Building HtPc/NAS in the Fractal design 803 which allows for a 12.7mm Slot-in Internal Drive.
Will be used mainly for playing 4K Blu-rays but also want the option to rip them.
What's my best option, where to get?
Internal slim line in NZ
Re: Internal slim line in NZ
There are no UHD capable 12.7mm drives. If you want to put a drive in the Fractal, your only choice is a LG BU40N 9.5mm and then you'd have to find some sort of 9.5mm to 12.7mmm adapter maybe somewhere like Amazon.
Your other option would be an external drive. I have had many NZ customers over the years! Check my site. Link is in my signature.
The LG BU40N is tray loading, I would need a slot-in drive.
Found this post from Billy:
Waiting on a reply from him on availability.Billycar11 wrote: ↑Fri May 26, 2023 9:47 pmThe pioneer xs07s flashed to xs07uhd from me is slot load and works with UHD contact details below if you want one
Already replied to you and I said I don't ship to NZ and have not had slim slot load drives since August recommend you talk to Marty and saw you were already in contact with him here already.ThaSpike wrote: ↑Fri Jun 28, 2024 11:48 pmThe LG BU40N is tray loading, I would need a slot-in drive.
Found this post from Billy:Waiting on a reply from him on availability.Billycar11 wrote: ↑Fri May 26, 2023 9:47 pmThe pioneer xs07s flashed to xs07uhd from me is slot load and works with UHD contact details below if you want one
