LibreDrive for Pioneer drives
jkboyo wrote: Wed Jun 12, 2024 11:34 pm This is the information for the previous post out of MKV(hit enter too early) :')
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DADL025006WL
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 47
Firmware version: ID06
Email me for the flasher see below
xaoseric
Post by xaoseric »
This is the information for my drive.
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: redacted
Firmware date: 2023-01-06
Highest AACS version: 68
Firmware version: ID05
xaoseric wrote: Sun Jun 16, 2024 7:47 pm This is the information for my drive.
OS device name: E:
Revision: 1.03
nah sorry man to new return it if you can.
few sellers here have pioneers with old fw im all out of USB ones and wont be getting more though full size only 5.25 but they can be made usb easy
MarkFromSales
Post by MarkFromSales »
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number: DBDL930313UC
Firmware date: 2023-08-01
Highest AACS version: 81
Firmware version: ID43
Disc Information
Label: [removed]
Timestamp: [removed]
Protection: AACS2.0/C v76
Data capacity: 58.24 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Getting "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" with above as of 2021-06-18 running a registered install of v1.17.7 (updated today) on Windows 11.
I also have a LG WH16NS40 that works great for non-UHD
Thank you for the great work, love MakeMKV!
MarkFromSales wrote: Tue Jun 18, 2024 2:43 pm Drive Information
Revision: 1.05
Disc Information
Label: [removed]
Number of layers: 2
I recommend you return it and get a pioneer with old fw from me.
There is currently no way to downgrade these
chronomac
Post by chronomac »
Just installed my BDR-212DBK. Info from MakeMKV:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: CIDL053978WL
Firmware date: 2022-03-16
Drive platform: RS8F00
Firmware version: 1.02/ID61
Ripped a Blu-ray with no problem but when I put a 4K disc in it couldn't read it. I assume 1. I need to flash it 2. It is flash-able, because it's from 3/22.
chronomac wrote: Tue Jun 18, 2024 10:41 pm Just installed my BDR-212DBK. Info from MakeMKV:
Revision: 1.02
email me for the auto flasher for that see below
outlier
Post by outlier »
I have the impression that the BDR-XS07U (firmware 1.01) is more prone to getting stuck running a save in a slow[er] mode (compared to the BDR-XD08U and BDR-X13U that I also have experience with). E.g., if you take too long to pick out what to save from the disc and the drive spins down to a slower rate before you initiate the save then the drive is more likely to perform the save at a slower rate (basically runs at most at 2x or 3x max). Or, the drive might initially perform the save at a decent rate, and then the save enters safe mode and reduces to 3x, but after exiting safe mode the drive doesn't ever go back to a faster rate.
starkkie
Post by starkkie »
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
starkkie wrote: Sat Jun 22, 2024 1:17 am Drive Information
Revision: 1.02
Can't do nothing with that. Perhaps you should return it.
voltagex
Post by voltagex »
I am almost sure this used to work with older MakeMKVs
PIONEER_BD-RW___BDR-XS06_1.01_PFDL007080UC - disconnects and reconnects when starting to read discs.
001003:0020 DEBUG: Code 1 at D!3/rPt!1Ynu_3vQ.&=3+:B :121261704
001003:0020 DEBUG: Code 3221225486 at D!3/rPt!1Ynu_3vQ.&=3+:B :121261727
001003:0020 DEBUG: Code 3221225486 at 5#4\dEib_fCEUs!P8iCn:213130582
DEBUG: Code 3 at wsuH-I{pjx"D{a*<>oxG0$',:29395310
SDF  v098: PIONEER_BD-RW___BDR-XS06_1.01_PFDL007080UC
DEBUG: Code 4278358273 at eP4E'9IxPe4XXL<dp:121265246
DEBUG: Code 0 at eP4E'9IxPe4XXL<dp:213133388
DEBUG: Code 4278317063 at eP4E'9IxPe4XXL<dp:121265246
DEBUG: Code 1 at eP4E'9IxPe4XXL<dp:213133388
DEBUG: Code 2 at eP4E'9IxPe4XXL<dp:213133388
DEBUG: Code 3 at eP4E'9IxPe4XXL<dp:213133388
DEBUG: Code 4 at eP4E'9IxPe4XXL<dp:213133388
DEBUG: Code 5 at eP4E'9IxPe4XXL<dp:213133388
DEBUG: Code 4278317063 at eP4E'9IxPe4XXL<dp:29396943
DEBUG: Code 0 at :_D~hKrDX!l7kzzP:29401750
001003:0020 DEBUG: Code 3221225629 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 3221225629 at 8)gN3IM7_1@BG-`Ird:121263429
001003:0020 DEBUG: Code 3221225629 at 8)gN3IM7_1@BG-`Ird:121262302
002003:0000 Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading 'BD-RE PIONEER BD-RW   BDR-XS06 1.01 PFDL007080UC' at offset '524288'
001003:0020 DEBUG: Code 3221225664 at y/G?z@b0R+~Y]$0V:213130559
001003:0020 DEBUG: Code 3221225664 at 8)gN3IM7_1@BG-`Ird:121263429
001003:0020 DEBUG: Code 3221225664 at 8)gN3IM7_1@BG-`Ird:121262302
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-RE PIONEER BD-RW   BDR-XS06 1.01 PFDL007080UC' at offset '1048576'
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-RE PIONEER BD-RW   BDR-XS06 1.01 PFDL007080UC' at offset '32768'
001003:0020 DEBUG: Code 0 at 8\N?a?btpdZeI[I/XU]:213129777
001003:0020 DEBUG: Code 3221225664 at :_D~hKrDX!l7kzzP:121267293
Post by d00zah »
voltagex wrote: Mon Jun 24, 2024 10:51 am I am almost sure this used to work with older MakeMKVs
Drive is USB powered & looks to be drawing more than the source can provide. If a 2-USB Y-connector is provided, use both connections. Try rear-panel USB ports. Try an externally powered USB hub.
voltagex
Post by voltagex »
Good catch, it seems to be using at least an additional 5 watts, perhaps I've never used this for blurays.
starkkie
Post by starkkie »
MartyMcNuts wrote: Sat Jun 22, 2024 9:20 am
Revision: 1.02
Dang ok. I really like this drive model; if i can get my hands on one with firmware from pre Dec 2022, would that work, or does this drive not work all together? And if it does work, do i need special firmware like the LG drives, or does it work out of the box?
Thanks in advance for your help.
starkkie wrote: Tue Jun 25, 2024 1:41 am
Revision: 1.02
If you can find a XD08U (UHD version) with pre Dec 2022 firmware then it will work out of the box but you will be very hard pressed to find one anywhere!! They all seem to have the newer firmware.
