PROTECTION AACS2.0/C v68
SPECOPS501
#1 Post by SPECOPS501 » Mon Jun 10, 2024 12:52 am
HELLO GOOD DAY, I HOPE YOU ARE WELL, DOES ANYONE KNOW HOW TO BREAK THE AACS2.0/C v68 PROTECTION?
WHEN WANTING TO RIP FAST FURIOUS 5 4K I COULD NOT OPEN THE DISC. DOES ANYONE KNOW IF I CAN ADD ANY FILE, METHOD OR UPDATE TO BE ABLE TO RIP IT?
PS: FROM TIME TO TIME THE PROGRAM NO LONGER ALLOWS ME TO OPEN THE DISCS LIKE TRANSFORMERS 1 IN 4K BUT WHEN I TRY TO OPEN IT FOR THE SECOND TIME I SUCCESSFUL
THANK YOU VERY MUCH FOR YOUR HELP AND TIME. :cry: :| :(
Re: PROTECTION AACS2.0/C v68
#2 Post by Woodstock » Mon Jun 10, 2024 1:36 am
All-uppercase is not considered polite nowadays.
A version 68 protection should be handled automatically by MakeMKV, assuming you have allowed it to fetch updates. If not, it will create a file (ending in ".TGZ") that has what is needed to decode it, which you then forward to svq@makemkv.com for processing. THEN you have to have updates enabled to fetch the decoder key. That can be a separate issue, but that would be shown in the log that you didn't provide.
SPECOPS501
#3 Post by SPECOPS501 » Sun Jun 30, 2024 2:12 am
hank you very much, sorry for the capital letters, I was using my old keyboard and Google Translate, the truth is I don't know English.
