Your PM will be deleted on Monday.
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Looking for 5.25 inch drive in Sweden.
If in doubt, flat out!
Hi I lived in USA and would like a recommendation for internal and external drives. Thanks
I'm in Australia and Indonesia, what's the best portable drive (preferably ready-to-go?
Windows laptop user, slimline poprtable preferred.
Don' care about writing to disk, only reading
You can buy the Verbatim 43888. It's UHD ready but it is power hungry on USB and the enclosure electronics seems not to be the best quality.Wad Mabbit wrote: ↑Sun Jun 16, 2024 2:38 pmHi,
OK, so NOT the Verbatim 43888
What about the BDR-XD08TB (flip)
or BDR-XS07B-UHD, BDR-XS07TS, BDR-XD08EMB-S?
Oop, forgot to ask about the Archgon MD-8107S-U3-UHD and the LG WP/BP50NB40 (BU40N)
No, none of those Pioneer drives are UHD compatible as they all come with too new firmware that disabled libredrive and UHD readability.Wad Mabbit wrote: ↑Sun Jun 16, 2024 11:07 pmOK, so NOT the Verbatim 43888
Yes, both are good. The BP50NB40 cross-flashed with BU40N firmware works the same as the Archgon for UHD ripping.Wad Mabbit wrote: ↑Sun Jun 16, 2024 11:12 pmOop, forgot to ask about the Archgon MD-8107S-U3-UHD and the LG WP/BP50NB40 (BU40N)
Check out my site for drive options. Link in my signature.
Total noob here.
Looking to get DVD and BR rips for my digital collection and getting dead-ended on some cranky discs while using a a Verbatim-brand BDR-UD03.
From a long time using MakeMKV and some moderate research outside this forum it sounds like there's just some discs that don't play nice and possible upgrade to my drive might catch a few of them?
Working in windows and from the US. Sadly don't have a slot in my tower for an internal drive so I'd either have to just get an external or rig up an enclosure of some kind to work with an internal drive if that's a thing.
Recommendations?
Recommendations?
