#10126 Post by RESET_9999 » Wed Jun 26, 2024 10:56 pm
TS/M2TS/MKV/MP4 are just video containers. They are unrelated to the DV profile and I was using the TS version in the video because back then, I didn't have the Ugoos and was still using my x800m2
deadchip12
#10127 Post by deadchip12 » Wed Jun 26, 2024 11:34 pm
RESET_9999 wrote:
Wed Jun 26, 2024 1:16 pm
I actually always convert P7 MEL to P8.
What are the benefits of doing so? To remove the color difference caused by apple?
#10128 Post by RESET_9999 » Thu Jun 27, 2024 12:14 am
For better support on devices. I used to do that when I was using my TV internal player Plex and kept doing it even after getting the ugoos.
Also by doing this, I know that all my P7 rip are FEL even though it's easy and fast to find out with dovi_scripts
deadchip12
#10129 Post by deadchip12 » Thu Jun 27, 2024 1:49 am
What about the "color difference cause by apple"? Your spreadsheet says "Once removed (when converted to P8), the colors match." What file that needs to be converted to P8 here? The web releases?
#10130 Post by RESET_9999 » Thu Jun 27, 2024 2:48 am
this applies only to any P5 web-dl from itunes/appleTV.
deadchip12
#10131 Post by deadchip12 » Thu Jun 27, 2024 3:15 am
Ok.
I'm using workflow 7-3 to generate screenshots to compare brightness between the hdr10 bluray and DV stream. It says "PQ screenshots DVP5/HDR10 or SDR vs SDR (Libplacebo)".
Why DVP5? Can I still use this workflow if the DV stream is profile 8?
#10132 Post by RESET_9999 » Thu Jun 27, 2024 10:59 am
because 7-3 and 7-2 dont care about metadata, they only process the base layer of P8 P7 P5
sofakng
#10133 Post by sofakng » Fri Jun 28, 2024 2:44 pm
Is this lossless?
sofakng
#10135 Post by sofakng » Fri Jun 28, 2024 4:42 pm
Thanks ... Also, is it possible to check if a disc is FEL or MEL using MediaInfo?
I thought the FEL/MEL is encoded as a separate video track but I've checked tons of full remux rips and all of them only have a single video track? (for example, Back To The Future)
#10136 Post by RESET_9999 » Fri Jun 28, 2024 5:24 pm
not with mediainfo but you can use workflow 2-2 with dovi_scripts
sofakng
#10137 Post by sofakng » Fri Jun 28, 2024 7:19 pm
I thought the enhancement layer was stored as a separate video track though?
#10138 Post by RESET_9999 » Fri Jun 28, 2024 8:11 pm
P7 is a dual-layer format that can be Single or Dual track.
sofakng
#10139 Post by sofakng » Fri Jun 28, 2024 8:27 pm
Ahh! I never knew what that meant but now I think I do. Single layer means it's embedded into the base layer (?) video track and dual layer means it has a separate video track?
Does MakeMKV automatically convert the dual layer into a single layer?
For example, Back To The Future appears to be dual layer (according to caps-a-holic.com) but the rips are only single layer?
#10140 Post by RESET_9999 » Fri Jun 28, 2024 9:32 pm
P7 is always dual layers.
Single track Dual layer means that the BL + EL are interleaved which is what MakeMKV does
Dual track Dual layer is the Bluray original format.
