Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
#76 Post by Billycar11 » Mon Jul 01, 2024 12:33 am
mas1701 wrote: Sun Jun 30, 2024 11:51 pm Hi,
is there any chance for UHD with this OEM USB3 BD-XL drive? When inserting an UHD disc, it only makes funny sounds, then stops.
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: ALDL2403xxxx
Firmware-Datum: 2018-08-22
Highest AACS version: 71
Drive platform: RS8511
Firmware version: E101/ID26
After successfully flashing a first drive on Linux today and reading some of the previous posts, I'm at least a bit hopeful that there is an expert here who can help.
yeah but pioneers can be flashed on windows only email me if you can send that info from windows
#77 Post by Coopervid » Tue Jul 02, 2024 5:52 pm
PM for clwelch63 deleted. was not read within a week.
clwelch63
#78 Post by clwelch63 » Sat Jul 06, 2024 8:21 pm
Hi coopervid,
Sorry I wasn't able to get to the PM you sent. I've been traveling. I'm back home and would appreciate a second PM.
Thanks,
Chris
Coopervid wrote: Tue Jun 25, 2024 9:21 am
clwelch63 wrote: Sat Jun 22, 2024 3:40 pm Hi coopervid,
I'd like to flash my PIONEER BD-RW BDR-UD03 with the firmware that lets it read UHD discs. I see a lot of discussion about it, but don't see where to download the firmware. Is there a download site? Thanks in advance.
Here's my drive information:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.10
Serial number: [redacted]
Firmware date: 2017-04-18
Firmware version: 1.10
PM sent.
#79 Post by Coopervid » Sun Jul 07, 2024 11:03 am
clwelch63 wrote: Sat Jul 06, 2024 8:21 pm Hi coopervid,
Thanks,
Chris
OS device name: E:
Revision: 1.10
PM sent.
PM sent.
mas1701
#80 Post by mas1701 » Mon Jul 08, 2024 12:20 am
Billycar11 wrote: Mon Jul 01, 2024 12:33 am
Respectfully, I'd like to point out that this seems to be incorrect.
The drive I successfully flashed on Linux was an ASUS drive manufactured by Pioneer. I even reported on the successful flash attempt in full detail right here on the forum. The drive was on up-to-date encrypted firmware and is now on an older, non-encrypted MK firmware.
If you just want to sell a piece of windooze software to me (as suggested by your signature), you are out of luck.
#81 Post by Billycar11 » Mon Jul 08, 2024 1:12 am
mas1701 wrote: Mon Jul 08, 2024 12:20 am
if you want to be proven wrong post your makemkv drive info section
if your drive platform is mt1959 or mt1939 its not a pioneer its an LG
oh look mt1959 you say your drive was
mas1701 wrote: Sun Jun 30, 2024 10:00 pm
MakeMKV confirms v3.10 and shows:
Before flashing, I confirmed the correct drive with "lsblk -S". Recommend this before something bad happens.
so you are incorrect giving people false hope and misleading them and trying to prove a person wrong who is always helping people here.
i give away all the info for free the charge for those who dont want to do it them selves with the guide.
mas1701
#82 Post by mas1701 » Mon Jul 08, 2024 11:11 pm
Billycar11 wrote: Mon Jul 08, 2024 1:12 am if you want to be proven wrong post your makemkv drive info section
That was NOT my intention. But thanks for the clarification.
In fact, I'm shocked that ASUS has to resort to more than one OEM supplier for their drives. So if this is a Pioneer drive and the other is in fact an LG, then of course you may be completely right, I just can't tell. I have to depend on what I read here and obviously I didn't notice the difference between MT19x9 types. It is not really to be expected that this little change in the number has to do with a different manufacturer, it looks more like another model from the same manufacturer.
Sorry for the mix-up.
So if this is a Pioneer drive and if there is an alternative firmware with less artificial restrictions, is there a reason why this FW is not just available for download and has to be requested? I doubt the legal situation differs from the situation of other FW packages.
Btw., I just flashed the FW of another ASUS/LG drive remotely for a friend using MeshCentral remote control. He picked up the drive by recommendation after I've successfully flashed my own.
As for flashing with Windows, yes, of course I can do that. It's an external USB3 drive after all, so it's not "stuck" to the Linux system.
#83 Post by Billycar11 » Mon Jul 08, 2024 11:40 pm
mas1701 wrote: Mon Jul 08, 2024 11:11 pm
If look on the sticker of your Asus you will see it says LG bh16ns40
The pioneers are way better I stopped selling LG/Asus desktop drives back in 2019
gschmidl
#84 Post by gschmidl » Wed Jul 10, 2024 9:28 pm
Hello! I have the same drive - hopefully coopervid can assist me as well.
OS device name: F:
Current profile: DVD-ROM
Revision: 1.11
Firmware date: 2018-11-28
Firmware version: 1.11
Thank you!
#85 Post by Coopervid » Thu Jul 11, 2024 4:37 pm
gschmidl wrote: Wed Jul 10, 2024 9:28 pm Hello! I have the same drive - hopefully coopervid can assist me as well.
OS device name: F:
Revision: 1.11
Thank you!
Check your PM.
gschmidl
#86 Post by gschmidl » Thu Jul 11, 2024 8:34 pm
Coopervid wrote: Thu Jul 11, 2024 4:37 pm Check your PM.
Worked like a charm, thank you.
maxxie
#87 Post by maxxie » Sat Jul 13, 2024 4:29 am
Hello Coopervid. May I ask for the UHD patch too, please? My Verbatim 43887 (non UHD) shows this:
Revision: 1.14
Serial number: BADL47xxxxx
Firmware date: 2020-06-15
Firmware version: 1.14
Thank you very much!
Dany-el
#88 Post by Dany-el » Sun Jul 14, 2024 9:29 pm
Hi, I think I have the same Drive. SDFtool Flasher says "The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed."
Is there a way to flash it so I can play ultra hd blu rays?
OS device name: E:
Revision: 1.14
#89 Post by Billycar11 » Sun Jul 14, 2024 11:31 pm
Dany-el wrote: Sun Jul 14, 2024 9:29 pm Hi, I think I have the same Drive. SDFtool Flasher says "The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed."
OS device name: E:
Revision: 1.14
Yeah email me your makemkv drive info section like that see below
#90 Post by Coopervid » Mon Jul 15, 2024 9:45 am
maxxie wrote: Sat Jul 13, 2024 4:29 am
Revision: 1.14
Check your PM.
