Chris Kelly
Re: Pioneer firmware update February 2023
Post by Chris Kelly » Tue Jun 25, 2024 9:16 am
I just upgraded my BDR-212UBK from 1.02 to 1.05. It's no longer a libreDrive. I wish I discovered this thread before I did this. I do believe in firmware updates for the sake of bug fixes, read/write issues with certain discs, etc.. At least with LG, MK firmware is released not long after the official firmware. If you have a Pioneer drive that's a LibreDrive in MakeMKV, don't update it to anything starting from the end of 2022 unless a miracle happens, and if it does, find out the next threshold date before you lose LibreDrive in MakeMKV again.
dizzy
Post by dizzy » Wed Jun 26, 2024 6:12 am
Sorry if this is a stupid question: I just got a new Pioneer drive off Amazon:
Manufacturer: PIONEER
Product: BD-RW BDR-213M
Revision: 1.05
Serial number: ...
Firmware date: 2023-08-01
Highest AACS version: 78
Drive platform: Pioneer RS9200
Firmware version: ID56
Now, I have 0 interest in UHD/4k (I don't own any 4k discs and have no plans to ever buy one) but I do care about everything else LibreDrive offers (disabling forced revoked host certificate lists, no region locking, etc). Does that mean that I should return the drive and get one from Billy?
Also, I just successfully ripped a BluRay using this new Pioneer drive (the same disc was returning errors in my older LG WH14NS40 1.02 drive that has full LibreDrive support) and it said it opened the drive in "direct disc mode" which (after some Googling) seems to be the same as LibreDrive, so I'm very confused as to if I need a special firmware or not to get those LibreDrive features (again, don't care about 4k).
Post by Billycar11 » Wed Jun 26, 2024 6:29 am
dizzy wrote: Wed Jun 26, 2024 6:12 am Sorry if this is a stupid question: I just got a new Pioneer drive off Amazon:
Revision: 1.05
Serial number: ...
direct disc mode is not the same as libredrive + that only libredrive can get around buss encryption and revoked host certificates.
but for the most part its only needed for 4K most times makemkv will be updated so support new aacs versions.
Post by dcoke22 » Wed Jun 26, 2024 2:15 pm
MakeMKV works pretty well for DVDs and regular blu-rays with almost any blu-ray capable drive. If you want to rip 4K UHDs, then you must get a drive that supports LibreDrive. Since you don't care about 4K, then you don't need it.
However, there are certain edge cases where not having LibreDrive might cause you some difficulty. Billycar11 mentioned AACS versions. AACS is occasionally updated to a newer version. LibreDrive capable drives can rip blu-rays with the newest AACS even if MakeMKV does not yet have explicit support for it. Without LibreDrive, you might have to wait until a new version of MakeMKV is released with explicit support for that version of AACS before you can rip a new disc.
In my view, using a drive without LibreDrive support is fine, especially if you're using an existing drive you already have. If you're going to buy a new drive, it makes the most sense to get one that can support LibreDrive, even if you don't want to rip 4K discs. Pioneer drives are generally more reliable than other brands of drives. Pioneer's firmware situation means buying a drive from a seller in your region. Unless you have a strong aversion to it (or got a great deal on your current drive), I'd return the drive you bought and buy a LibreDrive capable drive from a seller. Your new-drive-money might as well buy you freedom from rare edge cases as well.
dizzy
Post by dizzy » Wed Jun 26, 2024 10:43 pm
Thanks, that clears out some things.
I guess it comes down to $$$. I paid $120 for the drive (which according to camelcamelcamel seems to be the only price it's been at, from the "Pioneer Store"). That's more than double vs getting an LG WH14NS40 (that also happens to be Libre Drive compatible). If the Pioneer doesn't last at least twice the time the LG would last then I just wasted some money.
Now Billy's version would be ~$100 more, almost double than the Pioneer base price. Just to be clear, the pricing for what's on offer is probably fine, I just have a bit of conundrum from where I'm sitting at because I don't need UHD. Following the same logic if this drive doesn't last 4 times more than the LG drive then I'd be really wasting money :)
Post by Billycar11 » Thu Jun 27, 2024 1:09 am
dizzy wrote: Wed Jun 26, 2024 10:43 pm Thanks, that clears out some things.
i have had lg/asus drives last 0 days so yes pioneers last more than 4 days worth it ! lol
BaiDuYunPan
Post by BaiDuYunPan » Mon Jul 01, 2024 1:28 pm
Hello guys, can anyone tell me how to apply the patch or how to make him able to rip UHD?
Thank you
OS device name: F:
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: CADL000339CN
Firmware date: 2022-07-26
Highest AACS version: 81
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
InfinityX
Post by InfinityX » Mon Jul 01, 2024 4:35 pm
BaiDuYunPan wrote: Mon Jul 01, 2024 1:28 pm Hello guys, can anyone tell me how to apply the patch or how to make him able to rip UHD?
Thank you
OS device name: F:
Revision: 1.03
you have a UHD ready unit version 1.03 is the latest version supported by libedrive, what error do you get?
BaiDuYunPan
Post by BaiDuYunPan » Tue Jul 02, 2024 4:19 am
InfinityX wrote: Mon Jul 01, 2024 4:35 pm
Thank you
OS device name: F:
Revision: 1.03
It shows that it cannot be decrypted, thank you.
Downloading latest HK to C:\Users\百度云盘/.MakeMKV ...
Saved AACS dump file as C:\Users\百度云盘/.MakeMKV/MKB20_v77_The_wandering_earth_E3F2.tgz
Backup failed
Todd_2003
Post by Todd_2003 » Fri Jul 26, 2024 12:36 am
Hello. I'm having the same issue with a too current Firmeware version on the Pionner BDR-S13U-X, I have Revision 1.04 from 12-12-2022. I bought the drive from Amazon a few months ago because it was the "best" according to many reviews, but now I'm seeing the huge limitation with UHD 4k movies. Any fix in sight yet? Thank you!
Post by Billycar11 » Fri Jul 26, 2024 12:51 am
Todd_2003 wrote: Fri Jul 26, 2024 12:36 am Hello. I'm having the same issue with a too current Firmeware version on the Pionner BDR-S13U-X, I have Revision 1.04 from 12-12-2022. I bought the drive from Amazon a few months ago because it was the "best" according to many reviews, but now I'm seeing the huge limitation with UHD 4k movies. Any fix in sight yet? Thank you!
Nah sorry man if you can return it.
I have those with old fw if you want one.
See below
Vaako
Post by Vaako » Fri Aug 02, 2024 2:45 pm
Where can I download the LibreDrive firmware for the Pioneer BDR-212EBK or does it need some other UHD firmware ?
Post by Coopervid » Fri Aug 02, 2024 2:47 pm
Vaako wrote: Fri Aug 02, 2024 2:45 pm Hi,
Post you Makemkv info.
Vaako
Post by Vaako » Fri Aug 02, 2024 8:27 pm
Coopervid wrote: Fri Aug 02, 2024 2:47 pm
The drive is a Pioneer BDR-212EBK but it identify as an BDR-212M is that correct or is this a issue ?
OS device name: L:
Product: BD-RW BDR-212M
Revision: 1.05
Serial number: TDDL002894WL
Post by Coopervid » Fri Aug 02, 2024 8:31 pm
Vaako wrote: Fri Aug 02, 2024 8:27 pm
OS device name: L:
Revision: 1.05
Your drive is f...d. Firmnwares after 12/2022 can't be flashed.
