Special SATA Cable Needed?
sphere3923
Post by sphere3923 »
Hi everyone,
I'm about to purchase a UHD friendly Blu-ray drive and I'm wondering about the SATA cable adapter. Do I need a special SATA cable adapter mentioned in the Ultimate Guide, or is a regular one sufficient?
Thanks in advance for your help!
Re: Special SATA Cable Needed?
If your connecting to a motherboard directly SATA to sata any SATA cable will do.
If your going to USB I would recommend the owc mercury pro.
sphere3923
Billycar11 wrote: Sun Jun 16, 2024 3:08 pm If your connecting to a motherboard directly SATA to sata any SATA cable will do.
If your going to USB I would recommend the vantec dx2.
Thanks for the info! Just wondering, is the LG WH16NS40 compatible with this enclosure?
sphere3923 wrote: Sun Jun 16, 2024 3:31 pm
Yes works with that drive and the pioneers
