John Wick 2 UHD Erroring Out at 24817GB on Two Different Discs
HanSolo551
Post by HanSolo551 »
Hey team, I know generally read errors are disc or hardware based so here is the troubleshooting I have done. To start I am using the John Wick Chapter 1-3 UHD disc set. John Wick 1 and John Wick 3 rip correctly.
I am using the following hardware to make rips.
  • BP60NB10 running BP60NB10 1.02MK
  • Windows 11
  • Writing to SSD
  • Using MakeMKV 1.77.7 registered.
I have tried two different chapter 2 discs in-case it was bad media. The drive works with other media leading me to believe it is not drive issue.
At 24817GB on both discs I can hear the drive start spinning up and down over and over trying to read until MakeMKV fails.
Final error I get is as follows:
  • Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '27624075264'
  • Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '27624075264'
HanSolo551
Re: John Wick 2 UHD Erroring Out at 24817GB on Two Different Discs
Further information: After failing the disc will not decrypt again now will the drive read any disc until unplugged and power cycled.
HanSolo551
Tested dual power plug, it also failed.
HanSolo551
At forced 2x speed I am able to force through but get a lot of errors on both discs. Is this just a bad series of discs?
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 31181064192, attempting to work around
Hash check failed for file 00000.m2ts at offset 31181236224, file is corrupt.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897826816, attempting to work around
Hash check failed for file 00000.m2ts at offset 32898017280, file is corrupt.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897826816-32897832960, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897832960, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897832960-32897839104, attempting to work aroundd
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897839104, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897839104-32897845248, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32897845248, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00000.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00000.m2ts at offset 32898213888, file is corrupt.
Hash check failed for file 00000.m2ts at offset 32931833856, file is corrupt.
Hash check failed for file 00000.m2ts at offset 32932227072, file is corrupt.
Too many hash check errors in file 00000.m2ts.
AV sync issue in stream 5 at 0:48:06.400 with duration of 64ms : audio gap - 2 missing frame(s)
AV sync issue in stream 2 at 0:48:06.335 with duration of 32ms : short audio gap was removed, audio skew is -31.333ms
AV sync issue in stream 3,4 at 0:48:06.304 with duration of 32ms : audio gap - 1 missing frame(s)
AV sync issue in stream 6 at 0:48:06.720 with duration of 32ms : audio gap - 1 missing frame(s)
HanSolo551 wrote: Tue Jun 25, 2024 10:20 pm At forced 2x speed I am able to force through but get a lot of errors on both discs. Is this just a bad series of discs?
You need a flashed Pioneer drive. Don't buy any stock drive on Amazon. New drives don't work for UHDs. Check the UHD drive and Libredrive section.
HanSolo551
I'm using the officially recommended drive. I don't need to use someone else's service unless the 2023 guide which has the BP60NB10 listed as supported is incorrect. If that is true i'll just request a refund on makeMKV and return everything.
BP60NB10, UHD Official External Slim 9.5mm USB 2.0 | Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
viewtopic.php?t=19634
I'm looking for technical solutions not just shotgunning "buy this vendors hardware".
HanSolo551
retrying at 1x max speed. Also ordered a second drive in case this one is DOA.
HanSolo551 wrote: Tue Jun 25, 2024 11:57 pm I'm using the officially recommended drive. I don't need to use someone else's service unless the 2023 guide which has the BP60NB10 listed as supported is incorrect. If that is true i'll just request a refund on makeMKV and return everything.
You are funny! Blaming Makemkv when the hardware is the root cause. You need an UHD capable Pioneer drive. I guess you know that joke beating a dead horse. If not I'm happy to post it here.
And in addition. You are too lazy to read what I posted. So get a life. No help from my side.
HanSolo551
If Pioneer is the only solution why are other drives listed as supported?
Pioneer drives are the best at dealing with problematic discs. It is unfortunate that Pioneer's current firmware disables LibreDrive functionality.
Obviously, your drive works for UHDs. You did rip JW 1 & 3 after all.
Using both USB plugs is the recommended way to go, since USB powered drives need all the power they can get.
Errors like that indicate that the drive is unable to correctly read that spot on the disc. A gentle cleaning is always recommended.
If a good cleaning doesn't get you past the troublesome spot (on either of your copies), the next best thing is to try a different drive. It is remarkable how often the same disc in a different drive produces different results.
Or, maybe, the disc is damaged and even with an expensive Pioneer drive, it would fail. JW2 is probably a triple-layer BD100 disc. These are always the hardest for any drive to read correctly since the data density is the highest of any disc in use today.
HanSolo551 wrote: Wed Jun 26, 2024 12:34 am If Pioneer is the only solution why are other drives listed as supported?
ok i will remove them ... lol but no its needed as most people dont buy from me.
pioneers are the only drive i recommend now as long as you get can them with old firmware you should
HanSolo551
dcoke22 wrote: Wed Jun 26, 2024 3:26 am Pioneer drives are the best at dealing with problematic discs. It is unfortunate that Pioneer's current firmware disables LibreDrive functionality.
Taking your advice, getting a second drive to test with. I noticed the laser module on this unit seems a bit sticky near the middle of the track. Wonder if that causes issues. I will have two copies of the blu-ray and two copies of the drive to test with. JW3 is also triple layer and works so i know some discs work.
HanSolo551
It was a bad drive. I replaced the drive and could read the discs i had trouble with before.
