LibreDrive for Pioneer drives
Fighter96123 wrote: Sat Jun 29, 2024 5:26 pm Hi there,
is there any way for the following drive to accept/recognize 4k blurays?
Thanks in advance for your help.
Laufwerksinformation
OS-Gerätename: \Device\CdRom1
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-XD08
Revision: 1.00
Serienummer:
Firmware-Datum: 2022-04-03
Highest AACS version: 78
Drive platform: Pioneer RS9330
Firmware version: GENE
For now no but this one will likely be supported in the future if you don't update
When that is we don't know
taint
Post by taint »
Just picked up a USB BD-RW, surprised to see it has such an old firmware. I know this is currently based on RS1XXX, is it possible to update this to something that will support LIbreDrive, or is it just a dead end?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-TD03
Revision: 1.20
Serial number:
Firmware date: 2011-07-15
Highest AACS version: 62
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1027
Firmware version: ID72
taint wrote: Sun Jul 14, 2024 7:18 pm Just picked up a USB BD-RW, surprised to see it has such an old firmware. I know this is currently based on RS1XXX, is it possible to update this to something that will support LIbreDrive, or is it just a dead end?
Revision: 1.20
Serial number:
Forget about it. Most likely will never get libredrive enabled and even if it does at some point, it will never be able to rip UHD.
Placidcasual98
Post by Placidcasual98 »
I have a Pioneer BD-RW BDR-209M here is the info below. Put in a 4K disc and it doesn't read it. Will this be able used? Thanks in advance.
Info
OS device name: E:
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: REDL001848WL
Firmware date: 2017-12-21
Bus encryption flags: 3
Status: Possible, not yet enabled Drive platform: Pioneer RS8601
Firmware version: ID60
Placidcasual98 wrote: Thu Jul 25, 2024 5:12 pm I have a Pioneer BD-RW BDR-209M here is the info below. Put in a 4K disc and it doesn't read it. Will this be able used? Thanks in advance.
Info
OS device name: E:
Revision: 1.50
Email me for the flasher to enable uhd
ohhoo
Post by ohhoo »
I have a Pioneer BDR-XS07U drive of Japan model.
Its FW version is 1.00, but the status is "Possible, not yet enabled"...
Can you please tell me what I need to do to enable LibreDrive?
OS device name: F:
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: SJDLxxxxxxJP
Firmware date: 2019-01-07
Highest AACS version: 81
Firmware version: ID69
ohhoo wrote: Sat Jul 27, 2024 6:03 am Hi,
OS device name: F:
Revision: 1.00
you could update with an old pioneer updater but do not use a new one
or email me for a flasher
ohhoo
Post by ohhoo »
Billycar11 wrote: Sat Jul 27, 2024 6:07 am
OS device name: F:
Revision: 1.00
Thanks for the quick reply.
From the information in SDF.bin (v8D), I think FW1.01 (ID69) can enable LibreDrive, but the updater I have is only FW1.02 (ID69)...
Can FW1.02 (ID69) enable LibreDrive?
I can also get ID05 versions FW1.01 and FW1.02, but my drive is ID69 so I can't apply them...
ohhoo wrote: Sat Jul 27, 2024 6:32 am
OS device name: F:
Revision: 1.00
1.01 is what you want
ohhoo
Post by ohhoo »
Billycar11 wrote: Sat Jul 27, 2024 6:35 am
Thank you.
As I thought, I still need 1.01.
But so far I can't find 1.01 on the internet...
Do you know of any site where I can get it?
Or can your flasher solve this problem? If so I will send you an email.
Marych
Post by Marych »
Hello I have this player and it is listed to be good for flashing and decrypting UHD BDs. But I can't find the .bin to flash it.
Thanks for your help
Informations lecteur
Nom du lecteur SE : D:
Fabricant : PIONEER
Produit : BD-RW BDR-UD04
Révision : 1.14
Date micrologiciel : 2020-06-15
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 81
Drive platform: RS8A10
Firmware version: 1.14
Marych wrote: Fri Aug 02, 2024 3:58 am Hello I have this player and it is listed to be good for flashing and decrypting UHD BDs. But I can't find the .bin to flash it.
Fabricant : PIONEER
Révision : 1.14
should work as is no need to flash.
Marych
Post by Marych »
Billycar11 wrote: Fri Aug 02, 2024 5:50 am
Fabricant : PIONEER
Révision : 1.14
Thanks I will try a 4k
badrip7
Post by badrip7 »
Recently purchased pioneer BDR-212, will this work with the patcher?
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Bus encryption flags: 13
Drive platform: RS8F00
Firmware name: PIONEER. BDR-212T
Firmware version: 1.02/ID61
badrip7 wrote: Sat Aug 03, 2024 3:48 pm Recently purchased pioneer BDR-212, will this work with the patcher?
Revision: 1.02
Serial number:
Yes.
