What titles does MakeMKV show when you open the disc/folder? Can you link the image.KimJongNumberUn wrote: Sat Jun 29, 2024 1:45 amYeah, with the decrypted folder. There are also two films on the disc. MPC-HC didn't open the right playlist.MartyMcNuts wrote: Sat Jun 29, 2024 12:52 amYou are trying with your ripped decrypted backup folder aren't you??KimJongNumberUn wrote: Fri Jun 28, 2024 10:04 pm I'm trying to use this to get the correct playlist from Flicker Alley's BD of Never Open That Door, but when I run the folder through it doesn't show anything.
I'm not familiar with this title but you could try opening the index.bdmv file with a player (I use MPC-HC) and it should (most of the time) open the correct playlist and tell you which playlist it is.
GetMPLS - An Application to help find the correct playlist for BD / UHD
Re: GetMPLS - An Application to help find the correct playlist for BD / UHD
KimJongNumberUn
It shows 87 titles for the main movie, and 22 titles for the bonus featureMartyMcNuts wrote: Sat Jun 29, 2024 10:54 pmWhat titles does MakeMKV show when you open the disc/folder? Can you link the image.KimJongNumberUn wrote: Sat Jun 29, 2024 1:45 amYeah, with the decrypted folder. There are also two films on the disc. MPC-HC didn't open the right playlist.MartyMcNuts wrote: Sat Jun 29, 2024 12:52 am
We need to see it. Show the MakeMKV screen with all of the titles.KimJongNumberUn wrote: Sun Jun 30, 2024 7:25 pmIt shows 87 titles for the main movie, and 22 titles for the bonus featureMartyMcNuts wrote: Sat Jun 29, 2024 10:54 pmWhat titles does MakeMKV show when you open the disc/folder? Can you link the image.KimJongNumberUn wrote: Sat Jun 29, 2024 1:45 am
Hi.
Can this software also be used on Linux, perhaps with Wine? In fact I have a problem of many mpls: viewtopic.php?f=8&t=34557
Edit: I did it on my own
KimJongNumberUn
This is what I get. It's a list of hundreds of playlists. Not sure how to screenshot them all, or if there's a way to grab the data itself in a log.MartyMcNuts wrote: Sun Jun 30, 2024 9:51 pmWe need to see it. Show the MakeMKV screen with all of the titles.KimJongNumberUn wrote: Sun Jun 30, 2024 7:25 pmIt shows 87 titles for the main movie, and 22 titles for the bonus featureMartyMcNuts wrote: Sat Jun 29, 2024 10:54 pm
That looks like playlist obfuscation. Usually see this on Lionsgate titles. Anyway, you could start by looking at playlist 00800 or 00801 or 00001 and checking if one of them is correct.KimJongNumberUn wrote: Tue Jul 02, 2024 12:59 amThis is what I get. It's a list of hundreds of playlists. Not sure how to screenshot them all, or if there's a way to grab the data itself in a log.MartyMcNuts wrote: Sun Jun 30, 2024 9:51 pmWe need to see it. Show the MakeMKV screen with all of the titles.KimJongNumberUn wrote: Sun Jun 30, 2024 7:25 pm
As @MartyMcNuts posted, typical of Lionsgate playlist obfuscation. If GetMPLS hasn't worked for you, and googling the correct playlist to rip has drawn a blank, look at Process Monitor Method linked in my sig - there's a small learning curve to it but I guess if you want to rip the disc you'll persevere. Haven't read back though the thread but is the disc/playlist ID's not listed on TheDiscDB ?KimJongNumberUn wrote: Tue Jul 02, 2024 12:59 amThis is what I get. It's a list of hundreds of playlists. Not sure how to screenshot them all, or if there's a way to grab the data itself in a log.
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
This works amazingly. Thank you so much! I now have a weapon of offense for lionsgate blurays. Hehehe
