LibreDrive for Pioneer drives
Chris Kelly
Post by Chris Kelly » Tue Jun 25, 2024 7:59 am
Will support for Pioneer drives with upgraded firmware eventually be supported? Unaware I'd lose compatibility, I upgraded my BDR-212UBK from 1.02 to:
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.05
Serial number: TKDL001706WL
Firmware date: 2023-08-01
Highest AACS version: 77
Drive platform: Pioneer RS8F01
Firmware version: ID58
At least I still have my LG drives for backup.
Post by MartyMcNuts » Tue Jun 25, 2024 8:04 am
Chris Kelly wrote: Tue Jun 25, 2024 7:59 am Will support for Pioneer drives with upgraded firmware eventually be supported? Unaware I'd lose compatibility, I upgraded my BDR-212UBK from 1.02 to:
Revision: 1.05
Who knows?? Let's put it this way. It has been worked on for almost 18 months and as yet, nothing has happened. I wouldn't hold my breath!
Why update the firmware? There really isn't ever a need to do this.....
Chris Kelly
Post by Chris Kelly » Tue Jun 25, 2024 8:33 am
MartyMcNuts wrote: Tue Jun 25, 2024 8:04 am
Revision: 1.05
Unless there's a danger to it, I have a habit of upgrading firmware on all my gear to insure latest compatibility, the latest bug fixes, etc.. What can I say. My bad. I should have given it more thought. I vaguely remember upgrading from an earlier firmware to 1.02 and didn't think it would be a problem, which it wasn't if I did. I guess Pioneer caught up with MakeMKV. Oh well. It was nice while it lasted. Time to go back to my LG WH16NS40 for 100GB and WH16NS60 for 66GB. I'll explain more about that in LG threads.
Post by Billycar11 » Tue Jun 25, 2024 10:11 am
Revision: 1.05
big oooofff
rip a good pioneer
but yeah bluray drives with libredrive dont update them ever
Chris Kelly
Post by Chris Kelly » Tue Jun 25, 2024 1:32 pm
Billycar11 wrote: Tue Jun 25, 2024 10:11 am
Revision: 1.05
big oooofff
rip a good pioneer
At least I still have my Pioneer for 1080p Blu-rays and SD DVDs. And while not anytime soon, who knows. Maybe Mike might figure out another work-around. If he does, I'll find out what the latest firmware compatible with that work-around is won't perform an update if it either hasn't been tested or is not compatible.
Nectem
Post by Nectem » Wed Jun 26, 2024 10:00 am
is there any way for the following drive to accept/recognize 4k blurays ?
Thanks in advance for your help.
Laufwerksinformation
OS-Gerätename: F:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 8.11
Serienummer: removed
Firmware-Datum: 2014-01-16
Highest AACS version: 63
Drive platform: RS8600
Firmware version: 8.11/ID52
Post by Billycar11 » Wed Jun 26, 2024 10:03 am
Nectem wrote: Wed Jun 26, 2024 10:00 am Hello,
OS-Gerätename: F:
Produzent: PIONEER
Revision: 8.11
yes i can help you with that email see contact info below
Post by Billycar11 » Wed Jun 26, 2024 10:04 am
Chris Kelly wrote: Tue Jun 25, 2024 1:32 pm
fyi you can get a 212d/v cheap and email me for a flasher for that
those for now are still being sold with old FW
dizzy
Post by dizzy » Thu Jun 27, 2024 6:08 pm
Are you saying that getting a BDR-212DBK off Amazon (https://www.amazon.com/dp/B081R5CS4L) or the BDR-212V (btw, any significant difference between these 2?) would likely come with patchable firmware? (no UHD support obviously but can still enable Libre Drive support?) Then I can return the BDR-213M and just get that instead. Unless there are other drawbacks to doing that (other than losing UHD support).
Post by Billycar11 » Thu Jun 27, 2024 8:42 pm
dizzy wrote: Thu Jun 27, 2024 6:08 pm Are you saying that getting a BDR-212DBK off Amazon (https://www.amazon.com/dp/B081R5CS4L) or the BDR-212V (btw, any significant difference between these 2?) would likely come with patchable firmware? (no UHD support obviously but can still enable Libre Drive support?) Then I can return the BDR-213M and just get that instead. Unless there are other drawbacks to doing that (other than losing UHD support).
Yeah and I can enable UHD support
phazer11
Post by phazer11 » Fri Jun 28, 2024 8:14 pm
So, just ordered one of the BDR-212DBK off Amazon from that link. At the least the one from my local amazon warehouse seems to say manufacture date Jan 2024. I'll confirm when I get home, had someone grab it for me when they took the dog out since it's storming. Do they generally ship with older firmware or should I just cut my losses if I confirm the 2024 date?
Post by Billycar11 » Fri Jun 28, 2024 11:15 pm
phazer11 wrote: Fri Jun 28, 2024 8:14 pm So, just ordered one of the BDR-212DBK off Amazon from that link. At the least the one from my local amazon warehouse seems to say manufacture date Jan 2024. I'll confirm when I get home, had someone grab it for me when they took the dog out since it's storming. Do they generally ship with older firmware or should I just cut my losses if I confirm the 2024 date?
Depends on fw date not build date some company's can get new drives flashed with old fw from pioneer.
Just email me the makemkv drive info section.
PandaMan86
Post by PandaMan86 » Sat Jun 29, 2024 1:27 am
I have just purchased a new bdr-212v. Looking for a way to flash it to the proper firmware.
Post by Billycar11 » Sat Jun 29, 2024 1:42 am
PandaMan86 wrote: Sat Jun 29, 2024 1:27 am I have just purchased a new bdr-212v. Looking for a way to flash it to the proper firmware.
just email me see below
Fighter96123
Post by Fighter96123 » Sat Jun 29, 2024 5:26 pm
Hi there,
is there any way for the following drive to accept/recognize 4k blurays?
OS-Gerätename: \Device\CdRom1
Produzent: PIONEER
Produkt: BD-RW BDR-XD08
Revision: 1.00
Serienummer:
Firmware-Datum: 2022-04-03
Highest AACS version: 78
Drive platform: Pioneer RS9330
Firmware version: GENE
