staknhalo
Post by staknhalo » Tue Jun 25, 2024 7:37 pm
RESET_9999 wrote:
Tue Jun 25, 2024 3:08 pm
2- Windows Energy Player
whatever problems watching at the computer/windows platform aside - is that the best windows store dv player then outside of any official dv pcs player etc?
RESET_9999 wrote:
Tue Jun 18, 2024 5:04 pm
and it's only because I know him personally and I know that he always does all the necessary checks.
Some older framestor releases are wrong and I just checked the Captain America hybrid is still available on BHD even though it's a VERY different grade and the RPU is not even in sync with the BL.
Same for their Black Widow release and others.
You can pm the list of hybrids you're not sure and I can have a look if i can find them.
Framestor Mando S02E08 Hybrid UHD out of sync too - prob all the (d+ or iT/D?) stuff
Post by RESET_9999 » Tue Jun 25, 2024 9:42 pm
I never watched a movie with it so I don't know about its stability but as far as Dolby Vision decoding goes, it seems to do everything right (minus the same red push as the shield).
deadchip12
Post by deadchip12 » Tue Jun 25, 2024 10:30 pm
Oh damn I didn't know there's a media player that can play dolby vision on pc
Post by RESET_9999 » Tue Jun 25, 2024 11:08 pm
It doesnt trigger DV on your TV, you need a certified DV monitor for that. It decodes the DV metadata to HDR10 or SDR according to your EDID, the same as LLDV.
deadchip12
Post by deadchip12 » Tue Jun 25, 2024 11:17 pm
Yeah. Just noticed that in your spreadsheet. Dolby Vision scene remains dead on pc.
deadchip12
Post by deadchip12 » Wed Jun 26, 2024 4:27 am
Put Transformers: Rise of the Beasts (2023) in the list of web releases that is only cmv2.9. Just wasted a few hours downloading several versions of it; all are 2.9.
deadchip12
Post by deadchip12 » Wed Jun 26, 2024 12:37 pm
@RESET_9999 I'm testing The Marvels (2023), which is an HDR10 movie. I'm trying to inject DV cmv4.0 from the web release into the bluray one. Should I strictly follow the P8 hybrid tutorial or there's another way to inject DV so that the final file remains profile 7 mkv?
Post by RESET_9999 » Wed Jun 26, 2024 1:16 pm
Why would you want to do that? P7 is pointless without FEL. As far as DV quality goes: P7 FEL > P5 > P7 MEL = P8
I actually always convert P7 MEL to P8.
deadchip12
Post by deadchip12 » Wed Jun 26, 2024 10:34 pm
Does it have to be P8 ts or it can be P8 mkv? In the P8 hybrid tutorial the final file is ts
Post by RESET_9999 » Wed Jun 26, 2024 10:56 pm
TS/M2TS/MKV/MP4 are just video containers. They are unrelated to the DV profile and I was using the TS version in the video because back then, I didn't have the Ugoos and was still using my x800m2
deadchip12
Post by deadchip12 » Wed Jun 26, 2024 11:34 pm
What are the benefits of doing so? To remove the color difference caused by apple?
Post by RESET_9999 » Thu Jun 27, 2024 12:14 am
For better support on devices. I used to do that when I was using my TV internal player Plex and kept doing it even after getting the ugoos.
Also by doing this, I know that all my P7 rip are FEL even though it's easy and fast to find out with dovi_scripts
deadchip12
Post by deadchip12 » Thu Jun 27, 2024 1:49 am
What about the "color difference cause by apple"? Your spreadsheet says "Once removed (when converted to P8), the colors match." What file that needs to be converted to P8 here? The web releases?
Post by RESET_9999 » Thu Jun 27, 2024 2:48 am
this applies only to any P5 web-dl from itunes/appleTV.
deadchip12
Post by deadchip12 » Thu Jun 27, 2024 3:15 am
Ok.
I'm using workflow 7-3 to generate screenshots to compare brightness between the hdr10 bluray and DV stream. It says "PQ screenshots DVP5/HDR10 or SDR vs SDR (Libplacebo)".
Why DVP5? Can I still use this workflow if the DV stream is profile 8?
