Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Post by Coopervid » Tue Jun 18, 2024 9:18 am
dirtyrobinson wrote:
Thu Jun 13, 2024 12:08 am
I'm here for the same reason. Can this read play UHD discs?
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Check your PM
Post by Coopervid » Tue Jun 18, 2024 9:19 am
MeeStaKlean wrote:
Mon Jun 17, 2024 9:53 pm
Hello Coppervid
Hello, Can you please Message me the flash code for UD03. Here is the screenshot of the drive.
https://ibb.co/9GXjYgw
Check your PM.
MeeStaKlean
Post by MeeStaKlean » Tue Jun 18, 2024 12:58 pm
Good morning, thank you.
qops1981
Post by qops1981 » Tue Jun 18, 2024 3:59 pm
I have a similar drive? Looks my my revision is much older than what other have posted too. May I also get the flash?
Current profile: DVD-ROM
Product: BD-RW BDRUD03AS
Revision: 1.00
Firmware date: 2014-04-01
Highest AACS version: 50
Drive platform: Pioneer RS8510
Firmware version: ID23
Post by Coopervid » Tue Jun 18, 2024 8:53 pm
OS device name: G:
Revision: 1.14
Your PM will expire next Monday.
dirtyrobinson
Post by dirtyrobinson » Wed Jun 19, 2024 11:24 pm
Check your PM
There's no greater proof to "Not all heros wear capes". Thank you!!!
clwelch63
Post by clwelch63 » Sat Jun 22, 2024 3:40 pm
Hi coopervid,
I'd like to flash my PIONEER BD-RW BDR-UD03 with the firmware that lets it read UHD discs. I see a lot of discussion about it, but don't see where to download the firmware. Is there a download site? Thanks in advance.
Here's my drive information:
OS device name: E:
Revision: 1.10
Firmware date: 2017-04-18
Firmware version: 1.10
csomebody1
Post by csomebody1 » Tue Jun 25, 2024 1:42 am
I'm guessing the firmware on mine is too new, but is it possible to flash this drive to a firmware that can read a UHD disk?
Revision: 1.14
Highest AACS version: 76
Post by Coopervid » Tue Jun 25, 2024 9:21 am
Hi coopervid,
OS device name: E:
Revision: 1.10
PM sent.
Post by Coopervid » Tue Jun 25, 2024 9:22 am
Revision: 1.14
PM sent.
Post by Coopervid » Tue Jun 25, 2024 10:07 pm
Revision: 1.00
I oversaw you. Check your PM.
Post by Coopervid » Tue Jun 25, 2024 10:12 pm
Warning to people who don't read their PM. They will be deleted when they are one week old and unread. And then no further PMs will be sent.
csomebody1
Post by csomebody1 » Fri Jun 28, 2024 4:22 am
Revision: 1.14
PM sent.
Got it! Thank you! I'll take a look at the documentation and try flashing the drive.
qops1981
Post by qops1981 » Sun Jun 30, 2024 4:40 pm
Thank you very Much!!
mas1701
Post by mas1701 » Sun Jun 30, 2024 11:51 pm
is there any chance for UHD with this OEM USB3 BD-XL drive? When inserting an UHD disc, it only makes funny sounds, then stops.
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: ALDL2403xxxx
Firmware-Datum: 2018-08-22
Highest AACS version: 71
Firmware version: E101/ID26
After successfully flashing a first drive on Linux today and reading some of the previous posts, I'm at least a bit hopeful that there is an expert here who can help.
