backing up my hd-dvd's audio help
RobTi
#1 Post by RobTi » Sat Aug 27, 2011 3:21 pm
Hi i am finally looking to back up my HD-dvd's and have hit a problem they are backing up with an E-AC-3 audio track (using any dvd and makemkv)
Now my amp only supports dd5.1\dts and they are playing in 2 channel but showing as a 3\2.1 track in vlc
So before i go any further (tried 3 discs all the same result) is this correct makemkv is backing them up okay with the DD+ audio and its just bad luck that my amp doesnt play them.
If this is correct is there anyway around it, i would like to have them all backed up as original and later on get a suitable amp, but get a DD5.1 sound now(will be using Mp with SAF to play them)
Robert
Re: backing up my hd-dvd's audio help
#2 Post by mike admin » Wed Aug 31, 2011 9:37 am
Yes, MakeMKV just puts e-ac3 streams as is. You can use application called eac3to to transcode MKV files with such streams.
