Rango UHD cannot be opened.
SigiHH
Post by SigiHH »
Hi there...
am having problems opening Rango with MakeMKV...
Using LibreDrive mode (v06.3 id=EC0D0F39EDA7)
Saved AACS dump file as C:\Users\[redacted]/.MakeMKV/MKB20_v77_Rango_FD22.tgz
Please find an attachment to this post regarding the AACS dump file.
Is there any quick fix?
Much thanks for any help!
SigiHH
Re: Rango UHD cannot be opened.
See the Hashed Keys section of the UHD FAQ.
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
SigiHH
Post by SigiHH »
Much Thanks! :D
