Is Verbatim 43888 sufficient for ripping some 4k UHD discs for Plex
Kezza
Post by Kezza » Fri Jul 05, 2024 12:13 am
Hi all,
New here and and have been reading a lot of the forum trying to understand what I need.
The impression I am getting is that the Verbatim 43888 can read UHD drives and is LiberDrive compatible out of the box, which should be all I need in order to rip some 4K blurays to store on my plex server.
Is there anything I am not understanting, or is it worth getting a different drive. I am not intending on ripping blurays constantly, its just for the movies that I want to have in the highest quality possible.
Any advice is appreciated greatly
Re: Is Verbatim 43888 sufficient for ripping some 4k UHD discs for Plex
Post by MartyMcNuts » Fri Jul 05, 2024 12:38 am
Kezza wrote: Fri Jul 05, 2024 12:13 am Hi all,
Yep, works fine.
Kezza
Post by Kezza » Fri Jul 05, 2024 12:50 am
MartyMcNuts wrote: Fri Jul 05, 2024 12:38 am
Yep, works fine.
Great thanks, will go with that then!
