You'll have found a disc with it if you try to rip a movie that seems to have several hundred copies of the movie on it.HarryKleins wrote: Thu Jun 06, 2024 10:49 pm Hello,
What is the "fake playlist"?
I am new to this. Thank you for your understanding.
"Fake playlist" protection - help needed
Re: "Fake playlist" protection - help needed
HarryKleins
OK, I see. So out of this hundred lists of films, only one would be correct?
What are the others empty shells?
Yes, only one is correct. Unfortunately, the others are not empty shells. They are also full length movies that might have a part missing or a couple scenes out of order or some other subtle, incorrect variation.HarryKleins wrote: Thu Jun 06, 2024 11:04 pm OK, I see. So out of this hundred lists of films, only one would be correct?
HarryKleins
OK. And this is just to piss off those who break the DRM?
If I understand correctly, to date, there is no miracle tool to overcome this?
It could have to movie in the wrong order or it could just display a thing piracy bad grrHarryKleins wrote: Thu Jun 06, 2024 10:49 pm Hello,
Have you tried with @MartyMcNuts GetMPLS tool, link in my sig.HarryKleins wrote: Thu Jun 06, 2024 11:25 pmIf I understand correctly, to date, there is no miracle tool to overcome this?
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
KimJongNumberUn
The new Flicker Alley Blu-Ray of Never Open That Door is full of duplicate playlists. MakeMKV said to share this file on the forums. How do I know which playlist to use to rip? https://mega.nz/file/5dkE0K6a#M9wpD9vZw ... R42SBREbJ4
billwolfer
Ditto. I came here hoping someone had found the answer. Very frustrating. The last time I had this problem was another Flicker Alley disc. Bla. Anyone have any ideas?KimJongNumberUn wrote: Fri Jun 28, 2024 6:16 pm The new Flicker Alley Blu-Ray of Never Open That Door is full of duplicate playlists. MakeMKV said to share this file on the forums. How do I know which playlist to use to rip? https://mega.nz/file/5dkE0K6a#M9wpD9vZw ... R42SBREbJ4
cryptkeeper
Try using 00278.mplsKimJongNumberUn wrote: Fri Jun 28, 2024 6:16 pm The new Flicker Alley Blu-Ray of Never Open That Door is full of duplicate playlists. MakeMKV said to share this file on the forums. How do I know which playlist to use to rip? https://mega.nz/file/5dkE0K6a#M9wpD9vZw ... R42SBREbJ4
billwolfer
That worked. Thank you! Do you mind if I ask how you found it? Or, if you don't want to get into that, can you tell us the playlist number for the other feature, "If I should die before I awake"? TIA.cryptkeeper wrote: Wed Jul 03, 2024 8:36 pmTry using 00278.mplsKimJongNumberUn wrote: Fri Jun 28, 2024 6:16 pm The new Flicker Alley Blu-Ray of Never Open That Door is full of duplicate playlists. MakeMKV said to share this file on the forums. How do I know which playlist to use to rip? https://mega.nz/file/5dkE0K6a#M9wpD9vZw ... R42SBREbJ4
cryptkeeper
If you're referring to the bonus feature, "If I Should Die Before I Wake", try 00144.mpls.billwolfer wrote: Fri Jul 05, 2024 2:54 amThat worked. Thank you! Do you mind if I ask how you found it? Or, if you don't want to get into that, can you tell us the playlist number for the other feature, "If I should die before I awake"? TIA.cryptkeeper wrote: Wed Jul 03, 2024 8:36 pmTry using 00278.mplsKimJongNumberUn wrote: Fri Jun 28, 2024 6:16 pm The new Flicker Alley Blu-Ray of Never Open That Door is full of duplicate playlists. MakeMKV said to share this file on the forums. How do I know which playlist to use to rip? https://mega.nz/file/5dkE0K6a#M9wpD9vZw ... R42SBREbJ4
billwolfer
That's it. Thanks again!cryptkeeper wrote: Fri Jul 05, 2024 9:49 pmIf you're referring to the bonus feature, "If I Should Die Before I Wake", try 00144.mpls.billwolfer wrote: Fri Jul 05, 2024 2:54 amThat worked. Thank you! Do you mind if I ask how you found it? Or, if you don't want to get into that, can you tell us the playlist number for the other feature, "If I should die before I awake"? TIA.
VERIFIED CORRECT STREAMS FOR FLICKER ALLEY BLU RAY
NEVER OPEN THAT DOOR 1952 flicker alley -BR
Title information
Source file name: 00278.mpls
Duration: 1:24:46
Chapters count: 11
Segment count: 9
Segment map: 10100,10101,1101,11111,10001,11011,11001,111,10111
File name: title_t251.mkv
IF I SHOULD DIE BEFORE I WAKE 1952 flicker alley -BR
Title information
Source file name: 00144.mpls(1)
Duration: 1:10:24
Chapters count: 8
Segment count: 6
Segment map: 110,10010,11101,11110,1111,1100
File name: title_t242.mkv
Title information
Duration: 1:24:46
Chapters count: 11
Segment count: 9
Title information
Duration: 1:10:24
Chapters count: 8
Segment count: 6
MaidenHell
This sure helped me, I've been used to seeing many files, but I could pick the largest one and it would be right. Midway- 4K UHD and the 1080p disks both had about 80 files that were all the largest size, so on both I just picked the first one, both were wrong, I didn't know about this Fake Playlist thing and thought I had a bad factory burn because it would start at the beginning an hour into the movie. Doing the backup method let me see the correct one. I've been watching the 1080p one I did and put on my server while I'm encoding the 4K 2160p one after having done it's backup. ~Thank you.
Sent in a report for the Flicker Alley release "Laurel & Hardy: Year Two - The Newly Restored 1928 Silents".
Some of the mkv files end up with 10-20 seconds of black silence at the end that gets stuck when playing. Just trim it off with mkvtoolnix.
Disc 1
Play All 00819.mpls 1:47:59
Leave 'em Laughing 00250.mpls 22:17
The Finishing Touch 00480.mpls 21:23
From Soup to Nuts 00505.mpls 19:28
You're Darn Tootin' 00850.mpls 21:34
Their Purple Moment 00747.mpls 22:53
Now I'll Tell One 00988.mpls,40945.m2ts 10:20
Eve's Love Letters 00042.mpls 21:46
Galloping Ghosts 00885.mpls,78050.m2ts 5:07
Thomas B. Roberts Interview 00109.mpls 12:02
Hal Roach Interview 00972.mpls 21:43
Anita Garvin Stanley Interview 00458.mpls 26:31
Disc 2
Play All 00819.mpls 1:46:13
Should Married Men Go Home? 00082.mpls 21:27
Early to Bed 00383.mpls 20:09
Two Tars 00580.mpls 21:48
Habeas Corpus 00897.mpls 21:20
We Faw Down 00221.mpls 20:53
On Location in Year Two 00003.mpls,08212.m2ts 15:24
A Pair of Tights 00766.mpls 20:28
George Mann's Home Movies 00850.mpls,08808.m2ts 6:29
Stan Laurel Interview 00002.mpls,05280.m2ts 23:22
Disc 1
Disc 2
