ts was added as title #24
003313:000000:0000 File 00025.m2ts was added as title #25
003313:000000:0000 File 00026.m2ts was added as title #26
003313:000000:0000 File 00027.m2ts was added as title #27
003020:000000:0000 Title #00028.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00029.m2ts was added as title #28
003313:000000:0000 File 00030.m2ts was added as title #29
003020:000000:0000 Title #00113.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00114.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00115.m2ts was added as title #30
003020:000000:0000 Title #00001.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00002.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:000000:0000 Saving 1 titles into directory /Users/kevinbal/Desktop
001012:000000:0020 FAILURE: Code 2 at vjY="(Q03+A<Z/?d:213135251
001012:000000:0020 FAILURE: Code 4294967276 at Xf2^'gJ5Fdafm]lM:121267270
001012:000000:0020 FAILURE: Code 0 at Xf2^'gJ5Fdafm]lM:213134837
001012:000000:0020 FAILURE: Code 4294967276 at 0xIw=2VR4.QvJZ#amg:29394068
001012:000000:0020 FAILURE: Code 4294967276 at 0xIw=2VR4.QvJZ#amg:121262601
001012:000000:0020 FAILURE: Code 4294967276 at 0xIw=2VR4.QvJZ#amg:29394597
002007:000000:0000 Read error. File="<n/a>" Info=""
001012:000000:0020 FAILURE: Code 0 at J]U1Lj-[9O?|d5oJz~9T:121262509
001012:000000:0020 FAILURE: Code 0 at &,T}}<#'5}m65I]X7fHP:121262049
001012:000000:0020 FAILURE: Code 0 at J]U1Lj-[9O?|d5oJz~9T:121262164
001012:000000:0020 FAILURE: Code 10618015 at J]U1Lj-[9O?|d5oJz~9T:213129639
Edit: After a lot of research and then booting into windows, I've found out that this uses MKBv12 and from what I gather, can't be decrypted by either makemkv or dumphd at this time. :)
Methelys
Post by Methelys » Fri Sep 11, 2009 5:43 pm
Well I was looking forward to ripping my 250+ DVD collection... Out of the first 7... 3 of those caused "Fatal Error" from bad sectors.
Electra - Widescreen (024543182641) <-- Bar Code to look up :)
Paycheck - Widescreen (097363380344)
Driven - Widescreen (085392101320)
Suggestions Welcome. I am using 1.4.6 Beta
cayether
Post by cayether » Fri Sep 11, 2009 6:08 pm
Using MakeMKV v1.4.6 beta windows
with AnyDVD HD 6.5.4.9 activated
Harry Potter 1 EU Zone
Error log :
005014:000000:0000 Saving 1 titles into directory W:/DVD Iso
001012:000000:0020 FAILURE: Code 2 at o9KTzxA0Z`r$,p]y:213135251
SD=ZeNorYGBiAAIuEGEFIhgWSByY1VzDodZQ8x8IGIC0k2pDTQ87AwOYDwRb/i+QeO3lwPAPiAEtgRVq
001012:000000:0020 FAILURE: Code 4294967276 at ]'"ECb(.):V?I4|m:121267270
001012:000000:0020 FAILURE: Code 0 at ]'"ECb(.):V?I4|m:213134837
001012:000000:0020 FAILURE: Code 4294967276 at lqVh3D([=AJ(T=he!3:29394068
001012:000000:0020 FAILURE: Code 4294967276 at lqVh3D([=AJ(T=he!3:121262601
001012:000000:0020 FAILURE: Code 4294967276 at lqVh3D([=AJ(T=he!3:29394597
001012:000000:0020 FAILURE: Code 0 at QW.:v(HC[49&%g[k~]\a:121262509
001012:000000:0020 FAILURE: Code 0 at &tpe]+P%hhD}LbAlPwYx:121262049
001012:000000:0020 FAILURE: Code 0 at QW.:v(HC[49&%g[k~]\a:121262164
001012:000000:0020 FAILURE: Code 8507680 at QW.:v(HC[49&%g[k~]\a:213129639
005003:000000:0000 Failed to save title 0 to file W:/DVD Iso/title00.mkv
kevinbal
Post by kevinbal » Sat Sep 19, 2009 1:38 pm
Here's another Blu-ray - Rocky Balboa, US release.
