Jeggo
Re: SDFtool Flasher
#1051 Post by Jeggo » Tue Jun 25, 2024 9:41 am
I flashed a LG drive successfully and made a firmware dump (original FW) before I flashed the drive.
As the LG drive is not what I expected I would like to return it and restore the original FW.
How do I apply the firmware dump and restore the drive to its original state? Is this possible?
The tar dump file contains several bin files. What file do I need to flash?
Thanks for your help.
Re: SDFtool Flasher
#1052 Post by Billycar11 » Tue Jun 25, 2024 10:09 am
Jeggo wrote: Tue Jun 25, 2024 9:41 am I flashed a LG drive successfully and made a firmware dump (original FW) before I flashed the drive.
the fw you backed up is useless
just use the lg updater but really who cares just return it they wont check
rolledjoel
Re: SDFtool Flasher
#1053 Post by rolledjoel » Wed Jun 26, 2024 6:09 pm
What is the average speed for ripping UHD BR on a WH16NS40? I saw someone on YouTube who averaged about 12x on an unencrypted disc. Are drives slower when encryption is in use?
Re: SDFtool Flasher
#1054 Post by d00zah » Wed Jun 26, 2024 7:24 pm
rolledjoel wrote: Wed Jun 26, 2024 6:09 pm What is the average speed for ripping UHD BR on a WH16NS40? I saw someone on YouTube who averaged about 12x on an unencrypted disc. Are drives slower when encryption is in use?
1st post, Recommended UHD Drives to get: section...
Ultimate UHD Drives Flashing Guide Updated 2023
Re: SDFtool Flasher
#1055 Post by Woodstock » Wed Jun 26, 2024 7:29 pm
Drives are slower when the disk is less readable, or you're reading at the beginning, or ???
The data is at a constant density (bits per lineal centimeter), but there's more of it (per rotation) when you get further from the center (beginning). It will read fastest when you're reading furthest from that center. Once you hit layer 2, it will get slower as you advance back towards the center.
Reading at maximum rate puts the most stress on the media and draws the most power, so those are additional limits.
rolledjoel
Re: SDFtool Flasher
#1056 Post by rolledjoel » Wed Jun 26, 2024 7:31 pm
d00zah wrote: Wed Jun 26, 2024 7:24 pm
Thanks. I did a quick re-watch of the video , it turns out the guy was testing a DVD.
Koolbite
Re: SDFtool Flasher
#1057 Post by Koolbite » Sun Jul 07, 2024 4:42 pm
I had flashed my BW-16D1X-U (external Asus Drive) to a bu40n in order to rip BlueRays but it wouldn't work for some reason : Actually the drive wouldn't even eject :? . So i reflashed it as a BW-16D1HT (which i understand is the internal version of my BW-16D1X-U) and the tray is ejecting again. But i still can't read anything. I hear the drive trying to read for a few seconds end then stoping, then trying again etc...
Windows tells me the drivers are updated and i also tried reinstaling the device from device manager. So at this point, me not being a geek, i'm not sur what to look for ?
Could it be that i reflashed it as a BW-16D1HT instead of a BW-16D1X-U ? Sounds unlikely..
One thing i noticed as well is that puting a cd in the drive will freeze Windows Media Player even if the cd remains undetected :?:
Thanks in advancce for any help !
Re: SDFtool Flasher
#1058 Post by Billycar11 » Sun Jul 07, 2024 11:13 pm
Koolbite wrote: Sun Jul 07, 2024 4:42 pm Hello,
Who told you to do that?
See recovery section of guide and Marty's tool
Koolbite
Re: SDFtool Flasher
#1059 Post by Koolbite » Mon Jul 08, 2024 5:37 pm
Billycar11 wrote: Sun Jul 07, 2024 11:13 pm
I followed this tutorial :
https://www.youtube.com/watch?v=LguN8RC ... haelAndrew
I have checked Marty's Tool and i don't seem to find another procedure than the one i tried.
Is it possible that i damaged the harware doing this firmware change ??
This drive costed me 150€ so i would be pissed if i needed to buy a new one because of this.
Re: SDFtool Flasher
#1060 Post by Billycar11 » Mon Jul 08, 2024 11:02 pm
Koolbite wrote: Mon Jul 08, 2024 5:37 pm
It's possible but choose the recovery option choose the bu40n fw then select the WH16NS60 firmware
Koolbite
Re: SDFtool Flasher
#1061 Post by Koolbite » Tue Jul 09, 2024 10:40 am
Billycar11 wrote: Mon Jul 08, 2024 11:02 pm
Yes it's not working. Drive seems to be flashed correctly but i can't read anything.
Will look for other solutions on the forum today. If not buy a new drive, keep this one in case i come across sombebody more knowledgeable sometimes..
And learn this lesson the hard way, not to mess with firmware stuff if you don't know what you're doing :evil:
Thanks anyway for your replies !
Re: SDFtool Flasher
#1062 Post by Billycar11 » Tue Jul 09, 2024 10:47 am
Koolbite wrote: Tue Jul 09, 2024 10:40 am
whats your makemkv drive info show now?
just saying i dont think your going to get anyone then knows more than us we wrote the guide and marty made the tool.
i have recovered many drives this exact way it works most times
Koolbite
Re: SDFtool Flasher
#1063 Post by Koolbite » Tue Jul 09, 2024 3:25 pm
Billycar11 wrote: Tue Jul 09, 2024 10:47 am
Here is the MakeMKV window :
https://ibb.co/jHGN7BV
If you can help me through this process it would be much appreciated. i can pay you a little fee for this if it works.
Re: SDFtool Flasher
#1064 Post by Billycar11 » Tue Jul 09, 2024 9:29 pm
Koolbite wrote: Tue Jul 09, 2024 3:25 pm
I see and did you test it before you flashed it?
What is the build date on the drive?
How it it hooked up to the PC direct SATA or what model USB adapter?
Koolbite
Re: SDFtool Flasher
#1065 Post by Koolbite » Wed Jul 10, 2024 9:03 am
Billycar11 wrote: Tue Jul 09, 2024 9:29 pm
You mean if i was using the drive before i flashed it ? Yes i had been extracting CDs and DVDs since i bought it in december 2021 until right before i flashed it.
I don't know where to find a build date. I don't see that information either on the packaging or the drive itself. But Like i said it was working until right before i flashed it so i think firware change is the cause and not the drive being too old (if that was the sens of your question).
It's an external model so i plug it through usb 3.0. Here is a capture of my device manager window : https://ibb.co/2c9Y41r (sorry it's in french but i think you still get the harware information)
Thanks !
