dvd-iso plays fine from HD - error when converting to mkv
raathass
#1 Post by raathass » Thu Sep 01, 2011 9:56 pm
Hi.
I have an ISO that plays fine in VLC and other players, but I'm not able to make a mkv. The process stops at what I believe is 100% (time remaining is 0:00:00 when the error happens).
Here's the log (I deselct title 2). Could it be some bad info at the very end of the ISO?
MakeMKV v1.6.14 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Server1/MakeMKV_log.txt
The program can't find any usable optical drives.
Title #0 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1 was added (16 cell(s), 1:49:04)
Title #2 was added (1 cell(s), 0:04:33)
DEBUG: Code 233 at 4vEroj3bT5lqpvwt6MQ8Ot8q:0
Saving 1 titles into directory S:/99 - temp/_cd-da
DEBUG: Code 4294967295 at e*E<@K\\,p90jg/v3o|:121262555
DEBUG: Code 0 at 6<}tWK.\~_<Q[9t*M3_$:29394321
DEBUG: Code 3419385 at 6<}tWK.\~_<Q[9t*M3_$:29393309
Failed to save title 0 to file S:/99 - temp/_cd-da/title00.mkv
0 titles saved, 1 failed
raathass
Re: dvd-iso plays fine from HD - error when converting to mk
#2 Post by raathass » Thu Sep 01, 2011 10:35 pm
Used DVD Fab to create a new ISO with only the needed title, and tried to create a mkv. Same error.
Title #0 was added (16 cell(s), 1:49:04)
DEBUG: Code 233 at DcBmzvywajJRWTsXyLaYk/Fw:0
DEBUG: Code 0 at 6<}tWK.\~_<Q[9t*M3_$:29394183
setarip_old
#3 Post by setarip_old » Fri Sep 02, 2011 6:11 am
Hi!
DO NOT MOUNT the .ISO image file. Load it DIRECTLY into MakeMKV...
raathass
#4 Post by raathass » Fri Sep 02, 2011 6:54 am
setarip_old wrote:Hi!
Thanks, but I'm not mounting the file :-).
/r
setarip_old
#5 Post by setarip_old » Fri Sep 02, 2011 8:58 am
Then just load the original, commercial disc (Blu-ray or DVD) into MakeMKV (No need for the .ISO image file)...
raathass
#6 Post by raathass » Fri Sep 02, 2011 9:06 am
setarip_old wrote:Then just load the original, commercial disc (Blu-ray or DVD) into MakeMKV (No need for the .ISO image file)...
I don't have the original disc, just the image. What I think is strange is that
1) The image plays just fine
2) The error occur after the process has come to 100%
Are anyone able to tell me what these errors mean?
setarip_old
#7 Post by setarip_old » Fri Sep 02, 2011 5:31 pm
Then it's inappropriate to ask questions here about it...
#8 Post by mike admin » Sun Sep 04, 2011 8:57 am
The VOB file is corrupted at the very end. I would blame the bad rip.
raathass
#9 Post by raathass » Sun Sep 04, 2011 9:36 am
Thanks.
The image plays just fine in VLC and I have no problem converting it to h264 using handbrake and dvdfab. If I extract the troublesome title in dvdfab to a new image, this new image still fails in makemkv.
Is it likely that the two other programs have some sort of "failsafing" that forces them to continue when they encounter bad info?
Do not misunderstand me - makedvd is a brilliant tool - I just would like to understand how things work :-)
/r
