with the release 1.6.14 I have a problem playing the mkv in my LG 32le5300. The movie hangs for a short period every 3 seconds. When I edit thie MKV with mkv merge everything works fine. Please help....
File Info after makemkv
General
Unique ID : 251717154955592115570491518198546232842 (0xBD5EF5EB7CA01268B6D26C6E8784F60A)
Format : Matroska
Format version : Version 2
File size : 1.48 GiB
Duration : 42mn 17s
Overall bit rate : 5 027 Kbps
Encoded date : UTC 2011-07-02 15:21:33
Writing application : MakeMKV v1.6.10 win(x86-release)
Writing library : libmakemkv v1.6.10 (1.2.0/1.1.0) win(x86-release)
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Custom
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 42mn 17s
Bit rate mode : Variable
Bit rate : 4 543 Kbps
Maximum bit rate : 7 500 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.438
Stream size : 1.34 GiB (90%)
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 42mn 17s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -87ms
Stream size : 116 MiB (8%)
Title : 3/2+1
Language : German
Menu
00:00:00.000 : en:Chapter 01
00:04:01.047 : en:Chapter 02
00:10:55.047 : en:Chapter 03
00:14:06.767 : en:Chapter 04
00:16:35.647 : en:Chapter 05
00:18:45.767 : en:Chapter 06
00:22:32.807 : en:Chapter 07
00:25:42.247 : en:Chapter 08
00:29:52.607 : en:Chapter 09
00:31:38.807 : en:Chapter 10
00:35:10.407 : en:Chapter 11
00:38:39.567 : en:Chapter 12
Here the file info after mkvmerge
General
Unique ID : 242342180554026278824945851946255415170 (0xB65167FECD23E396A7A8B799684A7782)
Format : Matroska
Duration : 42mn 17s
Encoded date : UTC 2011-08-28 11:37:35
Writing application : mkvmerge v4.9.1 ('Ich will') gebaut am Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : MPEG Video
Codec ID : V_MPEG2
Duration : 42mn 17s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Language : German
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 42mn 17s
Bit rate : 384 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : German
Menu
Problem playing MKV on LG 32LE5300
crowfax
Re: Problem playing MKV on LG 32LE5300
Update to 1.6.14: http://makemkv.com/download/stidge wrote:Writing application : MakeMKV v1.6.10 win(x86-release)
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
stidge
Sorry, the file above was build with 1.6.10 but I have the same problem with 1.6.14.
stidge
Here the file informations made by mkvinfo
File with makemkv
(MKVInfo) + EBML-Kopf
(MKVInfo) |+ EBML-Version: 1
(MKVInfo) |+ EBML Leseversion: 1
(MKVInfo) |+ Maximale EBML-ID-L?¤nge: 4
(MKVInfo) |+ Maximale L?¤nge des EBML-L?¤ngenattributes: 8
(MKVInfo) |+ Dokumententyp: matroska
(MKVInfo) |+ Dokumententyp Version: 2
(MKVInfo) |+ Dokumententyp Leseversion: 2
(MKVInfo) + Segment, Gr?¶??e 1635983794
(MKVInfo) |+ Seek-Kopf
(MKVInfo) | + Seek-Eintrag
(MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo)
(MKVInfo) | + Seek-Position: 1113
(MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks)
(MKVInfo) | + Seek-Position: 1250
(MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues)
(MKVInfo) | + Seek-Position: 1635907920
