"Fake playlist" protection - help needed
Re: "Fake playlist" protection - help needed
Post by dcoke22 » Thu Jun 06, 2024 10:54 pm
HarryKleins wrote:
Thu Jun 06, 2024 10:49 pm
What is the "fake playlist"?
I am new to this. Thank you for your understanding.
You'll have found a disc with it if you try to rip a movie that seems to have several hundred copies of the movie on it.
HarryKleins
Post by HarryKleins » Thu Jun 06, 2024 11:04 pm
OK, I see. So out of this hundred lists of films, only one would be correct?
What are the others empty shells?
Post by dcoke22 » Thu Jun 06, 2024 11:12 pm
Yes, only one is correct. Unfortunately, the others are not empty shells. They are also full length movies that might have a part missing or a couple scenes out of order or some other subtle, incorrect variation.
HarryKleins
Post by HarryKleins » Thu Jun 06, 2024 11:25 pm
OK. And this is just to piss off those who break the DRM?
If I understand correctly, to date, there is no miracle tool to overcome this?
Post by Billycar11 » Fri Jun 07, 2024 12:45 pm
It could have to movie in the wrong order or it could just display a thing piracy bad grr
Nucleus
Post by Nucleus » Sat Jun 08, 2024 6:52 am
Have you tried with @MartyMcNuts GetMPLS tool, link in my sig.
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
KimJongNumberUn
Post by KimJongNumberUn » Fri Jun 28, 2024 6:16 pm
The new Flicker Alley Blu-Ray of Never Open That Door is full of duplicate playlists. MakeMKV said to share this file on the forums. How do I know which playlist to use to rip? https://mega.nz/file/5dkE0K6a#M9wpD9vZw ... R42SBREbJ4
billwolfer
Post by billwolfer » Wed Jul 03, 2024 7:49 pm
Ditto. I came here hoping someone had found the answer. Very frustrating. The last time I had this problem was another Flicker Alley disc. Bla. Anyone have any ideas?
cryptkeeper
Post by cryptkeeper » Wed Jul 03, 2024 8:36 pm
Try using 00278.mpls
billwolfer
Post by billwolfer » Fri Jul 05, 2024 2:54 am
That worked. Thank you! Do you mind if I ask how you found it? Or, if you don't want to get into that, can you tell us the playlist number for the other feature, "If I should die before I awake"? TIA.
cryptkeeper
Post by cryptkeeper » Fri Jul 05, 2024 9:49 pm
If you're referring to the bonus feature, "If I Should Die Before I Wake", try 00144.mpls.
billwolfer
Post by billwolfer » Sat Jul 06, 2024 5:15 pm
That's it. Thanks again!
zzeedd56
Post by zzeedd56 » Sat Aug 24, 2024 10:46 pm
VERIFIED CORRECT STREAMS FOR FLICKER ALLEY BLU RAY
NEVER OPEN THAT DOOR 1952 flicker alley -BR
Title information
Source file name: 00278.mpls
Duration: 1:24:46
Chapters count: 11
Segment count: 9
Segment map: 10100,10101,1101,11111,10001,11011,11001,111,10111
File name: title_t251.mkv
IF I SHOULD DIE BEFORE I WAKE 1952 flicker alley -BR
Title information
Source file name: 00144.mpls(1)
Duration: 1:10:24
Chapters count: 8
Segment count: 6
Segment map: 110,10010,11101,11110,1111,1100
File name: title_t242.mkv
MaidenHell
Post by MaidenHell » Sat Oct 12, 2024 1:31 am
This sure helped me, I've been used to seeing many files, but I could pick the largest one and it would be right. Midway- 4K UHD and the 1080p disks both had about 80 files that were all the largest size, so on both I just picked the first one, both were wrong, I didn't know about this Fake Playlist thing and thought I had a bad factory burn because it would start at the beginning an hour into the movie. Doing the backup method let me see the correct one. I've been watching the 1080p one I did and put on my server while I'm encoding the 4K 2160p one after having done it's backup. ~Thank you.
Ashfall
Post by Ashfall » Sun Nov 10, 2024 9:08 pm
Sent in a report for the Flicker Alley release "Laurel & Hardy: Year Two - The Newly Restored 1928 Silents".
Some of the mkv files end up with 10-20 seconds of black silence at the end that gets stuck when playing. Just trim it off with mkvtoolnix.
Disc 1
Play All 00819.mpls 1:47:59
Leave 'em Laughing 00250.mpls 22:17
The Finishing Touch 00480.mpls 21:23
From Soup to Nuts 00505.mpls 19:28
You're Darn Tootin' 00850.mpls 21:34
Their Purple Moment 00747.mpls 22:53
Now I'll Tell One 00988.mpls,40945.m2ts 10:20
Eve's Love Letters 00042.mpls 21:46
Galloping Ghosts 00885.mpls,78050.m2ts 5:07
Thomas B. Roberts Interview 00109.mpls 12:02
Hal Roach Interview 00972.mpls 21:43
Anita Garvin Stanley Interview 00458.mpls 26:31
Disc 2
Play All 00819.mpls 1:46:13
Should Married Men Go Home? 00082.mpls 21:27
Early to Bed 00383.mpls 20:09
Two Tars 00580.mpls 21:48
Habeas Corpus 00897.mpls 21:20
We Faw Down 00221.mpls 20:53
On Location in Year Two 00003.mpls,08212.m2ts 15:24
A Pair of Tights 00766.mpls 20:28
George Mann's Home Movies 00850.mpls,08808.m2ts 6:29
Stan Laurel Interview 00002.mpls,05280.m2ts 23:22
