Ghosbusters: Frozen Empire
Rodney M
Re: Ghosbusters: Frozen Empire
Post by Rodney M »
Rodney M wrote: Thu Jun 27, 2024 11:48 am Send tgz file: Ghostbusters-_Frozen_Empire_B086.tgz
Doesn't work today either, am I doing something wrong?
Rodney M wrote: Fri Jun 28, 2024 10:22 am
usually takes around 2weeks
bigbwb
Post by bigbwb »
I tried this disc recently as well. Funny thing, 90% of the movie played perfectly. The last 15 minutes or so, the audio was way off from the video. I tried the process over again and the same result.
I had to decrypt using DVDFab then used makemkv. So based on what I read, give it some time for the developer(s) to work out this problem and try ripping the disc again?
jamb309
Post by jamb309 »
Nothing has worked for MKB20_v77_Ghostbusters-_Frozen_Empire_E132.tgz, already submitted. Tried MakeMKV, KEYDB.cfg, and DVDFab. This UHD Bluray is a set with Ghostbusters- Frozen Empire, Afterlife, an ice cube maker, and regular HD Blu-rays. Also submitted MKB20_v77_Ghostbusters-_Afterlife_FA26.tgz. I am not shocked that it will take a little time as both are brand-new UHD Bluray versions.
omk1980
Post by omk1980 »
Still not ripping 4F38.tgz. hopefully will come soon
triplerinse
Post by triplerinse »
still a no go for me, maybe he is away for the holiday
Post by SamuriHL »
If you've tried adding the KEYDB.cfg file to your MakeMKV data directory and it still doesn't work, one thing you could try is install Xreveal and see if it can decrypt it. MakeMKV requires a VUK to be in the keydb for it to work and not all entries have the VUK. If the unit keys for your disc are in there, Xreveal will decrypt it in real time, then you can open it with MakeMKV. Ignore the warning about using 3rd party decrypters, and you're (potentially if your disc is supported) good to go. This may help until Mike can get to adding a key to MakeMKV.
triplerinse
it works. thanks mike
rubberpix
Post by rubberpix »
Dump submitted
MKB20_v77_Ghostbusters-_Frozen_Empire_349C.tgz
MrBfJohn
Post by MrBfJohn »
I think I now have this working by using FindVUK to download an updated keydb.cfg file, then opening Xreveal and telling it where I have the new file stored. Then restarting Xreveal (Exit in system tray and open again with the disc in the drive). Then I booted up MakeMKV, and everything seems to be ripping as normal.
bsather
Post by bsather »
Mine worked now. Much appreciated!
