Hey all,
Just getting back to backing up my stuff. Trying out MKV as SlyS is dead. My issue is when I try to create a MKV file there is no audio for the movie even though the box is checked. I attempted to create a complete backup but the audio that is ripped ends up being a commentary track.
Any help is much appreciated. Sorry if the is not the correct spot for this post. Advise and I will move it.
Thanks in advance for your time and assistance.
Here is my drive info:
OS device name: L:
Product: BDDVDRW UH12NS30
Revision: 1.00
Serial number: [redacted]
Firmware date: 2113-06-13 14:57
Bus encryption flags: 16
Highest AACS version: 81
Drive platform: MT1939
Firmware version: 1.00
BD raw metadata read: Partial
Disc Information
Label: Enter the Ninja
Timestamp: 2023-08-15 10:12:43
Protection: AACS v81
Data capacity: 32.75 Gb
Disc type: BD-ROM
Number of layers: 2
MKV newb needs help
Re: MKV newb needs help
What are you trying to do?
The drive is not capable of dealing with UHD (it was built 2 years before the standard was released). As such, it isn't really necessary for it to do LibreDrive, because it will do what it does without additional software.
As for the audio, are you sure your playback software understands the audio?
NotARobot
I am try to make backups of my movies to watch on Plex. I've used the drive to backup 100s of BD in the past.
....pebkac...different PC from my old HTPC. Playback software was the issue, lol. Trying to do one disc for 3 days.
Thanks for the help WoodStock!
Would I need a new drive for 4k?
dvdcompare.net says most versions Enter the Ninja only have DTS audio. Is that what your copy has? Can your playback software play DTS audio? I don't think Windows Media Player can play DTS by default. VLC should be able to play DTS.
Yes you need a different drive for UHD see guide below for that and if you want the better pioneer UHD drives email me for one with old fwNotARobot wrote: Wed Jun 19, 2024 4:09 pm I am try to make backups of my movies to watch on Plex. I've used the drive to backup 100s of BD in the past.
