Check your PMdirtyrobinson wrote: Thu Jun 13, 2024 12:08 am I'm here for the same reason. Can this read play UHD discs?
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Check your PM.MeeStaKlean wrote: Mon Jun 17, 2024 9:53 pm Hello Coppervid
Hello, Can you please Message me the flash code for UD03. Here is the screenshot of the drive.
https://ibb.co/9GXjYgw
MeeStaKlean
Good morning, thank you.
qops1981
I have a similar drive? Looks my my revision is much older than what other have posted too. May I also get the flash?
Current profile: DVD-ROM
Product: BD-RW BDRUD03AS
Revision: 1.00
Firmware date: 2014-04-01
Highest AACS version: 50
Drive platform: Pioneer RS8510
Firmware version: ID23
Your PM will expire next Monday.dirtyrobinson wrote: Thu Jun 13, 2024 12:08 am I'm here for the same reason. Can this read play UHD discs?
OS device name: G:
Revision: 1.14
dirtyrobinson
There's no greater proof to "Not all heros wear capes". Thank you!!!
clwelch63
Hi coopervid,
I'd like to flash my PIONEER BD-RW BDR-UD03 with the firmware that lets it read UHD discs. I see a lot of discussion about it, but don't see where to download the firmware. Is there a download site? Thanks in advance.
Here's my drive information:
OS device name: E:
Revision: 1.10
Firmware date: 2017-04-18
Firmware version: 1.10
OS device name: E:
Revision: 1.10
csomebody1
I'm guessing the firmware on mine is too new, but is it possible to flash this drive to a firmware that can read a UHD disk?
Revision: 1.14
Highest AACS version: 76
PM sent.clwelch63 wrote: Sat Jun 22, 2024 3:40 pm Hi coopervid,
OS device name: E:
Revision: 1.10
PM sent.csomebody1 wrote: Tue Jun 25, 2024 1:42 am I'm guessing the firmware on mine is too new, but is it possible to flash this drive to a firmware that can read a UHD disk?
Revision: 1.14
I oversaw you. Check your PM.qops1981 wrote: Tue Jun 18, 2024 3:59 pm I have a similar drive? Looks my my revision is much older than what other have posted too. May I also get the flash?
Drive Information OS device name: D: Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDRUD03AS Revision: 1.00 Serial number: [redacted] Firmware date: 2014-04-01 Bus encryption flags: 1B Highest AACS version: 50 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8510 Firmware version: ID23
Warning to people who don't read their PM. They will be deleted when they are one week old and unread. And then no further PMs will be sent.
csomebody1
Got it! Thank you! I'll take a look at the documentation and try flashing the drive.Coopervid wrote: Tue Jun 25, 2024 9:22 amPM sent.csomebody1 wrote: Tue Jun 25, 2024 1:42 am I'm guessing the firmware on mine is too new, but is it possible to flash this drive to a firmware that can read a UHD disk?
Revision: 1.14
qops1981
mas1701
is there any chance for UHD with this OEM USB3 BD-XL drive? When inserting an UHD disc, it only makes funny sounds, then stops.
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: ALDL2403xxxx
Firmware-Datum: 2018-08-22
Highest AACS version: 71
Firmware version: E101/ID26
After successfully flashing a first drive on Linux today and reading some of the previous posts, I'm at least a bit hopeful that there is an expert here who can help.
Produzent: ASUS
Revision: E101
