Recommendation for best (most reliable and versatile) LibreDrive for 2024?
avaio
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Post by avaio » Wed Jul 03, 2024 7:19 am
Coopervid wrote: Tue Jul 02, 2024 10:16 pm
avaio wrote: Tue Jul 02, 2024 7:27 pm Can I get a recommendation for Ireland, please?
5,25 or slim external? Check with asmcom if you want a ready-to-work drive.
Preferably external drive and ideally in EU. Since Brexit there is extra tax for shipping from UK (where I believe asmcom ships from :) to Ireland. Thanks a lot!
Okona
Post by Okona » Wed Jul 03, 2024 7:37 am
Coopervid wrote: Tue Jul 02, 2024 10:14 pm
You need to have access to a Windows PC to make it work.
You mean for the flashing? That can be arranged.
Post by Coopervid » Wed Jul 03, 2024 8:02 am
Okona wrote: Wed Jul 03, 2024 7:37 am
PM sent.
Post by Coopervid » Wed Jul 03, 2024 8:07 am
avaio wrote: Wed Jul 03, 2024 7:19 am
Buy a Verbatim 43888 if available in Ireland. The only drawback is that it is power hungry and doesn't work on all USB3 ports. Otherwise get one from Asmcom. He is located in Northern Ireland and so no duty applies to shipments to you or in the whole EU.
Goddy294
Post by Goddy294 » Fri Jul 05, 2024 7:25 am
Awesome work here.
I need two recommendations for Germany/Europe:
1) external slimline BluRay burner USB-C (ideally supporting the burning of M-Discs)
2) 5,25 internal BluRay burner SATA
Thx a lot.
Post by Coopervid » Fri Jul 05, 2024 9:22 am
Goddy294 wrote: Fri Jul 05, 2024 7:25 am Awesome work here.
Thx a lot.
PM sent.
Justus
Post by Justus » Fri Jul 05, 2024 7:29 pm
Hello everyone,
I'm looking for a recommendation for a drive. Unfortunately, the WH14NS40 and WH16NS40 models are currently unavailable in my region (EU/Germany). Can anyone suggest an alternative?
Thanks in advance!
Headbanger
Post by Headbanger » Sun Jul 07, 2024 7:26 am
My Pioneer drive arrived from Amazon last night. I’ll be installing it my PC later today.
HB
Headbanger
Post by Headbanger » Sun Jul 07, 2024 10:23 am
Just installed and flashed the new Pioneer drive and I’m up and running again after my old ASUS drive had failed.
@Coopervid - thank you again.
HB
Grunthos
Post by Grunthos » Mon Jul 08, 2024 1:23 pm
Like many others I am looking for a reliable UHD drive for use with LibreDrive. Australia-based; happy to order from most places.
Post by Coopervid » Mon Jul 08, 2024 6:53 pm
dos0711 wrote: Sat Jun 29, 2024 2:24 pm Could I get a recommendation for USA? Internal and normal size.
PM deleted since not read within a week.
thesexychicken
Post by thesexychicken » Mon Jul 08, 2024 9:16 pm
I'm in USA would love an option or 2, would like to run with mbp externally usb c preferrably. thanks!
Greg74378
Post by Greg74378 » Fri Jul 12, 2024 10:05 am
Looking for a reliable UHD drive (5.25" windows) for use with LibreDrive to backup my Bluray Ultra HDs. Situated in Canada - can order from most places. Any suggestions would be greatly appreciated.
Quester
Post by Quester » Sat Jul 13, 2024 12:42 pm
I also need some recommendations for Europe/Germany.
I already have some LG 5 1/4" SATA Drives I flashed to Libres some years ago and find it a good idea to update my stock :-)
Intention: ripping HD & UHD BD.
Thanks für suggestions.
Trixter
Post by Trixter » Sat Jul 13, 2024 11:53 pm
I currently am on my second ASUS BW-16D1HT, and it's starting to break down in the same way the first one did: After about 80-100 rips, it is doing excessive seeking, drive spinup/down, etc. so I guess I've "used it up" just like the first one. (The previous one died so hard it took a disc with it, gouging grooves into the disc and ruining it.)
I want a reliable internal SATA drive for BD and UHD rips. Ripping speed is not my primary concern; reliability is. Based on reading this thread, Pioneer is the best for this? I'm in the USA, is there a recommended model as of this posting (July 2024) I should get?
