'Holes' (2003)
Nutball_UK
'Holes' (2003)
Post by Nutball_UK »
https://www.imdb.com/title/tt0311289/
Plays fine on DVD player (not attached to a pc)
Disc is not damaged, scratched ect
Drive is a few years old but not hammered - rips other discs fine as well as other of the same producer/studio
I assume its a new version of CP or something, its second hand been a while waiting to get time to rip to plex
Drive is Region 2 and disc is also Region 2
No idea if i need to do something special (Autistic / ADHD user)
Re: 'Holes' (2003)
Do you have a MakeMKV log you can copy & paste into the forum?
Nutball_UK
Re: 'Holes' (2003)
Sorry on not replying sooner - ended up trying on another dvd player (all regions) the first was just Region 2.
Though the disk was region 2 it didnt work in the first one
In the all region player worked fine - but the all region player wasnt mine so i sent the copy back with a rather polite note - which i also received a reply to!
The replacement worked and ripped perfectly
