sorry man no way to flash that just return it and get a pioneer with old fw from a seller in your regionPKTapes wrote: Wed Jun 12, 2024 11:53 pm I need some assistance with this drive too. It refuses to rip UHD discs in MakeMKV.
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: [redacted]
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Firmware version: ID05
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Not going to do UHD. Locked out by Pioneer. All Pioneer firmware after 12/22/2022 is blocked from allowing UHD except with software approved by Pioneer, and MakeMKV isn't it.Manufacturer: PIONEER
Hi Coopervid
Looking to flash my BDR-XD07 for UHD. Coopervid, could you PM me?
BDR-XS07
Revision: 1.01
Firmware date: 2020-09-03
Thank you so much
BDR-XS07
Revision: 1.01
Thank you so much
You need to be specific: Is it a XD07 or a XS07?sanlin wrote: Sun Jun 23, 2024 10:16 am Hi Coopervid
BDR-XS07
Revision: 1.01
Thank you so much![]()
PM is coming.
Do you happen to have one for mine as well?
OS device name: /dev/rdisk5
Revision: 1.03
Serial number: redacted
Highest AACS version: 81
Yours is f...d since the firmware is newer than Dec. 2022.
Oh okay :/ Hopefully Mike gets it working
Hi Coopervid,
I would like to flash my BDR-XD07 for UHD. Could you PM me?
Thank you very much.
OS device name: E:
Product: BD-RW BDR-XD07
Revision: 1.01
Serial number: RLDL00xxxxxP
Firmware date: 2018-12-03
Drive platform: Pioneer RS8D30
Firmware version: ID36
OS device name: E:
Revision: 1.01
Hello, I just bought my very first blu-ray drive and any help would be greatly appreciated.
OS device name: F:
Revision: 1.01
Serial number: SAD********P
OS device name: F:
Revision: 1.01
email me for a flasher if you want to do UHDliomixdan wrote: Fri Jul 26, 2024 9:37 pm Hello, I just bought my very first blu-ray drive and any help would be greatly appreciated.
OS device name: F:
Revision: 1.01
PM sentphonitor wrote: Thu Jul 25, 2024 11:22 am Hi Coopervid,
OS device name: E:
Revision: 1.01
Hello Coopervid,
I have a similar drive to the one previously mentioned. Could I please get a PM from you if possible?
OS device name: F:
Revision: 1.01
Thank you!
OS device name: F:
Revision: 1.01
Thank you!
