I have successfully backed up all my 4k movies except for the back to the future 4k trilogy. when I back it up every so often in the movie the colors are messed up. I have bought a new copy of them and still got the same issue. Is there anything I can do?
thanks robo
back to the future trilogy 4k
Re: back to the future trilogy 4k
Does your MakeMKV log show anything when you're ripping a Back to the Future movie?
Is the behavior the same if you try different playback software?
Radiocomms237
And is the problem consistent, IE. does the same thing happen at the same place in each movie every time?
(Just trying to establish whether it may be the player or the file at fault?)
I have this UltraHD trilogy in my (seemingly endless) 'to-do' list so, if you're unable to solve the problem, and can described exactly what's happening and where in each movie, then I can dig it out and see if mine is the same?
roboticrocket
I have backed it up twice just recently and compared the two. The video does a weird color thing where the colors are almost inverted. the only thing the log says is a av audio sync with some subtitles cause there is none there. but unless there is a menu for more logs thats all i get.
csomebody1
I tried to rip mine tonight and get all sorts of errors on all 3 disks! The backup option just fails and if I try to rip MKV files, many files are corrupt.
Here are just some of the errors when trying to rip to MKV.
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Using Java runtime from C:\Program Files\Java\jre-1.8\bin\java.exe
File 00156.mpls was added as title #0
File 00157.mpls was added as title #1
File 00600.mpls was added as title #2
File 00100.mpls was added as title #3
File 00130.mpls was added as title #107
File 00131.mpls was added as title #108
File 00132.mpls was added as title #109
File 00133.mpls was added as title #110
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00282.m2ts' at offset '0'
Title #00134.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00283.m2ts' at offset '0'
Title #00137.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00286.m2ts' at offset '0'
Title #00138.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00287.m2ts' at offset '0'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00289.m2ts' at offset '0'
Title #00141.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00290.m2ts' at offset '0'
Title #00146.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00291.m2ts' at offset '0'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00340.m2ts' at offset '0'
Title #01062.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00330.m2ts' at offset '0'
Title #00844.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00296.m2ts' at offset '0'
Title #01068.mpls was skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00365.m2ts' at offset '0'
Error 'Scsi error - UNIT ATTENTION:NOT READY TO READY CHANGE, MEDIUM MAY HAVE CHANGED' occurred while reading '/BDMV/STREAM/00365.m2ts' at offset '0'
