yes
kazuma
Post by kazuma »
is it possible to make a pause button on doviscripts while muxing reset_9999?
no
deadchip12
Post by deadchip12 »
RESET_9999 wrote:
Sat Jun 15, 2024 2:53 pm
yes
Thanks. A few more questions:
-When I first receive the Ugoos, should I boot it normally one time first or I just plug in the usb and install CoreELEC right away (using the recovery button method)?
-After the CoreELEC screen shows up, when can I unplug the usb?
-I saw this in the recommended setting page:
Optional, Remove ‘Restart to eMMC option…’ option from boot menu
To prevent accidentally restarting into Android you will need to modify the available boot options to suppress that option from even showing. Navigate to the COREELEC folder via folder browser on your computer, then go to /Addons/[the skin folder you’re using]/xml/DialogButtonMenu.xml. Edit the file and set reboot to eMMC to ‘False’ or remove the option altogether.
Where is this COREELEC folder? How come I can access this on the computer?
deadchip12 wrote:
Sun Jun 16, 2024 3:43 am
first boot to the ugoos firmware and update it if necessary and then plug the USB drive and reboot with the recovery button.
With that method, you must keep the USB drive plugged all the time.
You don't need to do that if you install it on an external USB drive. This is for when you install it to the internal ugoos drive in dual boot mode which is faster.
I'm using a fast usb-3 flash drive and I haven't bothered trying that yet.
deadchip12
RESET_9999 wrote:
Sun Jun 16, 2024 12:12 pm
Wait so the usb must stay there forever, even during movie watching? So if the usb somehow malfunctions we need to redo all the installation steps again with a new usb?
Post by SamuriHL »
If you're not wanting to keep it on an external USB device or memory card, then move it to the internal memory and enable the fast memory mode. That's what I did with mine and it works fine.
yes, I dont use a cheap USB flash drive so I never have issues myself.
Otherwise, if you don't want to use an external drive, as @SamuriHL and I said you can install it to the ugoos internal drive in dual boot mode.
See the last point(9) in the installation instruction here:
https://discourse.coreelec.org/t/guide- ... tion/51231
deadchip12
I just received the Ugoos AM6B+ and finished setting up CoreELEC. So far so good. Tested a few minutes of an mkv movie file and there seemed to be no playback problem. Will watch a full movie later this week.
Some questions/early impressions:
-from the recommended setting page:
Settings->Services->Caching
Buffer mode - cache settings to all methods: smb, local, remote, etc (default ignores local playback)
Read factor - Set 'Adaptive’ readfactor (default is 4x). This is a multiplier for the bandwidth allocation based on video bitrate. Eg if video bitrate is 50Mbps and multiplier is set to 4x, then Kodi allocates 200Mbps of bandwidth to fill the cache faster. Adaptive is recommended
@RESET_9999 Do I need to follow this? I don't see you mention this in your own guide.
-The remote sucks. Its air mouse is pretty bad, and the remote itself is bare-bones. There's no play/pause/stop button, so it takes a few presses to navigate to the on-screen buttons. Any workaround?
-I'm using CoreELEC 21.0, which I believe is the first version in which DV works properly, downloaded from @RESET_9999's link. When should I update this to a later version? Is there a way to do this directly on the Ugoos (in the Update section) or do I have to reinstall the new CoreELEC version on the usb and repeat the Recovery Button installation method with the Ugoos?
I don't know. I've never changed any of this on mine.
Post by SamuriHL »
I didn't either. As for updates, you can allow it to update nightlies in the coreelec settings if you desire. They contain bug fixes but could introduce new issues.
Sent from my SM-S928U1 using Tapatalk
deadchip12
SamuriHL wrote:
Mon Jun 17, 2024 12:15 pm
Do you notice any differences in the latest build compared to the first build 21.0?
ans40
Post by ans40 »
deadchip12 wrote:
Mon Jun 17, 2024 9:21 am
Idk if it makes a difference but I use Jellyfin with "Jellyfin for Kodi" Add-on, and adjusting those settings did resolve high bitrate video stuttering. Playback is 100% smooth now. So if you experience stuttering then I'd start there.
A lot of your questions regarding CoreElec have been discussed on the CoreElec site and forums so you should head over there and look around.
Updating instructions. There are also nightly releases of CE 21 as development progresses that you can download if you want to help test the software or develop functions/fixes yourself but its generally recommended to stick to the stable versions (right now, 21.0) for general use unless you need the fixes offered in the nightlies. My 21.0 has handled everything I've thrown at it so I probably won't be updating until next stable.
Post by SamuriHL »
deadchip12 wrote:
Mon Jun 17, 2024 5:10 pm
This question makes no sense. Of course there are differences. Lots of bug fixing, some new functionality as far as I've seen, etc. I never started with the "first build of 21". I started directly with nightlies as the guide I followed recommended them because of the bug fixes. No, I'm not regurgitating the changesets of the differences between the first build and all the nightlies since then to show what bugs have been fixed or what might have been added. They are in the changeset release notes for each nightly. What I can say is that everything I need it to do works in the nightlies.
deadchip12
I can only see stable release updates in the coreelec settings. No nightly.
