Just flash it directly to 3.10MK and you're good to go.onoredikeidooo wrote: ↑Mon Jun 03, 2024 10:47 pmHey guys! I'll appreciate any help.
I own 2 Asus BW-16D1HT.
Drive 1 (manufactured on May/2018) is basically "about to die" (still works here and there but it's failing most of the time), did a great job during the rips/burns I did during this time and it's patched.
Drive 2 (manufactured on November/2023) I got these days ago and I didn't patched yet.Informações da Unidade
Nome do dispositivo do SO: F:
Fabricante: ASUS
Produto: BW-16D1HT
Revisão: 3.10
Número de série: [REDACTED]
Data do Firmware: 2119-01-04 10:14
Sinalizações de criptografia bus: 1F
Firmware version: 3.10
Judging by the manufacture date and the firmware information above, is it safe to patch with the current Libredrive pack available here to download?Informações da Unidade
Nome do dispositivo do SO: D:
Fabricante: ASUS
Produto: BW-16D1HT
Revisão: 3.11
Data do Firmware: 2120-12-01 17:59
Thanks in advance!
Ultimate UHD Drives Flashing Guide Updated 2025
With Pioneer no longer being viable for buying new, what drives are recommended for quality?
Reviewing the drives listed, some clearly have quality issues and low ratings. And some have buy before a certain manufacture date.
It seems like the only buy new drives are poor quality, does one stand out as better quality?
Pre-flashed/tested drives for whatever region you are in can be had...Plane wrote: ↑Sun Jun 09, 2024 10:21 pmWith Pioneer no longer being viable for buying new, what drives are recommended for quality?
Drives for sale, Flashing Services, where to buy...
Vendors request you contact them via email w/ questions (consult respective topics).
I am ok with attempting to flash a drive, so I am not looking to buy a preflashed drive. The flashing guide lists compatible drives, and comments that Pioneer drives are of higher quality, but are no longer viable do to an updated firmware. However no additional comments on drive quality, or ranking is made for other drives.d00zah wrote: ↑Mon Jun 10, 2024 12:17 amPre-flashed/tested drives for whatever region you are in can be had...Plane wrote: ↑Sun Jun 09, 2024 10:21 pmWith Pioneer no longer being viable for buying new, what drives are recommended for quality?
drive quality rank here you go best to worstPlane wrote: ↑Tue Jun 11, 2024 12:42 am
Pioneer BDR S13UX
Pioneer BDR S13UBK
Pioneer BDR 213 212/S12
Pioneer BDR XS07, XD07, XD08
Pioneer BDR UD04, UD03, XD05
LG BU40N BP50NB40 BP60NB10 ect..
LG/ASUS WH14xx-WH16xx Asus BW16D1HT BH14xx-BH16xx ect... all the same junk if your getting one of these they are all the same get the cheapest available and hope you get a good one.
All pioneers need old FW or to be professionally flashed
for most i recommend the UBK as the UX is way over priced in the USA. the UX has a fw cents worth of better caps black paint job and slightly more sound deadening on the disc tray not worth it.
i myself have a UBK.
I'm not quite up to date on the Pioneer news so I'll just ask this simply: if I get a 212DBK, listed here on Amazon, today would I be able to use it for UHD discs, with or without new firmware?Billycar11 wrote: ↑Tue Jun 11, 2024 2:00 amdrive quality rank here you go best to worst
Pioneer BDR S13UX
Pioneer BDR S13UBK
It would need to be professionally flashed you can email me for that only the 212 for now is still remote flashablechronomac wrote: ↑Sat Jun 15, 2024 4:14 pmI'm not quite up to date on the Pioneer news so I'll just ask this simply: if I get a 212DBK, listed here on Amazon, today would I be able to use it for UHD discs, with or without new firmware?Billycar11 wrote: ↑Tue Jun 11, 2024 2:00 amdrive quality rank here you go best to worst
Pioneer BDR S13UX
Pioneer BDR S13UBK
Fate.
I'll be in contact tomorrow after I get the MakeMKV drive specs page.
Was not my question, but I'll take that answer also since I ordered that same 212DBK this morning and wondered later if it could read UHD.It would need to be professionally flashed you can email me for that only the 212 for now is still remote flashable
Fate.
no it wont read UHD it will need to be professionally flashed mail me for that if the fw is after 12/22 your out of luck but most 212s are old stillJustSittingHere wrote: ↑Sun Jun 16, 2024 1:24 amI'm not quite up to date on the Pioneer news so I'll just ask this simply: if I get a 212DBK, listed here on Amazon, today would I be able to use it for UHD discs, with or without new firmware?Was not my question, but I'll take that answer also since I ordered that same 212DBK this morning and wondered later if it could read UHD.It would need to be professionally flashed you can email me for that only the 212 for now is still remote flashable
Fate.
I've got a portable BD writer SE-506
TSSTcorp BDDVDW SE-506CB
Revision: TS02
Serial number: [redacted]
Bus encryption flags: 1F
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 01.07
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
So, is this flashable?
Revision: TS02
Not for UHD support - the hardware won't do it.
Thanks for that
Dear everyone,
do you have any idea what I'm doing wrong?
I have the LG BU40N drive with Windows 10 and DVDFab 13 (13.0.1.9) and MakeMKV 1.17.7
My problem is now that I cannot rip the 4k UHD Blu-Rays "Avengers - Infinity War" and "Avengers - Endgame" with voices of the actors.
This means I can rip both discs to the hard drive and everything is fine except that the voices of the actors cannot be heard. The soundtrack, music, etc. can be heard perfectly but you cannot hear enything when the actors speak…
This happens with DVDFab and MakeMKV.
I flashed now the LG BU40N with SDFtool Flasher (v1.3.5) from 1.0 to 1.03 (The all you need firmware pack.zip) but still the same issue.
Any idea how to solve this?
Best regards
Best regards
My laptop has no DVD so I'll need to find a USB drive that will be able to be flashed for UHD. I'd appreciate knowing a worthy one to get & where to find the software for flashing. Any help is greatly appreciated.
Have you read the 1st post of this topic, for starters?
