deadchip12
#10111
Post
by deadchip12 » Tue Jun 25, 2024 1:40 pm
RESET_9999 wrote: ↑Tue Jun 25, 2024 1:26 pm
yes, when it's already the right values, you skip. As I said, L5 is rarely incorrect on Bluray.
I just checked Blue Beetle in aviSynth and it crops at 277 for top and 277 for bottom, while it reports 276 for top and 277 for bottom in dovi scripts. I guess we have to edit L5 for this one...
What happens if I don't edit L5? Like if I don't do any of this stuff and just watch the original bluray with the wrong L5, will I notice something wrong with the picture?
#10112
Post
by RESET_9999 » Tue Jun 25, 2024 2:21 pm
L5 tells the TV the part of the image(active area) to display/tonemap but all the hdmi devices ignore L5 so it doesn't matter to them. Only your TV internal player uses it.
there are L5 test files on my GD, try them and see what it does:
https://drive.google.com/drive/u/1/fold ... fx6vRYDEfs
so with 0-0-277-277 L5 with a 16/9 video, the TV will display/tonemap: 3840x1606 pixels (it will exclude 554pixels row top/bottom)
276/277 will be 3840x1607 pixels meaning 1 row of pixels that are black bars will get tone mapping. A 1 pixel row is not enough to cause any visible defect though.
deadchip12
#10113
Post
by deadchip12 » Tue Jun 25, 2024 2:57 pm
RESET_9999 wrote: ↑Tue Jun 25, 2024 2:21 pm
Huh? So if I'm using the Ugoos AM6B+ it won't matter if L5 is correct or not, or am I misunderstanding sth here?
#10114
Post
by RESET_9999 » Tue Jun 25, 2024 3:08 pm
yes, L5 doesnt matter for all the devices except:
1- TV internal player
2- Windows Energy Player
deadchip12
#10115
Post
by deadchip12 » Tue Jun 25, 2024 3:24 pm
RESET_9999 wrote: ↑Tue Jun 25, 2024 3:08 pm
Ok nice. I can save time by skipping editing L5 then.
staknhalo
#10116
Post
by staknhalo » Tue Jun 25, 2024 7:37 pm
whatever problems watching at the computer/windows platform aside - is that the best windows store dv player then outside of any official dv pcs player etc?
RESET_9999 wrote: ↑Tue Jun 18, 2024 5:04 pm
and it's only because I know him personally and I know that he always does all the necessary checks.
Some older framestor releases are wrong and I just checked the Captain America hybrid is still available on BHD even though it's a VERY different grade and the RPU is not even in sync with the BL.
Same for their Black Widow release and others.
You can pm the list of hybrids you're not sure and I can have a look if i can find them.
Framestor Mando S02E08 Hybrid UHD out of sync too - prob all the (d+ or iT/D?) stuff
#10117
Post
by RESET_9999 » Tue Jun 25, 2024 9:42 pm
staknhalo wrote: ↑Tue Jun 25, 2024 7:37 pm
I never watched a movie with it so I don't know about its stability but as far as Dolby Vision decoding goes, it seems to do everything right (minus the same red push as the shield).
deadchip12
#10118
Post
by deadchip12 » Tue Jun 25, 2024 10:30 pm
Oh damn I didn't know there's a media player that can play dolby vision on pc
#10119
Post
by RESET_9999 » Tue Jun 25, 2024 11:08 pm
It doesnt trigger DV on your TV, you need a certified DV monitor for that. It decodes the DV metadata to HDR10 or SDR according to your EDID, the same as LLDV.
deadchip12
#10120
Post
by deadchip12 » Tue Jun 25, 2024 11:17 pm
RESET_9999 wrote: ↑Tue Jun 25, 2024 11:08 pm
Yeah. Just noticed that in your spreadsheet. Dolby Vision scene remains dead on pc.
deadchip12
#10121
Post
by deadchip12 » Wed Jun 26, 2024 4:27 am
Put Transformers: Rise of the Beasts (2023) in the list of web releases that is only cmv2.9. Just wasted a few hours downloading several versions of it; all are 2.9.
deadchip12
#10122
Post
by deadchip12 » Wed Jun 26, 2024 12:37 pm
@RESET_9999 I'm testing The Marvels (2023), which is an HDR10 movie. I'm trying to inject DV cmv4.0 from the web release into the bluray one. Should I strictly follow the P8 hybrid tutorial or there's another way to inject DV so that the final file remains profile 7 mkv?
#10123
Post
by RESET_9999 » Wed Jun 26, 2024 1:16 pm
Why would you want to do that? P7 is pointless without FEL. As far as DV quality goes: P7 FEL > P5 > P7 MEL = P8
I actually always convert P7 MEL to P8.
deadchip12
#10124
Post
by deadchip12 » Wed Jun 26, 2024 10:34 pm
RESET_9999 wrote: ↑Wed Jun 26, 2024 1:16 pm
Does it have to be P8 ts or it can be P8 mkv? In the P8 hybrid tutorial the final file is ts
#10125
Post
by RESET_9999 » Wed Jun 26, 2024 10:56 pm
TS/M2TS/MKV/MP4 are just video containers. They are unrelated to the DV profile and I was using the TS version in the video because back then, I didn't have the Ugoos and was still using my x800m2