(MKVInfo) | + Seek ID: 0x10 0x43 0xa7 0x70 (KaxChapters)
(MKVInfo) | + Seek-Position: 3166
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 1021)
(MKVInfo) |+ Segment-Information
(MKVInfo) | + Zeitstempelskalierungsfaktor: 1000000
(MKVInfo) | + Muxeranwendung: libmakemkv v1.6.14 (1.2.0/1.1.0) win(x64-release)
(MKVInfo) | + Schreibende Anwendung: MakeMKV v1.6.14 win(x64-release)
(MKVInfo) | + Dauer: 2534.607s (00:42:14.607)
(MKVInfo) | + Datum: Sun Aug 28 16:03:30 2011 UTC
(MKVInfo) | + Segment-UID: 0x0c 0xb9 0x53 0x41 0xf4 0xd9 0x75 0xc0 0xa4 0xa3 0x8f 0x3f 0x7a 0x57 0x52 0xc9
(MKVInfo) |+ Segment-Tracks
(MKVInfo) | + Ein Track
(MKVInfo) | + Tracknummer: 1
(MKVInfo) | + Track UID: 1
(MKVInfo) | + Tracktyp: video
(MKVInfo) | + Flag f??r Paketb??ndelung: 0
(MKVInfo) | + MinCache: 2
(MKVInfo) | + Codec-ID: V_MPEG2
(MKVInfo) | + private Codecdaten, L?¤nge 152
(MKVInfo) | + Standarddauer: 40.000ms (25.000 Bilder pro Sekunde im Falle eines Videotracks)
(MKVInfo) | + Video-Track
(MKVInfo) | + Pixelbreite: 720
(MKVInfo) | + Pixelh?¶he: 576
(MKVInfo) | + Anzeigebreite: 1024
(MKVInfo) | + Anzeigeh?¶he: 576
(MKVInfo) | + Tracknummer: 2
(MKVInfo) | + Track UID: 2
(MKVInfo) | + Tracktyp: audio
(MKVInfo) | + Codec-ID: A_AC3
(MKVInfo) | + Sprache: ger
(MKVInfo) | + Standarddauer: 32.000ms (31.250 Bilder pro Sekunde im Falle eines Videotracks)
(MKVInfo) | + Name: 3/2+1
(MKVInfo) | + Audio track
(MKVInfo) | + Abtastrate: 48000
(MKVInfo) | + Kan?¤le: 6
(MKVInfo) | + Tracknummer: 3
(MKVInfo) | + Track UID: 3
(MKVInfo) | + Tracktyp: subtitles
(MKVInfo) | + Codec-ID: S_VOBSUB
(MKVInfo) | + private Codecdaten, L?¤nge 509
(MKVInfo) | + Tracknummer: 4
(MKVInfo) | + Track UID: 4
(MKVInfo) | + Standardtrack-Flag: 0
(MKVInfo) | + Tracknummer: 5
(MKVInfo) | + Track UID: 5
(MKVInfo) |+ Kapitel
(MKVInfo) | + EditionEntry
(MKVInfo) | + EditionFlagHidden: 0
(MKVInfo) | + EditionFlagDefault: 1
(MKVInfo) | + EditionUID: 12915922310339309525
(MKVInfo) | + (Unbekanntes Element: EBMLVoid; ID: 0xec Gr?¶??e: 48)
(MKVInfo) | + ChapterAtom
(MKVInfo) | + ChapterUID: 6600988848267687528
(MKVInfo) | + ChapterTimeStart: 00:00:00.000000000
(MKVInfo) | + ChapterFlagHidden: 0
(MKVInfo) | + ChapterFlagEnabled: 1
(MKVInfo) | + ChapterDisplay
(MKVInfo) | + ChapterString: Chapter 01
(MKVInfo) | + ChapterLanguage: eng
(MKVInfo) | + ChapterUID: 5302647143292416574
(MKVInfo) | + ChapterTimeStart: 00:03:24.287977777
(MKVInfo) | + ChapterString: Chapter 02
(MKVInfo) | + ChapterUID: 5259777300638015384
(MKVInfo) | + ChapterTimeStart: 00:06:20.607977777
(MKVInfo) | + ChapterString: Chapter 03
(MKVInfo) | + ChapterUID: 5760466414679433918
(MKVInfo) | + ChapterTimeStart: 00:08:47.927977777
(MKVInfo) | + ChapterString: Chapter 04
(MKVInfo) | + ChapterUID: 15211834422386042834
(MKVInfo) | + ChapterTimeStart: 00:11:27.647977777
(MKVInfo) | + ChapterString: Chapter 05
(MKVInfo) | + ChapterUID: 15981302781094438331
(MKVInfo) | + ChapterTimeStart: 00:15:12.727977777
(MKVInfo) | + ChapterString: Chapter 06
(MKVInfo) | + ChapterUID: 8986237484827966272
