Game of Thrones Season 3
MarkDinger
Post by MarkDinger » Thu Jul 04, 2024 3:51 pm
Hi there everyone I'm having issue with copying GOT season3 Disk 1,for some reason I will not save episode 1 but save episode 2 fine. This is a copy of the error I get.
Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
Title #1 was added (10 cell(s), 0:52:14)
Title #2 was added (9 cell(s), 0:54:42)
Title #3 was added (18 cell(s), 1:46:56)
Title #4 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #10 was added (2 cell(s), 0:10:01)
Title #11 has length of 582 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #12 was added (2 cell(s), 0:14:02)
Title #20 has length of 211 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #21 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 2 titles into directory F:/MakeMKV
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '220964864'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '220964864'
DEBUG: Code 3221225628 at 8)gN3IM7_1@BG-`Ird:213131502
DEBUG: Code 100864261 at 8)gN3IM7_1@BG-`Ird:213131502
DEBUG: Code 0 at xx_1Yp) 'ks"/5TmZCmq:29395471
Re: Game of Thrones Season 3
Post by dcoke22 » Fri Jul 05, 2024 3:55 am
Messages like that indicate that the drive was unable to correctly read that spot on the disc. Usually this means the disc is dirty or there's a scratch that can't be overcome. The standard advice is to gently clean the disc and try again.
MarkDinger
Post by MarkDinger » Fri Jul 05, 2024 5:44 am
Thank you for replying, after having a closer look at the disk I have noticed a light scratch on it. not sure if I can buff/ polish it out but will give it a go
