Blu rays not mounting
TrueNerd
Post by TrueNerd » Mon Aug 22, 2011 11:29 pm
I'm on OS X 10.6.8 and I have MakeMKV 1.6.14. I have an external Optiarc BD-ROM 5500S drive. MakeMKV has no problems recognizing regular DVDs in the Optiarc but when I put a blu ray in (I've tried a bunch), it tells me there is no disc. I used both OS access mode and DASPI mode. I've been looking for solutions online for the last two hours to no avail. Can anyone help?
Re: Blu rays not mounting
Post by mike admin » Wed Aug 31, 2011 10:34 am
Do you see the BD drive mounted in finder, when MakeMKV is not running? If not, then it's bad drive.
nicholas_d
Post by nicholas_d » Fri Nov 18, 2011 7:10 pm
I am having the same issue. I had by blu ray replaced and still have the SAME issues. I can say it is not a bad drive. ANy other ideas?
It is a LG external blu ray burner that I use...everything was fine up to about a month or two ago and ever since with the old drive/new drive nothing will "mount"
jp5fuel
Post by jp5fuel » Mon May 14, 2012 9:33 pm
I am having similar issues with an OWC Slim Blu-ray External Drive. Drive works perfectly fine reading DVD but fails to read any Blu-ray disk. Returned external drive to OWC and they say it tests just fine and that I require macblurayplayer to view/read a blue-ray disk? I think they are full of it and there is something else going wrong. When I insert a Blu-ray disk, it attempts to read and then returns with a whole bunch of error messages that say things ilke "could not open disk". Any thoughts on why it's not working?
