MakeMKV v1.6.14 failing with Black Swan bluray
A_Man_Eating_Duck
Post by A_Man_Eating_Duck » Wed Aug 24, 2011 7:28 am
I'm trying to do a full disk backup of the Black Swan bluray with MakeMKV v1.6.14 and it throws up some debug messages and fails.
Debug log started at Wed Aug 24 07:14:59 2011 , written by MakeMKV v1.6.14 win(x64-release)
001005:0000 MakeMKV v1.6.14 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\A Man Eating Duck/MakeMKV_log.txt
005072:0000 Backing up disc into folder "D://backup/BLACK_SWAN"
DAFD=PAAAADAAAAEABDQUEAAACAQ==
DCE=FIsB7D3m7Rca+rMM1rcKDKB/JWN0lXKCtwyeTuwu/RtwNCXhXKbInpEWjWsAMK+qJBkI+SBIuKMtGtVXJebExF4+XL0YT3E07j/vOSzVrRpRs8F7bkzR3d9wbuwWpiJrfxkFUJbJIY6GcfanUKmgmFiwp318wQ02JA==
003317:0000 Loaded 22 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00002.svq
003332:0000 Saved BD+ dump file as C:\Users\A Man Eating Duck/.MakeMKV/dump_Black_Swan_B97C3F3572A55953.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
001003:0020 DEBUG: Code 3 at <=!W.G2gf<'g2HuV"!jzy:121261750
001003:0020 DEBUG: Code 0 at haX&aAhi$Al\zWF894Mo:121268949
001003:0020 DEBUG: Code 0 at haX&aAhi$Al\zWF894Mo:121266994
001003:0020 DEBUG: Code 0 at haX&aAhi$Al\zWF894Mo:213142542
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Wed Aug 24 07:17:18 2011
I'm not sure what the problem is.
I hope this is enough info to debug the problem.
(720.06 KiB) Downloaded 440 times
Re: MakeMKV v1.6.14 failing with Black Swan bluray
Post by mike admin » Wed Aug 31, 2011 10:01 am
The program failed because the directory
is somehow incorrect. I guess the double slash is the problem.
A_Man_Eating_Duck
Post by A_Man_Eating_Duck » Sat Sep 03, 2011 3:49 am
I think you may have picked up on another bug.
In the preferences, Video tab, the default destination.
I have mine set to SemiAuto D:/
But when you look in the log it appears like this
Backing up disc into folder "D://backup/SERIOUS_MAN"
and it copies just fine.
if i set the output location to D:\ it shows up as
Backing up disc into folder "D:\/backup/SERIOUS_MAN"
in the log and still copies fine.
Post by mike admin » Sun Sep 04, 2011 9:17 am
Maybe, but what your error log shows, that the program failed to create output directory for backup with error "path is incorrect". Maybe disk D: was reassigned?
