Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Wad Mabbit
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Post by Wad Mabbit »
OK, I'll get of those. What's the advantage of the Archgon?
coopdeloop
Post by coopdeloop »
Coopervid wrote: Sun Jun 16, 2024 10:08 pm
Zips9280 wrote: Sun Jun 16, 2024 4:48 pm
Coopervid wrote: Sun Jun 16, 2024 9:46 am
Read your PM.
Point me in the correct direction sir!
U got mail.
Hello, Looking for help in finding a USA Slim drive for UHD. My pioneer works great for blus but have some UHDs I'd like to back up. The easier to set up the better for me. TIA
kbook wrote: Sat Jun 15, 2024 10:51 pm Hi I lived in USA and would like a recommendation for internal and external drives. Thanks
Read your PM.
Your PM will expire next Monday.
m64bert wrote: Sat Jun 15, 2024 10:09 pm Looking for 5.25 inch drive in Sweden.
coopdeloop wrote: Tue Jun 18, 2024 7:46 pm
U got mail.
Tell me what Pioneer drive you have.
Johanna12221
Post by Johanna12221 »
Hi! I'm new to this and I'm trying to find which drive to buy. I'm located in Sweden.
Edit: Preferably looking for a 5,25" drive, external could be fine if it doesn't exists
insanthony
Post by insanthony »
I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything. :D
Zips9280
Post by Zips9280 »
Coopervid wrote: Tue Jun 18, 2024 8:54 pm
Read your PM.
I ordered the 5.25" option you sent over. Thank you again!
insanthony wrote: Fri Jun 21, 2024 6:40 am I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything. :D
Country of residence?
Drives in Sweden are very expensive. Do you have a chance to buy from Amazon France, Germany or UK? Otherwise is suggest to check with the seller Asmcom.
Zips9280 wrote: Fri Jun 21, 2024 3:43 pm
Tell me the expected day of arrival.
insanthony
Coopervid wrote: Fri Jun 21, 2024 5:41 pm
US. Apologies, didn't mean to omit that detail.
Jeggo
Post by Jeggo »
I am also located in Germany and quite new to MakeMKV. I just got a LG BP60NB10, which does not work with layer change on UHD disc.
I tired two brand new UHD disc and they both fail on the layer change at appr. 25GB. Other tracks on the first layer are OK. BluRays work without any problems. So I blame it on the hardware.
I think I will give the pioneer drives a try. Any recommandations for a good drive? Are the high end Pioneer drives worth the money?
CU Jens
insanthony wrote: Fri Jun 21, 2024 6:26 pm
Check your PM.
