#10111 Post by RESET_9999 » Tue Jun 25, 2024 11:08 pm
It doesnt trigger DV on your TV, you need a certified DV monitor for that. It decodes the DV metadata to HDR10 or SDR according to your EDID, the same as LLDV.
deadchip12
#10112 Post by deadchip12 » Tue Jun 25, 2024 11:17 pm
RESET_9999 wrote: Tue Jun 25, 2024 11:08 pm It doesnt trigger DV on your TV, you need a certified DV monitor for that. It decodes the DV metadata to HDR10 or SDR according to your EDID, the same as LLDV.
Yeah. Just noticed that in your spreadsheet. Dolby Vision scene remains dead on pc.
deadchip12
#10113 Post by deadchip12 » Wed Jun 26, 2024 4:27 am
Put Transformers: Rise of the Beasts (2023) in the list of web releases that is only cmv2.9. Just wasted a few hours downloading several versions of it; all are 2.9.
deadchip12
#10114 Post by deadchip12 » Wed Jun 26, 2024 12:37 pm
@RESET_9999 I'm testing The Marvels (2023), which is an HDR10 movie. I'm trying to inject DV cmv4.0 from the web release into the bluray one. Should I strictly follow the P8 hybrid tutorial or there's another way to inject DV so that the final file remains profile 7 mkv?
#10115 Post by RESET_9999 » Wed Jun 26, 2024 1:16 pm
Why would you want to do that? P7 is pointless without FEL. As far as DV quality goes: P7 FEL > P5 > P7 MEL = P8
I actually always convert P7 MEL to P8.
deadchip12
#10116 Post by deadchip12 » Wed Jun 26, 2024 10:34 pm
RESET_9999 wrote: Wed Jun 26, 2024 1:16 pm Why would you want to do that? P7 is pointless without FEL. As far as DV quality goes: P7 FEL > P5 > P7 MEL = P8
Does it have to be P8 ts or it can be P8 mkv? In the P8 hybrid tutorial the final file is ts
#10117 Post by RESET_9999 » Wed Jun 26, 2024 10:56 pm
TS/M2TS/MKV/MP4 are just video containers. They are unrelated to the DV profile and I was using the TS version in the video because back then, I didn't have the Ugoos and was still using my x800m2
deadchip12
#10118 Post by deadchip12 » Wed Jun 26, 2024 11:34 pm
RESET_9999 wrote: Wed Jun 26, 2024 1:16 pm I actually always convert P7 MEL to P8.
What are the benefits of doing so? To remove the color difference caused by apple?
#10119 Post by RESET_9999 » Thu Jun 27, 2024 12:14 am
deadchip12 wrote: Wed Jun 26, 2024 11:34 pm What are the benefits of doing so? To remove the color difference caused by apple?
For better support on devices. I used to do that when I was using my TV internal player Plex and kept doing it even after getting the ugoos.
Also by doing this, I know that all my P7 rip are FEL even though it's easy and fast to find out with dovi_scripts
deadchip12
#10120 Post by deadchip12 » Thu Jun 27, 2024 1:49 am
RESET_9999 wrote: Thu Jun 27, 2024 12:14 am
What about the "color difference cause by apple"? Your spreadsheet says "Once removed (when converted to P8), the colors match." What file that needs to be converted to P8 here? The web releases?
#10121 Post by RESET_9999 » Thu Jun 27, 2024 2:48 am
this applies only to any P5 web-dl from itunes/appleTV.
deadchip12
#10122 Post by deadchip12 » Thu Jun 27, 2024 3:15 am
RESET_9999 wrote: Thu Jun 27, 2024 2:48 am this applies only to any P5 web-dl from itunes/appleTV.
Ok.
I'm using workflow 7-3 to generate screenshots to compare brightness between the hdr10 bluray and DV stream. It says "PQ screenshots DVP5/HDR10 or SDR vs SDR (Libplacebo)".
Why DVP5? Can I still use this workflow if the DV stream is profile 8?
#10123 Post by RESET_9999 » Thu Jun 27, 2024 10:59 am
because 7-3 and 7-2 dont care about metadata, they only process the base layer of P8 P7 P5
sofakng
#10124 Post by sofakng » Fri Jun 28, 2024 2:44 pm
Is this lossless?
#10125 Post by RESET_9999 » Fri Jun 28, 2024 4:14 pm
yes
