Ultimate UHD Drives Flashing Guide Updated 2025
Mr_Orange
#2326 Post by Mr_Orange » Tue Jun 04, 2024 9:20 pm
onoredikeidooo wrote:
Mon Jun 03, 2024 10:47 pm
Hey guys! I'll appreciate any help.
I own 2 Asus BW-16D1HT.
Drive 1 (manufactured on May/2018) is basically "about to die" (still works here and there but it's failing most of the time), did a great job during the rips/burns I did during this time and it's patched.
Informações da Unidade
Nome do dispositivo do SO: F:
Fabricante: ASUS
Produto: BW-16D1HT
Revisão: 3.10
Número de série: [REDACTED]
Data do Firmware: 2119-01-04 10:14
Sinalizações de criptografia bus: 1F
Firmware version: 3.10
Drive 2 (manufactured on November/2023) I got these days ago and I didn't patched yet.
Nome do dispositivo do SO: D:
Fabricante: ASUS
Produto: BW-16D1HT
Revisão: 3.11
Data do Firmware: 2120-12-01 17:59
Judging by the manufacture date and the firmware information above, is it safe to patch with the current Libredrive pack available here to download?
Thanks in advance!
Just flash it directly to 3.10MK and you're good to go.
Plane
#2327 Post by Plane » Sun Jun 09, 2024 10:21 pm
With Pioneer no longer being viable for buying new, what drives are recommended for quality?
Reviewing the drives listed, some clearly have quality issues and low ratings. And some have buy before a certain manufacture date.
It seems like the only buy new drives are poor quality, does one stand out as better quality?
#2328 Post by d00zah » Mon Jun 10, 2024 12:17 am
Pre-flashed/tested drives for whatever region you are in can be had...
Drives for sale, Flashing Services, where to buy...
Vendors request you contact them via email w/ questions (consult respective topics).
Plane
#2329 Post by Plane » Tue Jun 11, 2024 12:42 am
I am ok with attempting to flash a drive, so I am not looking to buy a preflashed drive. The flashing guide lists compatible drives, and comments that Pioneer drives are of higher quality, but are no longer viable do to an updated firmware. However no additional comments on drive quality, or ranking is made for other drives.
#2330 Post by Billycar11 » Tue Jun 11, 2024 2:00 am
drive quality rank here you go best to worst
Pioneer BDR S13UX
Pioneer BDR S13UBK
Pioneer BDR 213 212/S12
Pioneer BDR XS07, XD07, XD08
Pioneer BDR UD04, UD03, XD05
LG BU40N BP50NB40 BP60NB10 ect..
LG/ASUS WH14xx-WH16xx Asus BW16D1HT BH14xx-BH16xx ect... all the same junk if your getting one of these they are all the same get the cheapest available and hope you get a good one.
All pioneers need old FW or to be professionally flashed
for most i recommend the UBK as the UX is way over priced in the USA. the UX has a fw cents worth of better caps black paint job and slightly more sound deadening on the disc tray not worth it.
i myself have a UBK.
chronomac
#2331 Post by chronomac » Sat Jun 15, 2024 4:14 pm
Pioneer BDR S13UX
Pioneer BDR S13UBK
I'm not quite up to date on the Pioneer news so I'll just ask this simply: if I get a 212DBK, listed here on Amazon, today would I be able to use it for UHD discs, with or without new firmware?
#2332 Post by Billycar11 » Sun Jun 16, 2024 12:03 am
Pioneer BDR S13UX
Pioneer BDR S13UBK
It would need to be professionally flashed you can email me for that only the 212 for now is still remote flashable
JustSittingHere
#2333 Post by JustSittingHere » Sun Jun 16, 2024 1:24 am
Was not my question, but I'll take that answer also since I ordered that same 212DBK this morning and wondered later if it could read UHD.
Fate.
I'll be in contact tomorrow after I get the MakeMKV drive specs page.
#2334 Post by Billycar11 » Sun Jun 16, 2024 2:44 am
Fate.
no it wont read UHD it will need to be professionally flashed mail me for that if the fw is after 12/22 your out of luck but most 212s are old still
Wad Mabbit
#2335 Post by Wad Mabbit » Sun Jun 16, 2024 11:32 pm
I've got a portable BD writer SE-506
TSSTcorp BDDVDW SE-506CB
Revision: TS02
Serial number: [redacted]
Bus encryption flags: 1F
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 01.07
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
So, is this flashable?
#2336 Post by Woodstock » Mon Jun 17, 2024 1:56 am
Not for UHD support - the hardware won't do it.
Wad Mabbit
#2337 Post by Wad Mabbit » Mon Jun 17, 2024 2:49 am
Thanks for that :shock:
naruto
#2338 Post by naruto » Wed Jun 26, 2024 6:04 am
Dear everyone,
do you have any idea what I'm doing wrong?
I have the LG BU40N drive with Windows 10 and DVDFab 13 (13.0.1.9) and MakeMKV 1.17.7
My problem is now that I cannot rip the 4k UHD Blu-Rays "Avengers - Infinity War" and "Avengers - Endgame" with voices of the actors.
This means I can rip both discs to the hard drive and everything is fine except that the voices of the actors cannot be heard. The soundtrack, music, etc. can be heard perfectly but you cannot hear enything when the actors speak…
This happens with DVDFab and MakeMKV.
I flashed now the LG BU40N with SDFtool Flasher (v1.3.5) from 1.0 to 1.03 (The all you need firmware pack.zip) but still the same issue.
Any idea how to solve this?
Best regards
Mandolin
#2339 Post by Mandolin » Wed Jun 26, 2024 6:10 am
My laptop has no DVD so I'll need to find a USB drive that will be able to be flashed for UHD. I'd appreciate knowing a worthy one to get & where to find the software for flashing. Any help is greatly appreciated.
#2340 Post by d00zah » Wed Jun 26, 2024 3:56 pm
Have you read the 1st post of this topic, for starters?
