Dial M For Murder Blu Ray Rip
wunderlong88
Post by wunderlong88 »
I am trying to rip 1954 Dial M For Murder Blu Ray.
I keep getting an error. I don't know much about all of this and am hoping someone can help or point me in the right direction.
I have attached a log.
Thank you!
Re: Dial M For Murder Blu Ray Rip
No log attached. You can insert the relevant parts in the message between code tabs [code][/code].
Without the error, it's impossible to tell what the problem is.
wunderlong88
How do I know what the relevant part is?
wunderlong88
Is this all you need?
 005003:0000 Failed to save title 3 to file L:/Test 2/Dial M for Murder (1954) - Own Blu2.mkv
002023:0000 Encountered 46 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=46 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 32 unclassified errors
error=0xC000009C count=32 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 2 failed
005037:0204 Copy complete. 0 titles saved, 2 failed.
Application exited at Fri Jun 21 21:55:35 2024
wunderlong88
Here some more that talks about "error"
 Debug log started at Fri Jun 21 13:27:56 2024 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Linda/MakeMKV_log.txt
005075:0000 The new version 1.17.6 is available for download at http://www.makemkv.com/download/
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF  v098: HL-DT-ST_BDDVDRW_UH12NS30_1.00_211306131457_K94DAMC0355
No  SDF v098: ATAPI_iHAS124___Y_BL0V_L159ZLANTneK
SDF id v098: ATAPI_iHAS124___Y_BL0V_L159ZLANTneK
001011:0000 Using LibreDrive mode (v06.3 id=D1C17F787A5D)
DEBUG: Code 2147483648 at Nx*e^{R_\6h/]Oy7:121265499
001003:0020 DEBUG: Code 0 at Nx*e^{R_\6h/]Oy7:29398070
DISCID=D4B215DC80AA9FD40A07D8AC8976CE88B53FD553
003025:0000 Title #00052.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00120.mpls has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00055.mpls was added as title #0
003025:0000 Title #00403.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00404.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00100.mpls was added as title #1
DEBUG: Code 70 at Kq7-%]\zwwjX?&I]b:213137275
003307:0000 File 00098.mpls was added as title #2
003307:0000 File 00103.mpls was added as title #3
003307:0000 File 00101.mpls was added as title #4
003025:0000 Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00076.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00077.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00078.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00079.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00134.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00136.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00100.m2ts was added as title #5
003307:0000 File 00101.m2ts was added as title #6
005014:0000 Saving 1 titles into directory file://L:/Test 2
001003:0020 DEBUG: Code 3221225628 at w.G,[.W,J~s[OWwzq<.Q$D1P:121262371
001003:0020 DEBUG: Code 3221225628 at spDZ-<~\bXU:/9Ia:213130559
001003:0020 DEBUG: Code 100864261 at Hu0Y6$"G%/26#v|y:121271617
001003:0020 DEBUG: Code 100864261 at spDZ-<~\bXU:/9Ia:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00069.m2ts' at offset '21040005120'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '21046493184'
DEBUG: Code 3221225628 at XLZy#@p!6m/^{4B`f):29394896
001003:0020 DEBUG: Code 3221225628 at XLZy#@p!6m/^{4B`f):213131502
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00069.m2ts' at offset '21046493184'
DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):29394896
001003:0020 DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):213131502
001003:0020 DEBUG: Code 0 at .{9B4[Fe jYP ZH8Jl]t:29395471
001003:0020 DEBUG: Code 0 at DB!^@B"@;hWJ_7EETUQ@:29394068
001003:0020 DEBUG: Code 0 at .{9B4[Fe jYP ZH8Jl]t:213131157
001003:0020 DEBUG: Code 0 at .{9B4[Fe jYP ZH8Jl]t:121262647
001003:0020 DEBUG: Code 10276608 at .{9B4[Fe jYP ZH8Jl]t:121261773
001003:0020 DEBUG: Code 0 at |03L4Qet`E.eCrMo,`Zs':213137068
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29394022
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29404878
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29405384
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29403383
001003:0020 DEBUG: Code 0 at _m/rhT44"V1.WQmL:213132537
001003:0020 DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121264464
001003:0020 DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121263912
001003:0020 DEBUG: Code 0 at S+CKH[[Cjt"K.94+):213130145
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
---- Failed L:/Test 2/Dial M for Murder_t02.mkv
ch_0        3601257660000 0
ch_1        3602158560000 0
ch_2        3603059460000 0
ch_3        3603960360000 0
ch_4        3604861260000 0
ch_5        3605762160000 0
ch_6        3606663060000 0
wunderlong88
I can play the blu ray just fine (in 2d) from my blu ray player (hooked to tv). But I still can't get it ripped. It will rip the extras only. Sure hoping someone can help as I have no idea what to do.
Errors like that indicate the optical drive was unable to correctly read a spot on the disc. Often this is because the disc is dirty. The standard advice is to gently clean the disc and try again.
wunderlong88
I will clean and try again. There are 2 extras, which rip fine and 4 versions of the movie, none of which rip. I hope this fixes it.
TY
wunderlong88
Cleaning didn't help, urgh!
It doesn't look scratched or damaged or bad at all.
TY
wunderlong88
https://www.makemkv.com/errors/read/
How do I "The simple workaround is to copy all files from the disc to the hard drive manually, without MakeMKV running. If you succeed in this, there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later."
I don't know how to copy the files from the disc manually. When I try to find instructions everything points me to ripping which I can't get it to do. Wanted to try this.
Do I just drag them to my hard drive?
If I get them on my harddrive how do I "there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later."?
Do you have a different optical drive you can try the disc in? It is remarkable how often the same disc in a different drive produces different results.
It is unlikely to work, buy you could also try to make a decrypted backup of the disc. On the first screen of MakeMKV, in the row of icons along the top there's one with a yellow folder with a green arrow. That will start you down the path of making a backup of the disc instead of ripping a specific title. If that works, you can open the backup in MakeMKV and create .mkv files from the backup.
wunderlong88
I have another drive but it is only dvd. I am able to get a refund from the seller so I am going to do that and buy another copy.