Debug log started at Sat Sep 19 13:14:11 2009 , written by MakeMKV v1.4.6 beta darwin(x86-release)
DISCID=DC9FAF986C73C747AD1497E6D102F057A4CF854D
003020:000000:0000 Title #00033.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00051.mpls was added as title #0
003020:000000:0000 Title #00082.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00084.mpls was added as title #1
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00073
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00074
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00075
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00076
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00077
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00078
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00079
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00080
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00081
003020:000000:0000 Title #00032.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00033.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00034.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00045.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00046.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00050.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00053.m2ts was added as title #2
003313:000000:0000 File 00054.m2ts was added as title #3
003313:000000:0000 File 00055.m2ts was added as title #4
003020:000000:0000 Title #00056.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00057.m2ts was added as title #5
003313:000000:0000 File 00058.m2ts was added as title #6
003313:000000:0000 File 00059.m2ts was added as title #7
003313:000000:0000 File 00060.m2ts was added as title #8
003313:000000:0000 File 00061.m2ts was added as title #9
003020:000000:0000 Title #00062.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00063.m2ts was added as title #10
003313:000000:0000 File 00064.m2ts was added as title #11
003313:000000:0000 File 00065.m2ts was added as title #12
003313:000000:0000 File 00066.m2ts was added as title #13
003020:000000:0000 Title #00067.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00068.m2ts was added as title #14
003313:000000:0000 File 00069.m2ts was added as title #15
003313:000000:0000 File 00070.m2ts was added as title #16
003020:000000:0000 Title #00071.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00074.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00075.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00076.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005001:000000:0308 File /Users/kevinbal/Desktop/title00.mkv already exist. Do you want to overwrite it?
005002:000000:0000 Title 0 skipped
005005:000000:0000 0 titles saved
005036:000000:0104 Copy complete. 0 titles saved.
001012:000000:0020 FAILURE: Code 0 at &,T}}<#'5}m65I]X7fHP:213130053
001012:000000:0020 FAILURE: Code 3823296 at J]U1Lj-[9O?|d5oJz~9T:213129639
kevinbal
Post by kevinbal » Tue Sep 22, 2009 10:20 pm
And another... quite a string I have going here - Sin City, US Blu-ray release
Debug log started at Tue Sep 22 22:06:19 2009 , written by MakeMKV v1.4.6 beta darwin(x86-release)
DISCID=650C74CBEC59121764AD0135ECF52E38DBA01F6B
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00111
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00110
003313:000000:0000 File 00098.mpls was added as title #0
003313:000000:0000 File 00099.mpls was added as title #1
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00614.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00553.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00488.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00554.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00490.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00555.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00492.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00556.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00494.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00557.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00496.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00558.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00498.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00559.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00583.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00560.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00504.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00561.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00506.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00562.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00563.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00510.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00564.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00512.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00565.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00514.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00566.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00516.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00567.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00518.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00551.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00568.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00521.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00569.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00523.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00570.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00525.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00571.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00572.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00529.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00573.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00613.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00574.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00533.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00575.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00536.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00576.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00538.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00577.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00540.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00578.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00542.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00579.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00544.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00580.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00546.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00581.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00548.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00582.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00550.m2ts
003313:000000:0000 File 00002.mpls was added as title #2
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00487.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00489.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00491.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00493.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00495.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00497.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00499.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00503.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00505.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00585.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00509.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00511.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00513.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00515.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00517.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00520.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00522.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00524.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00586.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00528.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00530.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00532.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00552.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00537.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00539.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00541.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00543.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00545.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00547.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00549.m2ts
003313:000000:0000 File 00001.mpls was added as title #3
003020:000000:0000 Title #00589.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001012:000000:0020 FAILURE: Code 1 at 'PZL$m(iSJv5QPXe1T`:29396644
001012:000000:0020 FAILURE: Code 188896 at J]U1Lj-[9O?|d5oJz~9T:213129639
