Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
#61 Post by Coopervid » Tue Jun 18, 2024 9:18 am
dirtyrobinson wrote: Thu Jun 13, 2024 12:08 am I'm here for the same reason. Can this read play UHD discs?
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Check your PM
#62 Post by Coopervid » Tue Jun 18, 2024 9:19 am
MeeStaKlean wrote: Mon Jun 17, 2024 9:53 pm Hello Coppervid
Hello, Can you please Message me the flash code for UD03. Here is the screenshot of the drive.
https://ibb.co/9GXjYgw
Check your PM.
MeeStaKlean
#63 Post by MeeStaKlean » Tue Jun 18, 2024 12:58 pm
Good morning, thank you.
qops1981
#64 Post by qops1981 » Tue Jun 18, 2024 3:59 pm
I have a similar drive? Looks my my revision is much older than what other have posted too. May I also get the flash?
Current profile: DVD-ROM
Product: BD-RW BDRUD03AS
Revision: 1.00
Firmware date: 2014-04-01
Highest AACS version: 50
Drive platform: Pioneer RS8510
Firmware version: ID23
#65 Post by Coopervid » Tue Jun 18, 2024 8:53 pm
OS device name: G:
Revision: 1.14
Your PM will expire next Monday.
dirtyrobinson
#66 Post by dirtyrobinson » Wed Jun 19, 2024 11:24 pm
Coopervid wrote: Tue Jun 18, 2024 9:18 am Check your PM
There's no greater proof to "Not all heros wear capes". Thank you!!!
clwelch63
#67 Post by clwelch63 » Sat Jun 22, 2024 3:40 pm
Hi coopervid,
I'd like to flash my PIONEER BD-RW BDR-UD03 with the firmware that lets it read UHD discs. I see a lot of discussion about it, but don't see where to download the firmware. Is there a download site? Thanks in advance.
Here's my drive information:
OS device name: E:
Revision: 1.10
Firmware date: 2017-04-18
Firmware version: 1.10
csomebody1
#68 Post by csomebody1 » Tue Jun 25, 2024 1:42 am
I'm guessing the firmware on mine is too new, but is it possible to flash this drive to a firmware that can read a UHD disk?
Revision: 1.14
Highest AACS version: 76
#69 Post by Coopervid » Tue Jun 25, 2024 9:21 am
clwelch63 wrote: Sat Jun 22, 2024 3:40 pm Hi coopervid,
OS device name: E:
Revision: 1.10
PM sent.
#70 Post by Coopervid » Tue Jun 25, 2024 9:22 am
csomebody1 wrote: Tue Jun 25, 2024 1:42 am I'm guessing the firmware on mine is too new, but is it possible to flash this drive to a firmware that can read a UHD disk?
Revision: 1.14
PM sent.
#71 Post by Coopervid » Tue Jun 25, 2024 10:07 pm
qops1981 wrote: Tue Jun 18, 2024 3:59 pm I have a similar drive? Looks my my revision is much older than what other have posted too. May I also get the flash?
Revision: 1.00
I oversaw you. Check your PM.
#72 Post by Coopervid » Tue Jun 25, 2024 10:12 pm
Warning to people who don't read their PM. They will be deleted when they are one week old and unread. And then no further PMs will be sent.
csomebody1
#73 Post by csomebody1 » Fri Jun 28, 2024 4:22 am
Coopervid wrote: Tue Jun 25, 2024 9:22 am
Revision: 1.14
PM sent.
Got it! Thank you! I'll take a look at the documentation and try flashing the drive.
qops1981
#74 Post by qops1981 » Sun Jun 30, 2024 4:40 pm
Coopervid wrote: Tue Jun 25, 2024 10:07 pm
Thank you very Much!!
mas1701
#75 Post by mas1701 » Sun Jun 30, 2024 11:51 pm
is there any chance for UHD with this OEM USB3 BD-XL drive? When inserting an UHD disc, it only makes funny sounds, then stops.
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: ALDL2403xxxx
Firmware-Datum: 2018-08-22
Highest AACS version: 71
Firmware version: E101/ID26
After successfully flashing a first drive on Linux today and reading some of the previous posts, I'm at least a bit hopeful that there is an expert here who can help.