(MKVInfo) | + ChapterTimeStart: 00:17:43.407977777
(MKVInfo) | + ChapterString: Chapter 07
(MKVInfo) | + ChapterUID: 16958650146549606241
(MKVInfo) | + ChapterTimeStart: 00:20:09.967977777
(MKVInfo) | + ChapterString: Chapter 08
(MKVInfo) | + ChapterUID: 10173933294178321389
(MKVInfo) | + ChapterTimeStart: 00:24:30.527977777
(MKVInfo) | + ChapterString: Chapter 09
(MKVInfo) | + ChapterUID: 16688510121909472696
(MKVInfo) | + ChapterTimeStart: 00:29:13.487977777
(MKVInfo) | + ChapterString: Chapter 10
(MKVInfo) | + ChapterUID: 3423498750120431433
(MKVInfo) | + ChapterTimeStart: 00:34:07.167977777
(MKVInfo) | + ChapterString: Chapter 11
(MKVInfo) | + ChapterUID: 18027791169878789527
(MKVInfo) | + ChapterTimeStart: 00:38:03.287977777
(MKVInfo) | + ChapterString: Chapter 12
(MKVInfo) |+ Cluster
File after mkvmerge
(MKVInfo) + Segment, Gr?¶??e 1598861539
(MKVInfo) | + Seek-Position: 4099
(MKVInfo) | + Seek-Position: 4249
(MKVInfo) | + Seek-Position: 1598787314
(MKVInfo) | + Seek-Position: 6819
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 4029)
(MKVInfo) | + Muxeranwendung: libebml v1.2.1 + libmatroska v1.1.1
(MKVInfo) | + Schreibende Anwendung: mkvmerge v4.9.1 ('Ich will') gebaut am Jul 11 2011 23:53:15
(MKVInfo) | + Dauer: 2474.648s (00:41:14.648)
(MKVInfo) | + Datum: Sun Aug 28 19:31:53 2011 UTC
(MKVInfo) | + Segment-UID: 0x9a 0x03 0x09 0x2e 0xaa 0xf0 0x32 0xf8 0xa3 0x3d 0x4c 0xab 0x5d 0xde 0x69 0x61
(MKVInfo) | + Inhaltskodierungen
(MKVInfo) | + Inhaltskomprimierung
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 1171)
(MKVInfo) | + EditionUID: 10513718927689726498
(MKVInfo) | + ChapterUID: 11071981707625861246
(MKVInfo) | + ChapterUID: 13907736328834604584
(MKVInfo) | + ChapterTimeStart: 00:03:16.607977777
(MKVInfo) | + ChapterUID: 2466260640834288163
(MKVInfo) | + ChapterTimeStart: 00:05:46.727977777
(MKVInfo) | + ChapterUID: 3476502681518425561
(MKVInfo) | + ChapterTimeStart: 00:10:06.447977777
(MKVInfo) | + ChapterUID: 11164657143329770977
(MKVInfo) | + ChapterTimeStart: 00:13:45.767977777
(MKVInfo) | + ChapterUID: 7706525193942486452
(MKVInfo) | + ChapterTimeStart: 00:18:11.447977777
(MKVInfo) | + ChapterUID: 12501520707523653492
(MKVInfo) | + ChapterTimeStart: 00:22:09.127977777
(MKVInfo) | + ChapterUID: 12088525475564576559
(MKVInfo) | + ChapterTimeStart: 00:26:00.887977777
(MKVInfo) | + ChapterUID: 7119766449340844920
(MKVInfo) | + ChapterTimeStart: 00:29:41.567977777
(MKVInfo) | + ChapterUID: 8575058931623154166
(MKVInfo) | + ChapterTimeStart: 00:31:27.567977777
(MKVInfo) | + ChapterUID: 13271784711923174234
(MKVInfo) | + ChapterTimeStart: 00:36:07.487977777
(MKVInfo) | + ChapterUID: 16762510866261496561
(MKVInfo) | + ChapterTimeStart: 00:38:23.687977777
(MKVInfo) |+ EbmlVoid (Gr?¶??e: 101)
File with makemkv
File after mkvmerge
Please do the following - open MKV file produced by MMG in MakeMKV 1.6.14, keep all tracks, and make another MKV file. Please post if the file still has issues.
stidge
It is not possible to open the file with makemkv 1.6.14....
German Error message : "Das ?ffnen der Disk schlug fehl"
