Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Wad Mabbit
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
OK, I'll get of those. What's the advantage of the Archgon?
coopdeloop
Hello, Looking for help in finding a USA Slim drive for UHD. My pioneer works great for blus but have some UHDs I'd like to back up. The easier to set up the better for me. TIA
Your PM will expire next Monday.kbook wrote: Sat Jun 15, 2024 10:51 pm Hi I lived in USA and would like a recommendation for internal and external drives. Thanks
Tell me what Pioneer drive you have.coopdeloop wrote: Tue Jun 18, 2024 7:46 pmHello, Looking for help in finding a USA Slim drive for UHD. My pioneer works great for blus but have some UHDs I'd like to back up. The easier to set up the better for me. TIA
Johanna12221
Hi! I'm new to this and I'm trying to find which drive to buy. I'm located in Sweden.
Edit: Preferably looking for a 5,25" drive, external could be fine if it doesn't exists
insanthony
I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything.
Zips9280
Country of residence?insanthony wrote: Fri Jun 21, 2024 6:40 am I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything.![]()
Drives in Sweden are very expensive. Do you have a chance to buy from Amazon France, Germany or UK? Otherwise is suggest to check with the seller Asmcom.insanthony wrote: Fri Jun 21, 2024 6:40 am I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything.![]()
insanthony
US. Apologies, didn't mean to omit that detail.Coopervid wrote: Fri Jun 21, 2024 5:41 pmCountry of residence?insanthony wrote: Fri Jun 21, 2024 6:40 am I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything.![]()
Jeggo
I am also located in Germany and quite new to MakeMKV. I just got a LG BP60NB10, which does not work with layer change on UHD disc.
I tired two brand new UHD disc and they both fail on the layer change at appr. 25GB. Other tracks on the first layer are OK. BluRays work without any problems. So I blame it on the hardware.
I think I will give the pioneer drives a try. Any recommandations for a good drive? Are the high end Pioneer drives worth the money?
CU Jens
CU Jens
Check your PM.insanthony wrote: Fri Jun 21, 2024 6:26 pmUS. Apologies, didn't mean to omit that detail.Coopervid wrote: Fri Jun 21, 2024 5:41 pmCountry of residence?insanthony wrote: Fri Jun 21, 2024 6:40 am I too, am open to suggestions, something that won't give be a bunch of errors. Form factor doesn't matter as long as it can MakeMKVs out of anything.![]()
