BETA key not working
ggking7
#1 Post by ggking7 » Fri Apr 30, 2010 5:43 am
My evaluation period expired so I tried to use the BETA key as described here:
http://www.makemkv.com/forum2/viewtopic ... 1218#p4421
but makemkv says the key is expired and removes it. Can we still use makemkv without purchasing since it's in BETA?
Re: BETA key not working
#2 Post by mike admin » Fri Apr 30, 2010 7:19 am
Yes, the key is updated.
ggking7
#3 Post by ggking7 » Fri Apr 30, 2010 4:18 pm
I don't get the message about the key being removed from ~/.MakeMKV/settings.conf any more, but it still tells me my evaluation period is over and it doesn't let me rip a disc. I'm on 1.5.5. This is all I have in settings.conf:
appKey = "T-o4vIHFtFMG0O4H5u0NT40YJcRLnfXk2j1O0Yiy3O6YrwbHga7kWEYays4AS6MTK9h9"
I've double-checked permissions on the folder and file.
ggking7
#4 Post by ggking7 » Sat May 01, 2010 6:56 pm
I forgot the underscore in app_Key.
Archo
#5 Post by Archo » Fri Sep 02, 2011 12:52 pm
Makemkv beta expired and there isnt a new one. Batch encode errors out cause of trial expiration but i believe you are still allowed to use Makemkv regardless of beta expiration (at least until our of beta).
Romansh
#6 Post by Romansh » Fri Sep 02, 2011 11:04 pm
Archo wrote:Makemkv beta expired and there isnt a new one.
Yes, there is: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
hjr333
#7 Post by hjr333 » Sun Oct 01, 2017 5:23 am
Hi there,
the beta key is not working again. Although it should until the end of September
regards
#8 Post by Woodstock » Sun Oct 01, 2017 5:57 am
The link currently has a key that expired a couple of days ago. The message you're replying to is 6 years old!
When Mike replaces it, the note at the bottom will say something like....
and is valid until end of (probably) November 2017.
Right now, it's 1 October in many parts of the world, so the September key doesn't work anymore.
dorgan
#9 Post by dorgan » Sun Oct 01, 2017 4:01 pm
Would be really great if this didn't happen a couple times a month... Not sure I want to consider supporting something that stops working until its updated by the owner...
#10 Post by Woodstock » Sun Oct 01, 2017 6:38 pm
It hasn't happened to me since 2011. Of course, that was when I bought a permanent key.
The keys are typically good for two months. If you're having it happen 'a couple of times a month', there is something else going on.
