New WP50NB40 - UHD Ripping Errors
csomebody1
#1 Post by csomebody1 » Mon Jun 24, 2024 3:04 am
I have a new WP50NB40 which I am trying to use to rip the Back to the Future 4K disks, but it doesn't seem to be working.
I flashed the drive to BP50NB40 (NB50) 1.03-MK and then to BU40N 1.00 using this tool - viewtopic.php?f=16&t=22896
Did I choose the wrong firmware or make a mistake?
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIK04O42F0545
Firmware date: 2116-12-20 15:28
Highest AACS version: 76
Firmware version: 1.00
On the first disk I'm receiving this error -
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00445.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00445.m2ts to file C:/Users/<path>/Videos/BACK_TO_THE_FUTURE/BDMV/STREAM/00445.m2ts
On the second disk I'm receiving this error -
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00437.m2ts' at offset '1044480'
Failed to save title /BDMV/STREAM/00437.m2ts to file C:/Users/<path>/Videos/BACK_TO_THE_FUTURE_PART_II/BDMV/STREAM/00437.m2ts
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00330.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00330.m2ts to file C:/Users/<path>/Videos/BACK_TO_THE_FUTURE_PART_II/BDMV/STREAM/00330.m2ts
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00340.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00340.m2ts to file C:/Users/<path>/Videos/BACK_TO_THE_FUTURE_PART_II/BDMV/STREAM/00340.m2ts
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00277.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00277.m2ts to file C:/Users/<path>/Videos/BACK_TO_THE_FUTURE_PART_II/BDMV/STREAM/00277.m2ts
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00493.m2ts' at offset '0'
Re: New WP50NB40 - UHD Ripping Errors
#2 Post by Coopervid » Wed Jun 26, 2024 9:11 am
csomebody1 wrote: Mon Jun 24, 2024 3:04 am I have a new WP50NB40 which I am trying to use to rip the Back to the Future 4K disks, but it doesn't seem to be working.
Revision: 1.00
It looks like your drive doesn't get enough power via USB. You should try another USB port or use an active hub with its own power supply. And BTW - you should read your PM regarding your Pioneer drive.
csomebody1
#3 Post by csomebody1 » Fri Jun 28, 2024 4:24 am
Coopervid wrote: Wed Jun 26, 2024 9:11 am
Revision: 1.00
Ok, I'll see if a USB hub with it's own power supply works. Thanks for the suggestion!
I was able to rip two other UHD disks - The Meg and Rango, but none of the Back to the Future disks seem to work.
